'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
34 registered members (Bailes1992, ChrisD46, ArrestMeRedZ, ctechbob, billt460, Dave9, 2 invisible), 551 guests, and 56 spiders.
Topics286,049
Posts4,901,475
Members67,551
Most Online2,967
Mar 10th, 2019
Engine break in and new Rotella bottle #4516101
09/14/17 12:17 PM
09/14/17 12:17 PM
Iowa
RedRocketZ28 Offline OP
Iowa
Hello all, I own a 2001 Z28 Camaro that was a stock bottom end LQ4 6.0 with a borg warner billet S480 turbo strapped to it. I had the engine in the car for over 4 years and tore it down this year to have some forged rods and pistons put in it.
I am getting ready for the first start up and went to buy some oil for it. I was going to continue to use the Rotella 15w-40 that was in the stock bottom end motor but noticed that the bottle had changed. Is there anything different about this oil now and can I continue to use it? I did end up buying some SuperTech 10w-40 to break the engine in on. Will this work ok for that? I know all about the racing break in oils and can't justify the price of them and my engine builder said any dino oil will work for break in.
Should I switch to something else after break in? If so, what would you all suggest for this combo that will make 8-900 rwhp? The car will be driven a lot, raced a lot, and the oil will get changed a lot.
Thanks for the help! Video of the car below.
https://www.youtube.com/watch?v=KcQpb5My474
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516114
09/14/17 12:38 PM
09/14/17 12:38 PM
Plano, TX
dparm Offline
dparm  Offline
Plano, TX
Hi there, what recommendation does the engine builder recommend? Do you have any data from them on oil pressure requirements?
2017 Chevrolet Corvette Grand Sport
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516119
09/14/17 12:45 PM
09/14/17 12:45 PM
Iowa
Iowa
He said I could continue to use the Rotella I had been using, but that was before I noticed the bottle change.
No oil pressure requirements. I have a high volume pump though and oil pressure was always around 60 psi on a cold start and 50 or so warm. I am not sure on the new bearing clearances but should be somewhat on the loose side due to boost.
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516127
09/14/17 12:51 PM
09/14/17 12:51 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
The Rotella would be superior to the SuperTech for the break in process.
Gas/diesel oils are going through a transition right now.
Rotella seems to be the only one that has all the previous additive levels. The others seem to be lowering certain additive levels to comply with SN gas ratings. Rotella is no longer rated for use in gas engines, officially. But they will tell you its fine, and as will most everyone on this board.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Engine break in and new Rotella bottle [Re: bubbatime] #4516143
09/14/17 01:18 PM
09/14/17 01:18 PM
New England
Virtus_Probi Offline
New England
XOM pulled a switcheroo on me with an gas/diesel oil that hasn't even been changed recently, M1 5W30 ESP is rated for gasoline engines according to their website but customer service told me the product would not be covered by their warranty if I used it in my GDIT car. WTH?!?!?
Shell has been saying for a long time that T6 5W30 would be their gas/diesel fleet oil, but has anybody actually seen that for sale anywhere?
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516150
09/14/17 01:29 PM
09/14/17 01:29 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Might be better off with a 4 stroke marine 25w40. Mercruiser or equivalent.
SShhhh! Its a performance oil secret!
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516181
09/14/17 02:13 PM
09/14/17 02:13 PM
Iowa
Iowa
Good info. I won't keep the SuperTech in it for very long and switch back to Rotella since it worked so well previously.
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516185
09/14/17 02:18 PM
09/14/17 02:18 PM
MD
AirgunSavant Offline
MD
I'm no ST fan because I got some bad oil once. But I had to break in an engine and used the conventional ST 10w40 and
had no issues with it. Problem is once you get a bad product it sours you but in this area the ST 10w40 is as good as any for break in or OPE use.
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516296
09/14/17 04:35 PM
09/14/17 04:35 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
According to shell they have not changed the formulation but have dropped the SM for T4
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Engine break in and new Rotella bottle [Re: AirgunSavant] #4516300
09/14/17 04:44 PM
09/14/17 04:44 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Hi Jim smile
So, that's why you use Magnatec smile
Re: Engine break in and new Rotella bottle [Re: RedRocketZ28] #4516396
09/14/17 06:45 PM
09/14/17 06:45 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
M1 10w-30.
2015 Ford F150 2.7
2018 Ford F350 6.2
