4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
80 registered members (ad_infinitum, 4WD, 2010Civic, Agnosto, AdditiveOCD, 7 invisible), 1,438 guests, and 68 spiders.
Topics286,042
Posts4,901,388
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
2017 Ford F-150 2.7 Ecoboost #4515120
09/13/17 12:25 PM
09/13/17 12:25 PM
Douglas County, Colorado
bigj_16 Offline OP
bigj_16  Offline OP
This is the UOA from my wife's 2017 F-150 2.7 Ecoboost. This was a dealer oil change done theoretically with Motorcraft 5W-30. 1,331 miles on oil. 3,281 miles on vehicle.
Please ignore the Unit/Location averages in the first section. These are not correct.
Re: 2017 Ford F-150 2.7 Ecoboost [Re: bigj_16] #4515130
09/13/17 12:32 PM
09/13/17 12:32 PM
KS
FordBroncoVWJeta Offline
KS
Why have you done 2 oil changes with 3200 miles on the truck?
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2001 Pontiac Sunfire 2.2
Re: 2017 Ford F-150 2.7 Ecoboost [Re: bigj_16] #4515131
09/13/17 12:33 PM
09/13/17 12:33 PM
bigj_16 Offline OP
bigj_16  Offline OP
Why not?
Re: 2017 Ford F-150 2.7 Ecoboost [Re: bigj_16] #4515137
09/13/17 12:40 PM
09/13/17 12:40 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
I am in the camp that subscribes to early OCs to dump wear metals from break-in so no complaints from me on that. What is up with the viscosity? Are you sure it was 5W-30?
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: 2017 Ford F-150 2.7 Ecoboost [Re: 2015_PSD] #4515142
09/13/17 12:44 PM
09/13/17 12:44 PM
bigj_16 Offline OP
bigj_16  Offline OP
That is the question, friendo. I don't know. The samples from both our trucks showed viscosity about the same (out of grade). So, I don't know if they put 5W-20 in, or it was 5W-30 sheared down. I will be getting results back from the 2016 today for an oil change with about 2800 miles on it. This is M1 EP 5W-30 that I put in myself smile
Re: 2017 Ford F-150 2.7 Ecoboost [Re: bigj_16] #4515145
09/13/17 12:47 PM
09/13/17 12:47 PM
bigj_16 Offline OP
bigj_16  Offline OP
Here's the 2016 at roughly about the same miles.
This a dealer change, theoretically Motorcraft 5W-30.
Re: 2017 Ford F-150 2.7 Ecoboost [Re: FordBroncoVWJeta] #4515160
09/13/17 12:59 PM
09/13/17 12:59 PM
Utah
CKN Offline
CKN  Offline
Utah
This is BITOG....money is flushed on here needlessly-that's why. That truck won't last longer than an owner following the factory recommended OCI.
The filters catches anything "left over" from the assembly.
Re: 2017 Ford F-150 2.7 Ecoboost [Re: CKN] #4515173
09/13/17 01:09 PM
09/13/17 01:09 PM
bigj_16 Offline OP
bigj_16  Offline OP
And how do you know that?
Re: 2017 Ford F-150 2.7 Ecoboost [Re: CKN] #4515176
09/13/17 01:15 PM
09/13/17 01:15 PM
Danh Offline
Danh  Offline
If that's really 5w-30 there's a ton of fuel dilution in the sump. And if that's the case anything resembling an extended drain interval isn't exactly "flushing money"...
Re: 2017 Ford F-150 2.7 Ecoboost [Re: Danh] #4515192
09/13/17 01:29 PM
09/13/17 01:29 PM
bigj_16 Offline OP
bigj_16  Offline OP
Even if it is 5W-20, over at PQIA, the visco of the virgin is 8.54, which means it is shearing/diluting pretty fast. This upcoming M1 EP sample is going to be the one I am really interested in. Unfortunately, it is 2800 miles of highway roadtrip (80-85 mph), mostly, rather than the combination of city/highway in these UOA's. Still, it should give an indicator of shear/dilution.
Re: 2017 Ford F-150 2.7 Ecoboost [Re: CKN] #4515201
09/13/17 01:37 PM
09/13/17 01:37 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
That is most certainly not true. We've found that our Ford vehicles last longer with more frequent OCI's and in particular, higher viscosity. With modular engines lasting over 900K miles using 10W-40 and 5K oci's.
Re: 2017 Ford F-150 2.7 Ecoboost [Re: bigj_16] #4515203
09/13/17 01:42 PM
09/13/17 01:42 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
That is a 5W-20 oil. Castrol and Valvoline syn oils gives better results on these engines.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2017 Ford F-150 2.7 Ecoboost [Re: Cujet] #4515207
09/13/17 01:45 PM
09/13/17 01:45 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I would tend to agree.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2017 Ford F-150 2.7 Ecoboost [Re: bigj_16] #4515208
09/13/17 01:45 PM
09/13/17 01:45 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
You may want to try another lab if you suspect fuel dilution. Unless something has changed at Blackstone, they cannot accurately measure fuel levels.
Re: 2017 Ford F-150 2.7 Ecoboost [Re: 2015_PSD] #4515213
09/13/17 01:49 PM
09/13/17 01:49 PM
bigj_16 Offline OP
bigj_16  Offline OP
Not discounting what you say(thanks!). However, it really doesn't matter if it is dilution or shearing. Either is typical of these engines, and in the end is essentially the same thing. A lowering of viscosity. You could make a point about gasoline being a poor lubricant smile
Page 1 of 5 1 2 5
