High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Sparking discussion - excellent article
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Rotella CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
99 registered (69Torino, 01rangerxl, 4WD, Ag76, 9050lx, 11 invisible), 1432 Guests and 42 Spiders online.
65299 Members
67 Forums
285802 Topics
Page 1 of 2 1 2 >
#4516164 - 09/14/17 01:49 PM Source for 5 - 10ml of 99% Isopropyl Alcohol?
LoneRanger Offline
Loc: Midwest USA
I need some 99% pure or better Isopropyl Alcohol, but only about 10ml. It's to mix up a diluted bottle of Stabilant 22. I have a bottle of Stabilant 22 concentrate that I need to cut with the Isopropyl. The maker of Stabilant says to only cut it with 99% Isopropyl or pure Ethanol.
http://www.stabilant.com/sizes.html
You can buy large bottle of Isopropyl but they're like $25 and I'll never need more than the 10ml in forever.
What industries use 99% pure Isopropyl, so maybe I can go begging locally. Would a formulating Apothecary have the stuff?
Aside from that where could I find same amt of pure ethanol, short of building my own corn still and making moonshine?
'09 Subaru Forester ...................(QSED DEXOS1 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
#4516169 - 09/14/17 01:55 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
Bgallagher Offline
Loc: Boston, MA
you can get 91% easily at a drug store. Perhaps a Sally beauty store? Question, what is this for?
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4516173 - 09/14/17 02:04 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
LoneRanger Offline
Loc: Midwest USA
I know. But 91% won't work, needs to be 99% or better. It's for diluting Stabilant 22 concentrate, as mentioned in the post. Stabilant is a proven electrical connection conduction enhancer. The Isopropyl serves as a carrier to get the stabilant 22 into the connection, then evaporates leaving only the stabilant 22.
#4516176 - 09/14/17 02:06 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
nthach Offline
Loc: California
Do you have a biodiesel shop(not station) or a homebrewing shop nearby? The biodiesel shop might have anhydrous IPA or methanol in droppers, the homebrewing shop might have IPA or pure ethanol as a test reagent.
Also, if you live in a state where 190-proof vodka is legal, you can buy Everclear or Crystal Clear. It won't go above 91-95% pure, all alcohols will form azeotropes with water.
#4516182 - 09/14/17 02:16 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
A college chemistry lab or a college biology lab would probably have it. A research chem lab at a major hospital would have it.
In college biology we used pure alcohol to separate DNA from strawberries.
Edited by JimPghPA (09/14/17 02:17 PM)
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#4516183 - 09/14/17 02:17 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
MichiganMadMan Offline
Loc: SE Michigan
So do you need "Pure" ethanol or can you deal with denatured stuff (I believe they toss in some methanol to get it to full strength). If so, you'll trip over it at Home Depot, Lowes, Menards, Walmart in the painting section.
I think for the intended purpose, having some methanol mixed it won't cause problems. It sounds like you just need an easily evaporating carrier solvent.
2015 Chevrolet Impala
2008 Subaru Impreza STI
2004 Suzuki Hayabusa
1987 Honda VFR700F2
2011 Jonsered 2188 Chainsaw-The Judge.
#4516200 - 09/14/17 02:43 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
DdDd Offline
Loc: NY
If you're doing what I think you're doing, personally I wouldn't dirk around with the factory electrical connectors on a brand new bike. I had some EFI bikes in my fleet that are going into over ten years. No problems and they get washed with water. Fixing things that work... Now there's an idea!
Denatured ethanol usually has bitterants added. Whether they promote corrosion is anyone's guess.
Good old fashioned dielectric grease never hurt anybody. Upgraded the panel service in my house and they used tons. I've used it successfully on wet connections. Although technically an insulator the contacts break through and the grease seals off the metal pins.
If you read on the internet everything will break unless you use product X. In reality you can put her away wet and use the cheapest oil and still do 100k miles.
#4516207 - 09/14/17 03:03 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
ZeeOSix Offline
Loc: PNW
The grocery stores and places like Walmart & Walgreen's use to sell 99% isopropyl alcohol, but I never see it anymore. Seems the 91% is as pure as you can get over the counter anymore. I just looked on Amazon and you can get it, but it's not cheap like it use to be in the local stores.
#4516208 - 09/14/17 03:05 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
Langanobob Offline
Loc: Reno, Nevada
Stabilant has a phone number on their website. They can probably provide some suggestions.
#4516244 - 09/14/17 03:51 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
earlyre Offline
Loc: Lima, Ohio, USA
ummm...
According to their SDS Iso-HEET(the red Bottle) is 98.5% IPA. with the other 1.5% a blend of "proprietary" injector cleaners.
https://public.sitehawk.com/viewpdf.aspx?MaterialID=1576821&facilityID=1571&UseCatalog=True
regular HEET(yellow bottle) is 100% methanol. again,this is according to the company's own SDS.
https://public.sitehawk.com/viewpdf.aspx?MaterialID=1523113&facilityID=1571&UseCatalog=True
Edited by earlyre (09/14/17 03:53 PM)
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
#4516258 - 09/14/17 04:00 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
Rhymingmechanic Offline
Loc: VA
Would Deoxit do what you're trying to do with Stabilant?
Isopropyl 99% used to be sold as film cleaner. I got some for a B&W photo class, around the turn of the century, from a drugstore that had a full-on photography department. Theirs was packaged in cough syrup bottles, which they obviously filled from a larger container.
Maybe a pharmacy near you would stock it behind the counter, just not pre-packaged on the shelves. Otherwise, you might look around for a place that still sells film photography and darkroom supplies.
#4516277 - 09/14/17 04:15 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
earlyre Offline
and if someone says they have some they bought a long time ago, and would you like some? etc...pass
the reason IPA has an expiration date, is because due to oxidation, it eventually turns into acetone.
Mine:
Mine to Maintain:
#4516294 - 09/14/17 04:34 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: LoneRanger]
slug_bug Offline
Loc: Michigan
2016 Miata 2.0l (12k)
2013 Fusion 2.5l(78k)
2013 Focus(56K)
2010 Linc MKX 3.5l(88k)
2007 Dodge Caravan 3.8l(177k)
2003 Merc. Mountaineer 4.6l(114k)
#4516299 - 09/14/17 04:43 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: DdDd]
LoneRanger Offline
Loc: Midwest USA
Two older laptops I'm working on that I think will benefit from it, plus the HDMI connections for my OTA HD antenna. It is most used in A/V applications. Had the concentrate for a while, never did anything with it. Has an empty 10ml bottle to fill with the mixture, thought I might do that.
#4516301 - 09/14/17 04:45 PM Re: Source for 5 - 10ml of 99% Isopropyl Alcohol? [Re: Rhymingmechanic]
LoneRanger Offline
Loc: Midwest USA
I have Deoxit, in the pen style dispenser. I got the stabilant quite a while back as an upgrade from DeOxit but never really used it because I got the concentrate like a dumb arse instead of the pre-mix.
Page 1 of 2 1 2 >
