better day
by mx5miata
13 minutes 28 seconds ago
BRAVO to Officer Wheeles......
by Sayjac
22 minutes 27 seconds ago
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
How much is too much?
by Sealbilly
Yesterday at 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
Yesterday at 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
Yesterday at 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
Yesterday at 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
Yesterday at 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
Yesterday at 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
Yesterday at 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
Yesterday at 06:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
43 registered (BoiseBound, bradepb, bbhero, das_peikko, CleverUserName, Char Baby, 7 invisible), 872 Guests and 38 Spiders online.
65265 Members
67 Forums
285578 Topics
#4515623 - 09/13/17 09:28 PM Kubota oil change questions
jongies3 Offline
Loc: MT
I have a Kubota LA350A with a B2150 diesel engine in it. Trying to find out what the oil capacity is and filter number and came here to see if anyone knew anything about them. I'm unsure of the year on it, the sticker has long since faded away and there's no owners manual. Every google search I've done only gives me coolant and transmission capacity and says nothing about the engine oil. As I understand it, this model was made from 1988-1996 so I don't know if the oil capacity would've stated the same all that time or not.
What oil should it get and how many hours should it be changed? Is regular Rotella or synthetic Rotella okay? Thinking about going with the synthetic for use in wintertime to help it out with cold starts. Oil filter recommendations are welcome too as long as nobody says Purolator I'm open to suggestions there. Thank you in advance!
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM TG-3600 filter
1996 Ford Contour 2.5 V6 QSGB 5W-30, MC FL-500S filter
#4515663 - 09/13/17 10:11 PM Re: Kubota oil change questions [Re: jongies3]
mattwithcats Offline
Loc: Virginia
Kubota # HH150-32094
Converts to Fram PH3593A, TG3593A, or XG3593A
Lots of folks here like the TG, or ToughGuard. Good filter, good price..
Oil
Shell Rotella T5, in 10W-30, semi-synthetic, good value choice
Or
Shell T6, in 5W-40, full synthetic,
Looks like a 4 quart sump...
Careful, there may be two drain plugs, due to the hump in the middle...
Edited by mattwithcats (09/13/17 10:12 PM)
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4515677 - 09/13/17 10:37 PM Re: Kubota oil change questions [Re: jongies3]
doitmyself Offline
Loc: MI
You have a model B2150 tractor with a LA350 loader. Find the actual Serial identification tag on the tractor to find out which model you have (B2150, B2150DT, B2150HSD, B2150HST). Is it hydrostatic or gear drive?
I had a B2150 at my workplace and I used Wix (NAPA Gold)filters). My model was hydrostatic and I used the OEM filter for that, because the WIX just didn't seem correct.
10W30 was specified for ours. Any HDEO brand should work. I cannot remember the service intervals. You should be able to find an owners manual somewhere. Sucks that Kubota doesn't offer them for free at their website.
Dig around on this page to see examples of the i.d. tag: https://www.tractorhouse.com/listings/farm-equipment/for-sale/list/?MDLGrp=b2150&Manu=kubota (I couldn't get the pics to download here)
It could be white, gray, or metallic: This one shows B2150HSD EDIT...oops, I see that you stated the sticker is worn off!
Finally, TractorByNet compact tractor forum has some great guys that might be able to help locate an owners manual.
#4515758 - 09/14/17 04:45 AM Re: Kubota oil change questions [Re: jongies3]
dlundblad Offline
Loc: Indiana
Dad used to have one of these when I was a kid. One set if turfs and a set of ags. I remember helping him changing them out every spring and fall.
I run the WIX 51334 (Fram xx9688/3593a). If you don't have room, they have another small application filter that is sized like the Fram xx6607. When I used to buy Kubota filters, the dealer gave me either or interchangeably.
I run M1 5w40 in both diesel Kubotas specifying 10w30. 10w30 or even a mineral 15w40 would work great too. I imagine a 50 hour or yearly change would suffice.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4516595 - 09/14/17 09:55 PM Re: Kubota oil change questions [Re: dlundblad]
jongies3 Offline
Loc: MT
Think I will have to go with the standard size filter because it sits right up against the removable panel on the side.
Did not know about the two drain plugs, only saw one when I was under there looking around but I'll double check to be sure. Thanks for the replies, everyone!
#4516728 - 09/15/17 04:57 AM Re: Kubota oil change questions [Re: jongies3]
dlundblad Offline
Loc: Indiana
I don't think something that small will have 2 drain plugs, but Matt did good mentioning it.
#4519829 - 09/18/17 10:13 PM Re: Kubota oil change questions [Re: doitmyself]
jongies3 Offline
Loc: MT
Hydrostatic is another word for automatic I assume? If so, that's what I have, you don't have to put it in gear to move, just push down on the accelerator to move forward or rearward.
#4521854 - 09/21/17 04:58 AM Re: Kubota oil change questions [Re: jongies3]
dlundblad Offline
Loc: Indiana
Yes, but it uses a pump to push fluid through pistons to get you to move. You should be able to select low, med or high gear and as you said, you push the petal down in the direction you want to go.
You would know if it was gear driven since the stick would be right between your legs. You would have to select every gear too. Good for say plowing a field, but not so much for mowing a yard with frequent stops. You lose a little bit of pulling power with a hydro, but that's about it.
Edited by dlundblad (09/21/17 05:00 AM)
#4695465 - 03/15/18 09:40 AM Re: Kubota oil change questions [Re: jongies3]
atfadapter Offline
Loc: China
too old ...
