2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their cordless electric OPE?
by dlundblad. 09/25/18 04:21 PM
Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
102 registered members (2015_PSD, ABomb369, 2004tdigls, 2013ecof150, 53' Stude, Ag76, 12 invisible), 1,403 guests, and 32 spiders.
Topics291,010
Posts4,854,368
Members66,070
Most Online3,590
Jan 24th, 2017
2016 FLHTK, 7,600 Miles, Amsoil 20w-50 #4514788
09/13/17 05:13 AM
09/13/17 05:13 AM
Md, USA
montero1 Offline OP
montero1  Offline OP
Md, USA
Miles on oil 7,600
Miles on unit 8,600
Sample Date 9/5/17
Makeup oil 0
Oil and Filter both Amsoil - 20w-50 MC V-twin oil.
Silicon improved in this sample, as we expected it to. Copper increased just a little (68 vs. 66), and that wasn't quite the expected trend, though we're content to hold off calling it a problem for now. Most of this Copper is lingering wear-in, and it should wash out before too long. Other metals already look good, so this Harley is off to a fine start for the most part. The viscosity was a little thick, but we tend to see that quite a bit with Harleys, and we don't see it as a problem. The TBN was nice and strong at 4.9. Try 8,500 miles and we'll see how the Copper looks.
Aluminum 5
Chromium 1
Iron 17
Copper 68
Lead 2
Tin 1
Molybdenum 66
Nickel 0
Manganese 3
Silver 0
Titanium 0
Potassium 2
Boron 43
Silicon 17
Sodium 9
Calcium 2876
Magnesium 152
Phosphorous 991
Zinc 1246
Barium 1
SUS Viscosity at 210F 109.9
cst Viscosity at 100F 22.6
Flashpoint 405F
TBN 4.9
Water 0.0
Insolubles 0.2
First oil change was @ 1000 miles. I rode this to Sturgis, about 4,600 miles to end the OCI. I'm going to stick to no more than 5k from here on out. I only got 2 quarts out, and I suppose it will hold another 1/2 quart between the filter and crevices, but it only holds 3.5, so it must have consumed at least a quart in those 7600 miles (not horrible), but the dipstick never said to add a quart, and I checked it every day I was out to Sturgis. The Manual says not to add until you get to "add 1 quart". It seemed SO thick when I drained it, which was on an 85 degree day, and I had ridden it 2 hours, but let it sit for 2 hours. Shifted fine (for what that's worth in a Harley) the whole OCI, and no signs of it getting any hotter than normal.
While in Sturgis, I had a V&H Header and Pipe installed, and it has an FP3 tuner, on since about 3k.
In: Maxima Synthetic 20w50 V-Twin Full Synthetic, Baldwin B1413 Filter.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 V-Star 1300 Deluxe (Hers)
'13 VFR1200F
'16 Harley Electra Glide Limited
'18 GMC Canyon Denali (Hers)
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4514815
09/13/17 06:17 AM
09/13/17 06:17 AM
NY
DdDd Offline
DdDd  Offline
NY
Lol 8500 miles. What do they think this is a Toyota?
I change once a year or however many miles the manual says. Whichever comes first. With more than one bike it's once a year.
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4514979
09/13/17 10:11 AM
09/13/17 10:11 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
That's a LOT of highway riding to put on what is essentially a brand new bike isn't it? If there was oil loss then I would chalk it up to the engine not being fully broken in yet.
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4515788
09/14/17 06:06 AM
09/14/17 06:06 AM
Md, USA
montero1 Offline OP
montero1  Offline OP
Md, USA
Well, the break-in period was over when I took it on the trip....it had 4k on it.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 VFR1200F
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4517143
09/15/17 02:44 PM
09/15/17 02:44 PM
MINNESOTA
GRIMland Offline
GRIMland  Offline
MINNESOTA
Doesn't the oil cooler hold ~1/2 quart? That might explain some of the missing oil, along with the filter which you mentioned. The rest probably didn't drain out, which is common in these engines. I doubt you used much if any oil. Same oil in primary and trans?
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4517229
09/15/17 04:44 PM
09/15/17 04:44 PM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
My manual says to check the oil hot, after bike has sat 5 minutes for an accurate reading. Only getting 2 qts out of a 3.5 qt sump doesn't sound right to me. Could letting it cool down for 2hours before draining have an effect on not getting more oil out of the pan? I drain mine after sitting for about 10 minutes when changing the oil. There is some oil left in a Harley after draining, but 1.5 qts seems like quite a lot. Why did you decide to go to the Maxima for this run over the Amsoil?
