Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
71 registered members (77GrandPrix, Ag76, 69Torino, Alfred_B, alcyon, 8 invisible), 1,383 guests, and 53 spiders.
Topics306,271
Posts5,289,369
Members71,616
Amsoil ADN 10w30 #4515783 09/14/17 05:51 AM
O
ofelas Offline OP
O
Morning.
Who has tried Amsoil ADN 10w30, and how would it compare to ACD on a year round light duty 5.9 Cummins 12v ?
-35c to 45c, mixed city/hwy, no towing, occasionally haul the odd 1600lb-2000lb drivetrain.
Thanks.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Amsoil ADN 10w30 [Re: ofelas] #4525686 09/25/17 11:16 AM
spiderbypass Offline
Have not tried in but on paper looks robust especially with regards to noack. Most 10w30 heavy duty oils have noack between 10-12. Amsoil adn has noack of 4.5 according to spec sheet which is suggests excellent thermal stability.
Insecurity with overcompensation are the root of evil deeds.
Re: Amsoil ADN 10w30 [Re: ofelas] #4536224 10/07/17 01:12 PM
T
TiredTrucker Offline
T
ADN should be a great oil. Most of the 10w30 offerings by all the oil companies are pretty darn good. I have become quite fond of 10w30 HDEO. If 10w30 works fine in a 2000 Detroit 60 that is a factory reman with over 700,000 miles into its second life, and typically has to move around gross weights of 75,000+ lbs, and uses about 1-2 qts of oil (out of the 10 gal full sump) in 20K to 22.5K mile oil changes, it should be just fine for the OP's use.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Amsoil ADN 10w30 [Re: ofelas] #4616319 12/28/17 05:00 AM
O
ofelas Offline OP
O
Thanks; any advantages (aside from price) to using the ADN rather than the ACD ?
Re: Amsoil ADN 10w30 [Re: ofelas] #5390150 03/31/20 12:15 PM
P
Powerstroke Offline
P
I am currently using the Amsoil ADN 10w30. On paper it does look incredibly stout. I will run a UOA in a couple more thousand miles. I used it all winter up here in Minnesota, 0 starting issues.
'07 F-250 6.0 Powerstroke Diesel, 5" turbo back exhaust, Delvac 1 ESP 5w30 synthetic oil, Delo ELC coolant, ARP's, EGR delete, detroit lockers
Re: Amsoil ADN 10w30 [Re: ofelas] #5390852 04/01/20 11:09 AM
I agree have noticed that Amsoil’s “lower tier” oils have the best noack numbers for nearly any oil on here including redline. If you hid the names of the oils and just put the data-I would likely have guessed the second tier oils were the signature series.
Re: Amsoil ADN 10w30 [Re: ofelas] #5409098 04/20/20 10:01 PM
H
HighwayRanger Offline
H
After buying a 2020 Ram 3500 dually with the H.O. Cummins TD, I was surprised to see a 15K oil change recommendation using 10w30 oil in the manual. I am thinking of using the Amsoil ADN, as there are few choices in that weight. I’m not interested in doing oil analysis in order to stretch the interval out to 15k (an interval I would not normally be comfortable with.)
We are full time RVers with a 20k fifth wheel and this Ram is our daily driver/hauler. I am thinking of shooting for 10k OCIs, knowing that I can go over without any concerns.
Are there any good options to the ADN in this weight?
Thanks
2020 Ram 3500 Laramie LB, DRW, 4x4, H.O. Cummins TD, AISIN, 3.73
2016 DRV Mobile Suite Fifth Wheel
(2) Honda eu2000i Generators
Re: Amsoil ADN 10w30 [Re: HighwayRanger] #5409170 04/20/20 11:55 PM
CleverUserName Offline
Thanks
Biosyn HD 10w30. I wouldn’t exceed 10k without oil analysis though.
Re: Amsoil ADN 10w30 [Re: ofelas] #5409287 04/21/20 07:33 AM
B
BoiseRob Offline
B
2007 Chevrolet Silverado 2500HD LBZ Duramax
2016 Jeep Grand Cherokee Ecodiesel
Re: Amsoil ADN 10w30 [Re: ofelas] #5409428 04/21/20 11:03 AM
B
BrianF Offline
B
I ran petrocanada duron semisynthetic 10w30 year around up here. Lots of idle time, cold starts, light and heavy towing. The oil held up absolutely superb in the full 15,000 mile index. I only did 2 tests this far but both came back almost identical. The oil had little care for one with fuel dilution, the other with 100 idle hours and piles of cold starts and short trips.
Have zero fear of running a 30 weight for a full index while towing.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
