One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
39 registered (bbhero, BigJakeChevy, Atesz792, AVB, 2strokeNorthstar, Aero540T, 3 invisible), 981 Guests and 42 Spiders online.
65265 Members
67 Forums
285570 Topics
#4515755 - 09/14/17 04:26 AM How to reset BIOS password?
berniedd Offline
Loc: A Warm place to live in
I was given a 10 yr old Acer Aspire 4310 laptop yesterday. Had Win7 but boot process hangs and won't complete. Prob bad hard drive sectors. Can't repair the OS as it is password protected. Shucks, I'll just install a Linux distro instead. But I can't change the boot sequence to make the DVDROM the first boot device as the BIOS is also password locked by the previous owner, whose whereabouts no one knows. Any free/cheap way to get around this? Is there a CMOS battery in there I can remove to erase the BIOS settings, like we used to do in the old days for desktops? Anybody know if there is a master password Acer used to free locked machines? Thanks for any help, guys.
#4515800 - 09/14/17 06:24 AM Re: How to reset BIOS password? [Re: berniedd]
danez_yoda Offline
Loc: texas
There might be a clear cmos jumper on the mobo. Most recent cmos passwors would be stored in flash nowadays so removing the battery might not work but worth a try.
#4515811 - 09/14/17 06:36 AM Re: How to reset BIOS password? [Re: berniedd]
BigD1 Offline
Loc: NC
Either jumper it, or pull the battery. I would go ahead, and put a new battery in it while I was at it.
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4515858 - 09/14/17 07:44 AM Re: How to reset BIOS password? [Re: berniedd]
OVERKILL Offline
Loc: Ontario, Canada
Generally there will be a battery on a lead that you can unplug from the board, may require some disassembly to get to. The F12 boot menu is disabled i assume?
2016 Durango Limited
2016 Grand Cherokee SRT
#4515908 - 09/14/17 08:59 AM Re: How to reset BIOS password? [Re: berniedd]
SHOZ Offline
Loc: Illinois
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4515946 - 09/14/17 09:48 AM Re: How to reset BIOS password? [Re: berniedd]
Ethan1 Offline
Loc: 'murica
Did you try booting from USB? USB might be above HDD on the list.
#4515992 - 09/14/17 10:27 AM Re: How to reset BIOS password? [Re: berniedd]
i_hate_autofraud Offline
Loc: Canada
BIOS passwords often lock the HDD as well, at least in my case, so I move the HDD to another
computer and it's still locked! That's OK as long as I don't forget! smile
#4516102 - 09/14/17 12:18 PM Re: How to reset BIOS password? [Re: berniedd]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
Some machines can have the BIOS password removed, some cannot. I just dealt with this very issue on a (very nice 17") Toshiba laptop. The only way to remove it is to send the laptop to Toshiba and include $200.
Booting from another drive, or replacing the HD won't work. You can change the BIOS settings (boot sequence, etc) but that is ineffective as far as booting the machine goes. The BIOS password lock loads before the low-level boot partition.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4516429 - 09/14/17 07:20 PM Re: How to reset BIOS password? [Re: OVERKILL]
uc50ic4more Offline
Loc: Windsor, Ontario, Canada
Aren't those sometimes also cheapy 1032 watch batteries that can be trivially popped out? I swear I did that once years ago in this exact circumstance.
#4516478 - 09/14/17 08:04 PM Re: How to reset BIOS password? [Re: uc50ic4more]
OVERKILL Offline
Some laptops have them soldered to leads that plug into the board, but essentially the same concept.
#4516481 - 09/14/17 08:08 PM Re: How to reset BIOS password? [Re: berniedd]
JustinH Offline
Loc: Texas
Well I support laptops with dell pro support.
We have had one of our techs put the wrong bios password on a laptop.
Dell pro support generated a code on the bios and gave us a key to reset the bios password, so there is some kind of an algorithm at work at least for dells.
'11 Hyundai Sonata GLS
'11 Scion XB
#4516686 - 09/15/17 01:12 AM Re: How to reset BIOS password? [Re: berniedd]
punisher Offline
Loc: snowblind in TX
I remembered I have something like that bookmarked.... https://bios-pw.org/
EDIT: "Code" refers to the lock code when you hit your 3 strikes.
Edited by punisher (09/15/17 01:14 AM)
#4518177 - 09/16/17 09:04 PM Re: How to reset BIOS password? [Re: berniedd]
Subdued Online   happy
Loc: Youngstown, NY
laptops are generally pretty locked down for this sort of thing, even 10 years ago.
replacing the motherboard and hard drive are sometimes the only option.
Not sure about acer, though.
2015 Jeep Cherokee 18k
2008 Chrysler Town & Country Touring 149k
2007 Toyota Yaris S 170k
#4518462 - 09/17/17 10:12 AM Re: How to reset BIOS password? [Re: Subdued]
OVERKILL Offline
Generally BUSINESS laptops are more locked-down in that respect. I wouldn't say laptops in general. That's been my experience anyways.
#4536942 - 10/08/17 09:40 AM Re: How to reset BIOS password? [Re: berniedd]
berniedd Offline
punisher, that was spot on. I was able to reset the BIOS (by Phoenix) after I entered the error code the screen gave. Unfortunately, after a few minutes, the laptop would die and turn off. If I power back on, it would die again and turn off after a few seconds. No wonder it was free.
