When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
96 registered members (28oz, 64bawagon, ABomb369, Aero540T, AandPDan, advocate, 10 invisible), 1,180 guests, and 45 spiders.
Topics290,632
Posts4,847,745
Members66,011
Most Online3,590
Jan 24th, 2017
Bow in Insulated Clopay Garage Doors #4513690
09/11/17 08:57 PM
09/11/17 08:57 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Somebody decided to back up the driveway to better facilitate the removal of the $280 worth of groceries in the trunk of my '98 LS400. As I was studying for Sunday's sermon, that said somebody came running into the house via the garage man door saying, "I'm so sorry. I'm so sorry. How much will it cost? I don't think I hurt the car. Can you forgive me? I didn't mean to".
I took a deep breath and proceeded to walk towards the incident. Well, the bumper on the '98 LS400 is perfect so I'm feeling better. I look at the Clopay Insulated panels and there are just a few tiny creases that I could easily live with. Said perpetrator starting to cry as I said nothing. Getting ready to say, "It's all good" when I look down to where the bottom panel touches the concrete. I think, banana, 1/4 moon, bow, etc.
Just taking a stab but is there a way to straighten those panels since they are only bowed about 2 inches? They still go up and down so that's good.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513710
09/11/17 09:22 PM
09/11/17 09:22 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
You surely aren't talking about your wife here...because your narrative comes across pretty harsh.
T0 answer your question I was able to take the major bow out of a lower panel 2 car wide that an elderly lady backed into but it isn't perfect.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513723
09/11/17 09:38 PM
09/11/17 09:38 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Put the car in the garage, close door, reverse.
Re: Bow in Insulated Clopay Garage Doors [Re: JamesBond] #4513728
09/11/17 09:43 PM
09/11/17 09:43 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Thought about it but the hinges are all in the way. Would cut my bumper.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513746
09/11/17 09:59 PM
09/11/17 09:59 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You have to straighten it by "rewinding in slow motion"
You have to work from the outside edges towards the center as you straighten it.
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513747
09/11/17 10:00 PM
09/11/17 10:00 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I'd probably pull the car as far forward as I could, put my rear on the bumper and give the door a push with my feet.
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513749
09/11/17 10:01 PM
09/11/17 10:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Use blocks of wood, plywood, and carpet to protect the bumper. Use a beater vehicle.
Start at the sides and work slowly towards the center.
Re: Bow in Insulated Clopay Garage Doors [Re: JamesBond] #4513750
09/11/17 10:02 PM
09/11/17 10:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That might work, with two strong guys!
Work from the sides towards the center. >>>-<<<
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513766
09/11/17 10:40 PM
09/11/17 10:40 PM
USA
Reddy45 Online shocked
Reddy45  Online Shocked
USA
Call a garage repair guy. Tell them you want to know if it can be fixed instead of replaced, and insist on not replacing it.
Some of them are good hearted enough to know how to fix small dents and creases for a few hundred.
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513776
09/11/17 11:09 PM
09/11/17 11:09 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Call the paintless dent removal guy. Should be cake for him.
Re: Bow in Insulated Clopay Garage Doors [Re: Gebo] #4513821
09/12/17 12:55 AM
09/12/17 12:55 AM
KS
FordBroncoVWJeta Offline
KS
They damaged your property and then ran in the house? That outcome would have been a lot different if that would have been my house.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
Re: Bow in Insulated Clopay Garage Doors [Re: Linctex] #4513890
09/12/17 05:50 AM
09/12/17 05:50 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
The carpet idea coupled with my 4Runner might just work. I have no idea what you mean by starting at the sides though.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
