Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
108 registered members (77GrandPrix, aquariuscsm, Audios, Alfred_B, Astro_Guy, Bambam, 7 invisible), 2,070 guests, and 57 spiders.
Topics286,237
Posts4,904,952
Members67,582
Most Online2,967
Mar 10th, 2019
Why is this paint peeling (exterior door jamb)? #4513775
09/11/17 11:07 PM
09/11/17 11:07 PM
Seattle-ish, WA
Oro_O Online content OP
Oro_O  Online Content OP
Seattle-ish, WA
This is peeling paint on the jamb of an exterior door. I am going to repair it, but want to know why it failed. It is about 8 years old from what I am told. I found in storage the paint used, it is Rodda "Premium Classic Exterior" - which I take to be an adequate if not actual premium paint. It is fine on the trim everywhere else on the house. It gets neither very cold nor very hot here (Seattle area).
The part that is exposed is the edge of the 1/2" x 4.5" Jamb securing the weatherstripping (out of photo to the right). What you see underneath is bleached wood, nothing else.
I am thinking it was not primed correctly? This is around the lower part of the door below the handle. The opposite side, which sees less use/impact, has a small crack and peel spot, but no where near as much.
The pics of the small chip I peeled show the color layer and a distinct white layer underneath, which has complete pulled off the wood and clearly not bonded to it.
How should I fix it? I was thinking:
- peel/chip away what I could, sand as smooth as possible.
- Prime (with what?)
- re-Paint
Sorry, I cannot get these google photos to appear inline. Please click if you think you can help.
https://lh3.googleusercontent.com/ONiuKn...tY8BA_9DGS-PB_Q
https://lh3.googleusercontent.com/8I6SgC...rQ5Ru_J8mCz-Fqg
https://lh3.googleusercontent.com/s2QIYl...UcqPCuxCXgwAeow
Re: Why is this paint peeling (exterior door jamb)? [Re: Oro_O] #4513778
09/11/17 11:13 PM
09/11/17 11:13 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
The lower part of the door you mean the part of the door that gets hit by all of our friendly Seattle rain? Is this door facing the direction your storms usually come from? My guess in you need to strip the paint off the door and jam then prime it with something like white pigmented shellac then repaint it. Better hurry our fall rain is almost here yep summers nearly gone.
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Why is this paint peeling (exterior door jamb)? [Re: Oro_O] #4513784
09/11/17 11:21 PM
09/11/17 11:21 PM
5600 feet elevation, Arizona
double vanos Offline
I'm in the desert so this may not work in Seattle, but it's works fine here. Sand everything down to bare wood / paint that still sticking. Prime with Zinzer oil based primer and let dry completely- in Seattle this may take awhile; in the low humidity of the desert, 2 days is fine. Paint with high quality exterior paint in semi gloss. I did my whole house here and so far, so good.
I am not a paint wizard, just observed what worked here...
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Why is this paint peeling (exterior door jamb)? [Re: JohnnyJohnson] #4513826
09/12/17 01:12 AM
09/12/17 01:12 AM
Seattle-ish, WA
Seattle-ish, WA
Yep it is the west-facing side of the house. So I guess that implies the rain softened it, and the traffic/bumping ruined it? Curious why the apparent white primer didn't work (maybe it was applied when wet; I wasn't around for that!).
I am trying to get stuff like that done this month - both cars clayed/polished/waxed, this fixed. I planned to build a roof over the two small porches on that side for protection to the doors; did not get to it in a busy summer. Next year I will plan ahead and get the HOA permission and get it done next summer.
I will sand it and get a good primer like you two guys suggested before re-painting.
Re: Why is this paint peeling (exterior door jamb)? [Re: Oro_O] #4513867
09/12/17 04:30 AM
09/12/17 04:30 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Some possible causes:
1. Any wood making contact with the ground will wick up water. Then the sun draws the water out of the wood through the paint film. Latex paint is designed to breathe, oil paint doesn't breathe well. In time the water being drawn out of the wood will eventually cause the paint to fail, latex or oil.
2. Another cause for failure is tiny cracks in the paint film. Moisture gets in, spreads out and is pulled out by the sun.
Then we have poor quality products, incorrect products, painting over damp wood, dust, dirt, etc. The usual reasons.
Exterior paint lasting 8 years in a rainy climate is not that bad. Paint jobs don't last forever, they're considered maintenance.
Sand, re-prime with a good latex exterior primer, topcoat with your favorite exterior paint, and hope for the best. Make sure everything is properly caulked, if you have to caulk, caulk over dry primer. Allow the caulking to dry, spot prime it and paint it.
God Bless Our Troops
Re: Why is this paint peeling (exterior door jamb)? [Re: Oro_O] #4514061
09/12/17 09:10 AM
09/12/17 09:10 AM
PimTac Offline
PimTac  Offline
Yep, the south side of your house will get beaten from the weather. 8 years is not bad for Seattle
Cannot see signatures any longer so it doesn’t matter.
Re: Why is this paint peeling (exterior door jamb)? [Re: Oro_O] #4514087
09/12/17 09:37 AM
09/12/17 09:37 AM
Wisconsin
emmett442 Offline
emmett442  Offline
Wisconsin
If there's a leak at the head flashing, water could be getting behind the jamb, causing the paint to peel...
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Why is this paint peeling (exterior door jamb)? [Re: Oro_O] #4519931
09/19/17 01:05 AM
09/19/17 01:05 AM
Seattle-ish, WA
Seattle-ish, WA
I want to thank all of you for thoughtful comments.
I got distracted this week with car, child, and pet issues. I have though taken all this to mind and got the right sander, primer, replacement weather seal, and a cover piece of molding to protect the repair (pet wear on the weather seal was something I did not mention) and get it all back to battery.
Fire ash was literally raining here last week, and it's been raining actual water for the last few days. wink We have clear weather ahead and I'll get on it later this week. Your comments steered me in the right direction and saved me time. Thank you. Thank you in particular demarpaint, but ALL comments were valuable. You guys ALL put me in the right direction fast and saved me time. I appreciate that.
