New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
120 registered members (14Accent, 4WD, 97f150, 28oz, 53' Stude, 12 invisible), 2,272 guests, and 30 spiders.
Topics296,645
Posts4,956,582
Members66,950
Most Online2,577
Jan 14th, 2019
What to do about small countershaft seal leak? #4514592
09/12/17 07:36 PM
09/12/17 07:36 PM
VA
uzun Offline OP
uzun  Offline OP
VA
Hi guys,
I own a 2015 KTM 1290 Super Duke R that developed a small oil leak that seems to be coming from the countershaft seal behind the front sprocket. I think it was caused by the KTM dealer over-tightening the chain at my first service. This is my first chained bike and my fundamental mistake was to assume that the dealer knew what he was doing. So anyway, after discovering the leak, I have loosened up the chain which seems to have helped a bit. But the leak is still there intermittently and it is no more than a few drops when it shows up. I am confident what I am seeing is not the chain lube. I have no intention of going back to this dealer and I am also hesitant to go thru the trouble of replacing the seal at this time since the leak does not appear to be too serious. I am running Motorex 10W-50 oil in the motor by the way and the oil level is below the max line. Is it even worth trying a different viscosity/brand oil to see if that helps with the issue? What would you do?
Re: What to do about small countershaft seal leak? [Re: uzun] #4514625
09/12/17 08:10 PM
09/12/17 08:10 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
investigate if the seal is serviceable externally..if so then a change in the offseason would be a good idea. otherwise i would ignore if it isnt making a mess on the bike or ground.
some bikes the seal is the outer seal of the actual countershaft bearing...where a new bearing is needed to fix the leak.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: What to do about small countershaft seal leak? [Re: uzun] #4514639
09/12/17 08:29 PM
09/12/17 08:29 PM
VA
uzun Offline OP
uzun  Offline OP
VA
Thanks, I already did some previous investigation about this seal. Fortunately, on this bike model the seal is separate from the bearing and can be serviced externally.
Re: What to do about small countershaft seal leak? [Re: uzun] #4514721
09/12/17 10:39 PM
09/12/17 10:39 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
ATP205 at the appropriate ratio
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: What to do about small countershaft seal leak? [Re: uzun] #4514724
09/12/17 10:48 PM
09/12/17 10:48 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I doubt it was from over tightening the chain. The big beefy countershaft bearing just can't flex that much, plus the rubber seal lips have some flex. Probably damaged during manufacturing assembly - seen it happen a few times. It takes some miles for the seal to start leaking if there's a burr or some damage to the inner collar or the seal lip.
Re: What to do about small countershaft seal leak? [Re: uzun] #4514745
09/12/17 11:53 PM
09/12/17 11:53 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Personally, I'd fix it or have it fixed. It would be a bad day if the minor leak were to become a major leak at an inopportune time, like leaned over in a fast sweeper..
Re: What to do about small countershaft seal leak? [Re: uzun] #4514813
09/13/17 05:13 AM
09/13/17 05:13 AM
NY
DdDd Offline
DdDd  Offline
NY
Not a leak. That's the factory KTM chain oiler.
