Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
90 registered members (BamaE92, ARCOgraphite, billt460, Bailes1992, andyd, 14 invisible), 1,752 guests, and 67 spiders.
Topics286,446
Posts4,908,449
Members67,626
Most Online2,967
Mar 10th, 2019
M1 5W30 AP vs M1 5W30 #4515917
09/14/17 09:12 AM
09/14/17 09:12 AM
New England
Virtus_Probi Offline OP
New England
Small but interesting (to me) point I noticed about the AP 5W30 compared to M1 5W30...
AP 5W30 is quite a bit thicker than the standard product at 100C (roughly where my oil temp will sit once it is warmed up), 11.7 cSt compared to 11.0. The AP is actually not that far below M1 5W30 ESP at 12.1 cSt at 100C.
But, take it up to 150C for HTHS and the AP is 3.0 mPa*s while standard M1 5W30 is 3.1. I don't know why different units are used to report HTHS (density related?), but I did read that mPa*s is numerically equivalent to cP. M1 5W30 ESP kills both of these with a 3.58 HTHS.
I know that what's being measured is not quite the same in the two tests, but the suggestion that the AP's viscosity is falling off faster with temp than that of the standard M1 surprised me a bit. I don't know if this might suggest something about the composition of the oil to somebody in the know?
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: M1 5W30 AP vs M1 5W30 [Re: Virtus_Probi] #4516053
09/14/17 11:21 AM
09/14/17 11:21 AM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
More important - how many mile into the OC and how is the engine liking it? I have found LL oils to take 2-3000 miles before the DP settles down and engine smooths out for the duration.
Usually a lower HTHS would mean less oil and more VM - not what you would expect in a LL. At least an ACEA A3,B4 LL
Have you read anything about Xom "magic" DP for this oil you would share.
I think I missed a middle AP thread a while back.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: M1 5W30 AP vs M1 5W30 [Re: Virtus_Probi] #4516118
09/14/17 12:44 PM
09/14/17 12:44 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Just because the oil lasts longer doesn't mean it will protect better.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: M1 5W30 AP vs M1 5W30 [Re: ARCOgraphite] #4516139
09/14/17 01:08 PM
09/14/17 01:08 PM
New England
New England
Think I have about 300-400 miles on it and nothing much really jumps out about it compared to the 5W30 ESP it replaced. Oil temps still run a bit higher than I noted on M1 5W30 vanilla/EP as they did with the ESP and I suspect my gas mileage also remains slightly depressed. I was expecting to see lower oil temps after dropping the ESP, at least until I noticed how thick the AP is at 100C.
I bought this oil out of rabid curiosity, because it had a dexos1 Gen 2 license, and because there was a $10 WM gift card offer to go along with the XOM $12 rebate. I wasn't expecting anything miraculous or horrible to happen and my car hasn't changed its stripes yet. This is an easy OCI for my car, the chance of seeing real heat is pretty low and the oil will be out before the depths of winter. Still thinking about a 0W30 for my next change if a certain one I am dreaming about shows up on the market.
Last Change;
M1 0W30 AFE d1G2
Re: M1 5W30 AP vs M1 5W30 [Re: Virtus_Probi] #4517077
09/15/17 01:29 PM
09/15/17 01:29 PM
N.H, U.S.A.
N.H, U.S.A.
Thanks. You wont run this through till early spring of 2018?
Could that special oil be ENEOS SUSTINA?
probably not ...
I recall when we had that wonderful NA EJ253 on our 2009 it would love some Rotella Triple protect 10-w30 with a bottle of Shell Formula 5w30 to slick it up a tad.
All dino and all fantastic. EJ253 are easy on oil, roller rockers, no pushrods or shims or buckets, no timing CHAINS, Super Short stroke, Moly coated piston skirts. Fuel metering on the TB. Just that funky PCV system.
Re: M1 5W30 AP vs M1 5W30 [Re: Virtus_Probi] #4517093
09/15/17 01:50 PM
09/15/17 01:50 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
For 5W-30 oils out of the M1 5W-30, 5W-30 EP, 5W-30 AP, 0W-30 AFE, and 5W-30 HM, spec wise,
I am liking the 10W-30 HM smile
https://www.mobil.com/English-US/Passenger-Vehicle-Lube/pds/NAXXMobil-1-High-Mileage-Oils