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: gman2304] #4517393
09/15/17 08:49 PM
09/15/17 08:49 PM
Md, USA
montero1 Offline OP
montero1  Offline OP
Md, USA
Just found a good deal on the Maxima. I don't plan on riding the Harley a whole bunch, not long distance anyway. No more trips to Sturgis for me, and any other long trips will be on the Goldwing. Just no need to try and do long OCIs on the Harley.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 VFR1200F
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: GRIMland] #4517394
09/15/17 08:50 PM
09/15/17 08:50 PM
Md, USA
montero1 Offline OP
montero1  Offline OP
Md, USA
I used tranny and Primary specified oils, though I know you can run engine oil in all 3.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 VFR1200F
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4518319
09/17/17 05:32 AM
09/17/17 05:32 AM
Illinois
nocarb Offline
nocarb  Offline
Illinois
The wear metals should start dropping.
Nice upgrades, really cools things off and gives it a little more pep.
Will you be doing a UOA on Maxima?
I agree with gman on only getting 2 quarts on drain. Did you drain from plug with o-ring and magnet?
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: nocarb] #4518919
09/17/17 08:06 PM
09/17/17 08:06 PM
Md, USA
montero1 Offline OP
montero1  Offline OP
Md, USA
I used the right drain, trust me. Way different bike with the mods, should have come like this.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 VFR1200F
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: nocarb] #4518930
09/17/17 08:12 PM
09/17/17 08:12 PM
Md, USA
montero1 Offline OP
montero1  Offline OP
Md, USA
Yes, I will likely UOA the Maxima. The only time I usually don't do an analysis, is if I know the miles are very very low for the oci, or if I had an oil burner that I was constantly adding oil to.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 VFR1200F
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4518990
09/17/17 09:20 PM
09/17/17 09:20 PM
Illinois
nocarb Offline
nocarb  Offline
Illinois
I agree would save us all a bunch of money.
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4518994
09/17/17 09:22 PM
09/17/17 09:22 PM
Illinois
nocarb Offline
nocarb  Offline
Illinois
Great, I have mostly used Amsoil interested in different oil UOA.
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4549493
10/20/17 06:40 PM
10/20/17 06:40 PM
pa
benjy Offline
benjy  Offline
pa
if that were an M-8 i would say check the primary as some of those engines are "transferring" oil into it + HD has yet no solution, but they did change oil pump #'s so assuming they have updated pumps they are using on their warranty issues!!
Re: 2016 FLHTK, 7,600 Miles, Amsoil 20w-50 [Re: montero1] #4612763
12/24/17 08:52 AM
12/24/17 08:52 AM
Florida
RedVic Offline
RedVic  Offline
Florida
Miles on oil 7,600
Miles on unit 8,600
Sample Date 9/5/17
Makeup oil 0
Aluminum 5
Chromium 1
Iron 17
Copper 68
Lead 2
Tin 1
Molybdenum 66
Nickel 0
Manganese 3
Silver 0
Titanium 0
Potassium 2
Boron 43
Silicon 17
Sodium 9
Calcium 2876
Magnesium 152
Phosphorous 991
Zinc 1246
Barium 1
Flashpoint 405F
TBN 4.9
Water 0.0
Insolubles 0.2
This is my 2016 Harley Ultra Limited:
Engine has a Vance & Hines FP3 tuner, Vance & Hines Powerdual header, Rinehart mufflers and a Arlen Ness Big Sucker stage one intake.
Oil Type & Grade: Redline 20w-50 motorcycle oil
Comments: Wear metals look great for this first sample from your limited. Averages for this engine type are based on about 4,200 miles on the oil. You ran longer and got less metal in the oil-- that's great! Your engine is wearing with the best of them! The viscosity was a little think, but that hasn't hurt anything that we can see. We're not sure what causes it, but it's fairly common to see high viscosity in Harley engines. As far as we can tell, it's harmless. The TBN was quite strong at 5.0 (1.0 is low) so you should be fine with a longer interval. Try 6,500 miles. Nice!
Miles on oil: 5,222
Miles on unit: 25,001
Sample Date: 11/25/2017
Make up oil added: 0
Aluminum: 2
Chromium: 0
Iron: 8
Copper: 10
Lead: 0
Tin: 1
Molybdenum: 560
Nickel: 0
Manganese: 1
Silver: 1
Titanium: 0
Potassium: 1
Boron: 17
Silicon: 18
Sodium: 10
Calcium: 2695
Magnesium: 14
Phosphorus: 1901
Zinc: 2117
Barium: 1
SUS Viscosity @ 210 F: 109.0 Values: 75 - 99
cSt Viscosity @ 100 C: 22.45 Values: 14.3 - 20.4
Flashpoint in F: 415
Fuel %: <0.5
Antifreese %: 0
Water %: 0
Insolubles %: 0.2
TBN 5.0
