Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
81 registered members (53' Stude, AP9, Astro14, Anduril, 55hambone, 14 invisible), 1,596 guests, and 32 spiders.
Topics290,844
Posts4,851,324
Members66,040
Most Online3,590
Jan 24th, 2017
GMC Envoy Rough Idle #4513926
09/12/17 06:44 AM
09/12/17 06:44 AM
Illinois
carguy996 Offline OP
Illinois
I have recently purchased a 1 owner 2005 GMC Envoy with the 4.2 I6 motor to pull my camper. The vehicle has 97,000 miles and overall in decent shape, needs some TLC here and there but ill get it waxed this weekend and looking good. What I did notice is when it idle its a little rough and unsteady. When I accelerate it hesitates just a second and then it runs perfectly and smooth until I stop and it has to idle. Later this week I plan to do an oil/filter change, spark plugs and clean the throttle body. I also plan to run some SeaFoam through the gas and replace the air filter. This vehicle hasn't been used much recently by the previous owner so it has been sitting for a few months.
Anything I am missing here? I am assuming my issue is the plugs and throttle body. The car has no codes according to my reader and no warning lights.
2018 Nissan Rogue Platinum AWD w/ ProPilot
2014 Honda Odyssey Touring Elite 3.5
2013 Chrysler 200 Convertible 3.6
Re: GMC Envoy Rough Idle [Re: carguy996] #4513931
09/12/17 06:54 AM
09/12/17 06:54 AM
KS
FordBroncoVWJeta Offline
KS
My step dad just purchased a 2007 Trailblazer with the I6. They are smooth as silk. I have also worked on a ton of them at Walmart. They will last a very long time. It sounds like maybe bad plugs, MAF senor, gas filter, sometimes even a 02 sensor.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
Re: GMC Envoy Rough Idle [Re: FordBroncoVWJeta] #4513976
09/12/17 07:50 AM
09/12/17 07:50 AM
Illinois
Illinois
Thank you! Great to know they are reliable vehicles and will go a while! Doesn't look like the MAF sensor is very expensive so ill grab one of those as well.
Re: GMC Envoy Rough Idle [Re: carguy996] #4513982
09/12/17 07:55 AM
09/12/17 07:55 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
You could save some money and just clean the MAF sensor.
Re: GMC Envoy Rough Idle [Re: WobblyElvis] #4514041
09/12/17 08:47 AM
09/12/17 08:47 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 MAF sensor is my first thought. While you are in there I would check out the throttle body and the air filter to make sure they are in good shape. Clean/replace if needed. Sounds like the Envoy is lacking air. If none of that works I would check out the 02s to see if they are running lazy.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: GMC Envoy Rough Idle [Re: carguy996] #4514079
09/12/17 09:24 AM
09/12/17 09:24 AM
KS
KS
I would not recommend cleaning a MAF sensor. Many people do but nothing will be better than a brand new one. And they a cheap. Amazon has an ACDelco for $47. Also if you are going to replace an 02 Sensor you will only need the upstream sensor (About $40), since the downstream sensor is purely for emissions.(Just turns the check engine light on if the catalytic converter isnt doing its job.)
15 Honda CRV 2.4
Re: GMC Envoy Rough Idle [Re: carguy996] #4514090
09/12/17 09:39 AM
09/12/17 09:39 AM
Ohio
Lignums Offline
Lignums  Offline
Ohio
Check for spark, coils and plugs. Replace the fuel filter immediately if possible. I believe the 2005 model still has an external filter.
The forum trailvoy.com will help you out tremendously. You could chase that gremlin for a very long time. I know, I own an envoy, and chased many gremlins in that vehicle.
1998 Chevy w/t 1500 4.3
2004 Buick Lesabre 3.8
2006 Gmc envoy xl 5.3
Re: GMC Envoy Rough Idle [Re: carguy996] #4514093
09/12/17 09:44 AM
09/12/17 09:44 AM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
Sounds like you have a good plan. I still love my 2006 Tb. Runs strong but always has a hiccup or two in the platform.
When cleaning the MAF and the throttlebody, disconnect the battery for about 30 minutes to let the computer relearn on clean components. As well, remove the throttlebody from the intake to clean it fully.
The other, non related thing is the transfercase. These Autotrak 2 equipped vehicles need the fluid changed every 50,000 miles apparently.
2006 Trailblazer LT. Castrol Edge with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. It has oil and still runs
Re: GMC Envoy Rough Idle [Re: carguy996] #4514112
09/12/17 10:00 AM
09/12/17 10:00 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I owned a 2005 Trailblazer LS 4x4 for a few years. Like said, if there's no check engine light, it could be a dirty MAF sensor. Some of the earlier inline 6 powered Trailblazers didn't have a MAF (used computer modeling instead), but they started putting them back in, in 2005. Could be a lazy O2 sensor too, but it's all kind of a guessing game at this point. Could be old fuel even.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: GMC Envoy Rough Idle [Re: carguy996] #4514128
09/12/17 10:18 AM
09/12/17 10:18 AM
USA
mk378 Online content
mk378  Online Content
USA
Check for air leaks. Any unmetered air entering the engine through a leak after the MAF sensor will lean out the idle.
Re: GMC Envoy Rough Idle [Re: carguy996] #4514252
09/12/17 01:18 PM
09/12/17 01:18 PM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
Good suggestions here. I would personally clean the throttle body, clean the maf, change plugs, change air filter and check/replace fluids.
More than likely a dirty maf and throttle body. Make sure to use an actual maf cleaner and an actual throttle body cleaner. Don't use some generic brake parts cleaner or something. Use the right stuff, I've never had issues using crc maf cleaner or throttle body cleaner.
Good luck!
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: GMC Envoy Rough Idle [Re: carguy996] #4514337
09/12/17 03:36 PM
09/12/17 03:36 PM
Texas
JBinTX30 Offline
JBinTX30  Offline
Texas
More than likely a dirty throttle plate. I would take it off the car completely and clean it.
05 GMC Yukon XL SLT 5.3 CE 5w30 51042
06 Chevy Trailblazer LS 4.2 PP 5w30 XG9837
Re: GMC Envoy Rough Idle [Re: carguy996] #4516602
09/14/17 10:04 PM
09/14/17 10:04 PM
Lakeside CA
another Todd Offline
Lakeside CA
They did have valve seat problems which caused a rough cold idle. Got better when hot.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: GMC Envoy Rough Idle [Re: carguy996] #4519194
09/18/17 07:51 AM
09/18/17 07:51 AM
Illinois
Illinois
Wanted to provide an update....after replacing the plugs, doing a throttle body cleaning, air filter, MAF cleaning and SeaFoam upper intake clean, I still had a slight miss. Found the #2 coil on plug to be faulty, replaced that and it now runs perfectly and very smooth. Also did an oil change. Fuel Filter will be next.
Re: GMC Envoy Rough Idle [Re: carguy996] #4519251
09/18/17 08:54 AM
09/18/17 08:54 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Great work! I imagine all the cleaning and fixing the coil probably made a big difference.
