Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
106 registered members (ammolab, 4WD, advocate, AndyB, 69GTX, 69Torino, 10 invisible), 1,652 guests, and 33 spiders.
Topics296,899
Posts4,961,201
Members66,997
Most Online2,688
Jan 19th, 2019
Page 9 of 11 1 8 9 10 11
Re: Why are newer cars using thinner motor oils? [Re: billt460] #4520969
09/20/17 06:29 AM
09/20/17 06:29 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
same lifters ???
same solenoid ???
different oil ???
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521131
09/20/17 09:49 AM
09/20/17 09:49 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
User Clevy ran 0w-40 in his 5w-20 spec Charger and was able to get a code tripped for improper viscosity when it was below -30C I believe once. That was the only time I am aware that he experienced it.
The system is not that sensitive, it can't be given the range of the SAE grades.
Regarding the whole argument with the 5.7L and the 6.4L, the engines are extremely similar and the system operates in the same manner. There are accommodations made to the programming for the 6.4L engines for the 0w-40 spec.
Also, this may be found as amusing: The 5.7L and 6.4L truck engines use the exact same lifter part #'s. However they spec very different oils.
See below snap from the 2014 RAM 1500/2500/3500 manual:
I have not been able to find the SRT lifter part # as of yet, but I can probably find it at some point today.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521149
09/20/17 10:08 AM
09/20/17 10:08 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Just confirmed, the 5.7L MDS and 6.4L (SRT) MDS engines use the same lifters.
Quote:
LIFTER. Front, Rear. Hydraulic Roller Deactivating. Yoke.
Part Number: 05038788AC ; 05038788AA; 05038788AB; 05038683AA; 53021573BC
[NHA], Crew Cab, Front Yoke, Rear Yoke, Use 03/16/2015 And After, Use For Production Date 03/16/2015 And After, Use For Production Date 03/16/2016 And After, Use Up To And Including Production Date 03/15/2015, Yoke.
They also use the same solenoids:
Quote:
SOLENOID. Multiple Displacement.
Part Number: 53022298AA
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521193
09/20/17 10:52 AM
09/20/17 10:52 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Those sunsabitches! smile
Re: Why are newer cars using thinner motor oils? [Re: OVERKILL] #4521196
09/20/17 10:55 AM
09/20/17 10:55 AM
bigj_16 Offline
bigj_16  Offline
Is this from a Canadian manual? And I guess we know who makes the Mopar oil.
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521227
09/20/17 11:25 AM
09/20/17 11:25 AM
bigj_16 Offline
bigj_16  Offline
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521314
09/20/17 12:41 PM
09/20/17 12:41 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I am sorry. I thought this site was where average Joe's shared information and tips and about products and what works better and how to get more mileage. Sharing experience and what works and what doesn't. If we all just do as the manual says that eliminates alot of posts on MMO or any fuel additives, not permitted by manual. The point that we are lucky enough to even get to share information with people from other countries is Great. So what does it take for people to realize it is a Cafe standard and not for engine tolerances or longitivity and two countries don't get different cars. I think what drives me is not you follow the manual so religiously it's that you actually believe 15w40 and thick is don't pump below 0 and you need required 0 weight oils based on no experience, just what you read. Open up your minds.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Why are newer cars using thinner motor oils? [Re: bigj_16] #4521398
09/20/17 01:54 PM
09/20/17 01:54 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Nope, it is from the US manual:
https://www.ramtrucks.com/download/pdf/manuals/2014-RAM_15_25_35-OM-3rd.pdf
Re: Why are newer cars using thinner motor oils? [Re: OVERKILL] #4521429
09/20/17 02:55 PM
09/20/17 02:55 PM
'Stralia
'Stralia
Yep, that's what my researches found too... thumbsup thumbsup thumbsup
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521542
09/20/17 05:35 PM
09/20/17 05:35 PM
WI.
dblshock Offline
dblshock  Offline
WI.
Honda doesn't have these issues, here's my 1.5T with over sized tires so add 2mpg. and above I-system speeds on twice the spec viscosity...
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Why are newer cars using thinner motor oils? [Re: dblshock] #4521557
09/20/17 05:43 PM
09/20/17 05:43 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Not sure what your anecdote is qualifying shrug Seems no different than mine about user Clevy who did similar with his Charger.
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521669
09/20/17 08:11 PM
09/20/17 08:11 PM
WI.
dblshock Offline
dblshock  Offline
WI.
minimal risk ignoring the silly CAFE w20 motor oil spec.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Why are newer cars using thinner motor oils? [Re: dblshock] #4521764
09/20/17 10:07 PM
09/20/17 10:07 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Well I think that applies to both applications quite frankly; most of them even. An engine simply cannot be that sensitive to viscosity and survive anything close to resembling winter, which has a much greater impact on actual viscosity than the difference between grades at moderate ambient and 100C.
Re: Why are newer cars using thinner motor oils? [Re: AdrienneOwens] #4521788
09/20/17 10:58 PM
09/20/17 10:58 PM
burlington ,ontario, canada
ndfergy Offline
ndfergy  Offline
It's CAFE driven
I'm not sure, or anyone else for that matter, what the balance is between chemistry and viscosity is in the valvetrain but the BOI testing requirements for camshaft wear is not required if the exchanged Base oil is > in viscosity. I'm certainly not the one to comment on this intelligently, like some of, you but it seems to me viscosity is a key driver in wear protection in this area.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: Why are newer cars using thinner motor oils? [Re: ndfergy] #4521792
09/20/17 11:06 PM
09/20/17 11:06 PM
'Stralia
'Stralia
Yes, that is an entirely logical thought process.
If add pack a) in 5W20 meets sequence IVA, then it qualifies all thicker blends.
If add pack b) in 5W30 meets sequence IVA, then it qualifies a 40, but not a 20.
For API to make that distinction clearly indicates that they are aware of the behaviour.
