Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
103 registered members (01rangerxl, 2015_PSD, 77GrandPrix, 4WD, 11 invisible), 1,590 guests, and 52 spiders.
Topics286,092
Posts4,902,394
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Rotella T6 in Generator #4516212
09/14/17 03:18 PM
09/14/17 03:18 PM
FL, USA
shurguywutt Offline OP
FL, USA
I have a b&s 5500 generator that I usually run conventional 10w40. Can I run Rotella T6 5w40 or will lower zinc levels affect air cooling? Thanks
2008 Pilot 2WD J35Z1 153k
Shell 5w-30
Re: Rotella T6 in Generator [Re: shurguywutt] #4516219
09/14/17 03:25 PM
09/14/17 03:25 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
approved
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Rotella T6 in Generator [Re: shurguywutt] #4516282
09/14/17 04:21 PM
09/14/17 04:21 PM
USA
ArcticDriver Offline
USA
Does rotella T6 actually have lower Zinc levels than conventional 10w40?
Which brand ?
Thanks
Multiple Diesel and Gasoline vehicles
Re: Rotella T6 in Generator [Re: ArcticDriver] #4516331
09/14/17 05:24 PM
09/14/17 05:24 PM
FL, USA
FL, USA
Pennzoil Yellow bottle
Shell 5w-30
Re: Rotella T6 in Generator [Re: shurguywutt] #4516379
09/14/17 06:30 PM
09/14/17 06:30 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Rotella kicks Pennzoil 10W40 around the ring and knocks it out in the first round.
Yes the Rotella is fine.
Or get a jug of SuperTech 15W40 and call it a day.
I just bought Carquest SAE40 from Advance Auto for my generator a few days ago.
Remember, it needs an oil change every 50 hours, or every 100 hours if it has an oil filter. So the synthetic is really not needed.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Rotella T6 in Generator [Re: bubbatime] #4516423
09/14/17 07:13 PM
09/14/17 07:13 PM
USA
USA
An oil change every 2 days of run time?
Glad you mentioned that.
I don't know anyone here along SW Florida practicing that while they await FPL.
Re: Rotella T6 in Generator [Re: shurguywutt] #4516424
09/14/17 07:14 PM
09/14/17 07:14 PM
ME
eljefino Offline
eljefino  Offline
ME
Zinc levels are for valve spring pressures on radical cams. You're likely good, there.
Cooling depends on how hard you run it. The RPMs are the same but the load would be higher. Consider your needs and how gasoline is approx 15x as expensive as grid power. The rotella IS a superior product in general and I want something like it in my backup set, too.
Re: Rotella T6 in Generator [Re: shurguywutt] #4516427
09/14/17 07:18 PM
09/14/17 07:18 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
I'd personally run the arguably superior D1 and call it a day.
This engine won't have high enough cam loads that a few PPM of ZDDP would matter, air cooled or not.
A better basestock would likely be of more benefit in any event, and that would be D1.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Rotella T6 in Generator [Re: shurguywutt] #4516530
09/14/17 08:48 PM
09/14/17 08:48 PM
FL, USA
FL, USA
Thanks for the input. I usually change the oil every 100 hours. T6 it is.
Shell 5w-30
Re: Rotella T6 in Generator [Re: shurguywutt] #4516541
09/14/17 08:57 PM
09/14/17 08:57 PM
Great White North.. eh
webfors Offline
webfors  Offline
Yes.
The manual call for a 40 weight?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: Rotella T6 in Generator [Re: shurguywutt] #4516549
09/14/17 09:02 PM
09/14/17 09:02 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
For Florida you do not need any 5W anything. With the warm to hot temperatures in Florida you would be better off with 15W 40, or better yet 15W 50.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Rotella T6 in Generator [Re: shurguywutt] #4516579
09/14/17 09:26 PM
09/14/17 09:26 PM
JimPghPA Offline
JimPghPA  Offline
Oils with higher spreads between the low and higher number are more prone to shearing, especially in hot applications like air cooled engines running in hot ambient temperatures. A 5W 40 would be more apt to shear than a 15W 40.
JimPghPa
Re: Rotella T6 in Generator [Re: JimPghPA] #4516597
09/14/17 09:59 PM
09/14/17 09:59 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
+1 I run T6 5W40 in alot of things but only for the cold weather performance. If it rarely got to freezing I'd just use 15W40 in all the same stuff.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Rotella T6 in Generator [Re: JimPghPA] #4516627
09/14/17 10:43 PM
09/14/17 10:43 PM
USA
USA
Wouldn't this be dependent on the HT/HS ?
If a full synthetic 5w40 were a cP 3.9 and a semi-synthetic 15w40 were also a cP of 3.9 then doesn't that mean equal shear stability?
I thought full synthetics had an advantage of being more shear stable?
Not arguing...just trying to better understand.
Re: Rotella T6 in Generator [Re: shurguywutt] #4516671
09/15/17 12:14 AM
09/15/17 12:14 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The answer is... It depends. In general you want a narrower spread with less VII for higher heat, but depending on how it is blended the 5w40 syn may outperform the conventional 15w40. I don't have a data sheet for the oil so I can't say.
For OPE. Particularly generators, I would go with a quality syn 40 or 50. The better base stocks resist heat better than conventional. The important thing is to make sure you have an oil that will have adequate viscosity at 280-290F. The generators are a special case in that they run wide open under high load for extended periods. The oil gets hot.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Page 1 of 3 1 2 3
