1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
35 registered members (citationxeleven, Cornershop, c502cid, Ag76, billt460, 4 invisible), 948 guests, and 27 spiders.
Topics296,903
Posts4,961,303
Members66,997
Most Online2,688
Jan 19th, 2019
Balancing weights, how many is too many? #4514755
09/13/17 12:56 AM
09/13/17 12:56 AM
california
wrcsixeight Offline OP
california
Recently, I had to buy 4 new tires on a roadtrip.
Cooper Discoverer AT3 30 x 9.5 x 15 Load range C.
Today, I noticed on one wheel, there is a lot of weights on the rim, both sides, in the same part of the rim. This rim is on the driver's side front at the moment. Obviously the New tire itself was way out of balance.
There is a slight vibration beginning about 55mph.
The tires have about 1700 miles on them since they were installed mostly 55mph+ highway miles.
I am several hundred miles away from the tire dealer( not a chain) and unlikely to be in that tiny town again anytime in the forseeable future.
How many weights are too many?
Is a sign of a badly made tire? Dangerous?
The other three New tires do not have very many or very large weights on them, just this one.
The weights on both sides of the rim say 200 100 and 25.
Same sizes and numbers on both sides of the rim. This can't be 11.5 oz of lead on each side so that those numbers can't be grams. I'll guess the weights if they are lead, justging by fishineg weights, total about 2 OZ on each side of th erim.
AnD to surprise exactly nobody, the Lug nuts on the fronts were severly overtorqued. My 220 LBs and a 18 inch breaker bar had to use about 98% of my strength to loosen the lugs. The Lug nuts threads were damaged, luckily the studs were not. On the rears 2 of the 5 on each rim were extremely overtorqued, the three remainders were undertorqued, I'll guess the tight ones were about 180+Ft LB, the looser ones about 65Ft/LB.
I installed all new lugs today using a torque wrench.
Should I just try and get this tire rebalanced or remounted and rebalanced or try and see if Cooper will do anything for me?
There is a red dot on the whitewall side of the tire( which is on the inside) but it does not align with the tire weights. DOT code is 1717 on the tire in question.
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514757
09/13/17 01:34 AM
09/13/17 01:34 AM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
I think first step would be to get the thing rebalanced. Call around a couple shops and see if any of them use a hunter "road force" balancer. It does a pretty good job of being able to correct for things like a wheel out of round. If you find someone who knows how to really work the machine, ask for a balance accuracy of <0.10oz. There are a few menus you can navigate through the machine to do so. Out of the box it'll round to the nearest .25oz as that's the smallest weight available but there are ways around it if the tech is well versed in operation of the machine
As to your wheel weight numbers, 200=2.00oz, 175=1.75oz, etc.
2oz per wheel falls pretty well average FWIW
Oh yeah and the weights should be made of a zinc or steel. Lead's been phased out for a while now
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514764
09/13/17 01:59 AM
09/13/17 01:59 AM
california
california
Thanks for the info.
There are 3 weights on the rim on each side in the same point on the radius. A 200 100 and a 25 on each side of the rim in the same point on the radius, for a total of 650.
6.5 OZ required to counterbalance this One tire?
It seems and look like an excessive amount of weight added. I assume the slight vibration I am feeling is from this tire. There is one other weight on the inside of the rim on this wheel, I think it is a 50 and about 90 degrees away from the 325.
The vibration at 55Mph did not become noticeable until about 750 miles after purchase. It is slight.
LA 318 Roller Cam
Pennzoil Platinum 10w-30 SN Plus
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514776
09/13/17 03:09 AM
09/13/17 03:09 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yes, have the tire(s) rebalanced.
I have heard(only heard) that there should be no more than 7 weights on a wheel. Now, does this mean only 7 oz? IDK!
What if they're 1/2 oz wgts? IDK that either.
CapriRacer, our tire guru may chime in.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514782
09/13/17 03:31 AM
09/13/17 03:31 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Yeah, definitely rebalance all the tires.
Not all tire techs are the same and some don't do a good job.
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514799
09/13/17 04:42 AM
09/13/17 04:42 AM
PA
copcarguy Offline
copcarguy  Offline
PA
+1 on finding a shop with a RoadForce balancer.
http://www.hunter.com/wheel-balancers/road-force-elite
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514851
09/13/17 06:13 AM
09/13/17 06:13 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Sometimes moving the tire 180 on the rim will help.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514852
09/13/17 06:16 AM
09/13/17 06:16 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Also, try rotating the tires BEFORE getting them rebalanced. If the problem is the tires, the vibration ought to move. If it doesn't move, then something else is vibrating and the only problem you have is how unattractive the amount of weights are.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514859
09/13/17 06:39 AM
09/13/17 06:39 AM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
my guess - bad tire. michelins seem to use small weights
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514872
09/13/17 06:51 AM
09/13/17 06:51 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
There is no limit. It takes what it takes.
Yellow dot = heaviest part of tire. Used to be you would put this by the valve stem but that doesn't work on alloys because the stem is where it looks best, not lightest.
Red dot = highest radial force variation. Match it up with the mark on the rim that is the low spot. Again, probably not marked but there could be a punch or sticker on the rim.
If it has both...red rules.
A RoadForce balancer can find these points on the tire and rim, just find a shop that knows how to do it.
Not all companies use both dots and it can vary by plant. My new Continental winter tires had no dots so I had to match mount with a RoadForce balancer from scratch.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514884
09/13/17 07:15 AM
09/13/17 07:15 AM
northern NY
Driz Offline
Driz  Offline
northern NY
You didn't by chance bend a rim did you? It doesn't take much sometime and it would be highly coincidental but.........
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514889
09/13/17 07:24 AM
09/13/17 07:24 AM
edwardh1 Offline
edwardh1  Offline
some places that have aa road force machine dont use it wjhen they balance your tires , cause its slower and takes more work. so ask if they use that feature on the machine
Re: Balancing weights, how many is too many? [Re: Chris142] #4514898
09/13/17 07:42 AM
09/13/17 07:42 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 this and a road force balance can make a world of difference. To answer your question there isn't really "too many" weights but that being said I would question the tire or the machine before lining your rim with weights
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4514935
09/13/17 08:19 AM
09/13/17 08:19 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I had a similar thread going back in July https://bobistheoilguy.com/forums/ubbthreads.php/topics/4466267/Re:_New_DTD_wheels_for_the_For#Post4466267. On my Subaru, I had as many as 18 stick-on and one clip on weight on one of my factory wheel/tires! Also needed a lot of weight to balance new Walmart Douglas tires on new Discount Tire Direct wheels. 2 months later, all is well. No vibs or weird wear.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Balancing weights, how many is too many? [Re: wrcsixeight] #4515105
09/13/17 11:06 AM
09/13/17 11:06 AM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
My record is 8 oz to balance a tire. Even then you could feel the imbalance of the tire.
The tire had an additional problem of shimmying side-to-side. This was a craigslist purchase. The tires were WalMart Wintermark tires. I'm guessing the set I bought was a customer return at one point for this reason.
