Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
76 registered members (2010Civic, ArrestMeRedZ, Al, 2009Edge, 53' Stude, AndyB, 7 invisible), 1,281 guests, and 41 spiders.
Topics290,929
Posts4,852,633
Members66,055
Most Online3,590
Jan 24th, 2017
Toulene and ATF mix ratio #4515907
09/14/17 08:53 AM
09/14/17 08:53 AM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Hi,
I currently own a Mini Cooper S (2011) and I am experiencing knock (confirmed by logging). Both fuel quality and octane are horrible here. There is only one type of gasoline available from the pump. Which is supposedly 84 Mon/ 95 Ron (89,5 AKI?)
I had been using Toluene with good results. BUT I have been told to add ATF (MMO not available here) not to damage my engine.
1) Is it necessary to add lubricant if not using more than %10 of toluene? For example: 45 liters of petrol + 5 liters of toulene.
2) If it is necessary or good practice will any kind of ATF do? Or should I get a specific type?
3) Will using this formula damage my catalytic converter or O2 sensors?
4) What is the optimal ratio of ATF to Toluene?
5) How much will ATF degrade the octane level I am trying to enhance in the first place?
Many Thanks
Re: Toulene and ATF mix ratio [Re: Floydian] #4515963
09/14/17 10:01 AM
09/14/17 10:01 AM
New England
Virtus_Probi Offline
New England
Your gasoline probably already contains some toluene, but I'm not sure if there's a big worry about adding more. I would guess the issue would be with diluting whatever additives the gas already has in it?
Can you get Lucas Fuel Treatment in your location? It has a poor reputation as a fuel injector cleaner here, but I believe it has some reasonable lubricating properties and is also not too expensive here in larger quantities (gallons are available at some US Walmarts).
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Toulene and ATF mix ratio [Re: Floydian] #4515966
09/14/17 10:02 AM
09/14/17 10:02 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
You have to have something wacky going on. Needing to add toluene just to keep the car running cannot be normal.
too many cars and oil combinations to list in 150 characters or less
Re: Toulene and ATF mix ratio [Re: Floydian] #4515995
09/14/17 10:29 AM
09/14/17 10:29 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Is 2 stroke mix oil available?
Thick oil is better grin2
Re: Toulene and ATF mix ratio [Re: Virtus_Probi] #4516028
09/14/17 10:57 AM
09/14/17 10:57 AM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
I don't have access to Lucas Fuel Treatment at my location.
Re: Toulene and ATF mix ratio [Re: L_Sludger] #4516031
09/14/17 11:00 AM
09/14/17 11:00 AM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
The car does run without a CEL and decent mileage but with reduced performance and pinging between 1250-2100 rpm at high load situations (for example climbing a hill, car is auto btw and likes to upshift as soon as possible)
Re: Toulene and ATF mix ratio [Re: andyd] #4516032
09/14/17 11:01 AM
09/14/17 11:01 AM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Yes it is.
Re: Toulene and ATF mix ratio [Re: Floydian] #4516062
09/14/17 11:33 AM
09/14/17 11:33 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
oil will reduce the octane rating.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Toulene and ATF mix ratio [Re: SHOZ] #4516142
09/14/17 01:14 PM
09/14/17 01:14 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
The toluene should counter that grin2
Re: Toulene and ATF mix ratio [Re: Floydian] #4516247
09/14/17 03:53 PM
09/14/17 03:53 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Is your ignition timing setted correctly?
Do you have a timing chain or a belt? If...is your belt setted correctly?
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Toulene and ATF mix ratio [Re: SHOZ] #4516304
09/14/17 04:49 PM
09/14/17 04:49 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Yes, but how much?
Re: Toulene and ATF mix ratio [Re: Kamele0N] #4516306
09/14/17 04:51 PM
09/14/17 04:51 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Yes and Yes
Re: Toulene and ATF mix ratio [Re: Floydian] #4516314
09/14/17 05:00 PM
09/14/17 05:00 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Yes, but how much?
Don't know but I would just use the toluene. I use to use Lacquer Thinner. It was 50/50 Toluene and Xylene.
Re: Toulene and ATF mix ratio [Re: SHOZ] #4516322
09/14/17 05:14 PM
09/14/17 05:14 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Yes, but how much?
But wouldn't using toluene by itself increase valve and upper bore wear?
Re: Toulene and ATF mix ratio [Re: Floydian] #4516327
09/14/17 05:20 PM
09/14/17 05:20 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Toluene is up to 40% of the gasoline make up as is. Valve ware is almost no existent anymore as far as i know due to the hardened seats used because of the unleaded fuel.
