The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
what happened to merk
by ernied
06/24/18 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
06/24/18 03:02 PM
Paint impurities on a new car
by Quattro Pete
06/24/18 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
06/24/18 02:41 PM
Do people buy from telemarketers?
by Chris142
06/24/18 02:06 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
113 registered (2018matto, 209paulc, 4WD, 14Accent, 2015_PSD, 8 invisible), 1536 Guests and 70 Spiders online.
65317 Members
67 Forums
285941 Topics
Page 1 of 2 1 2 >
#4513400 - 09/11/17 03:33 PM 2015 Ford Edge Recommendation
Kyle2636 Offline
Loc: Kentucky
I'm looking for an oil recommendation for my wife's car. We just bought it so this will be the first oil change I've don't on it. It has the 3.5L engine and calls for 5w20 synthetic blend oil. Her commute is over an hour with 95% of it on the interstate. It has the oil life monitor on it which should notify her at 7,500 to 10,000 miles under normal driving conditions.
Since she'll be putting so many miles on this car, I'd really like to get at least 7,500 miles out of an oil change. I use maxlife full synthetic 5w-20 in my car. (2001 Ford Edge w/180,xxx miles). I know her's doesn't need the high mileage oil but would it be ok in her car with those intervals? It would be easier for me to use the same oil in both vehicles and I already have a little stockpile of it. I'm not against buying something else if it's better suited for her car, I'm just lazy. I usually use the motorcraft filters.
I look forward to hearing your suggestions!
Kyle
#4513406 - 09/11/17 03:37 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
EricBeau Offline
Loc: Sauk Valley, IL
As far as I know there's no reason not to use the MaxLife Full Synthetic in that vehicle. I'm still new around here but I've gathered that the MaxLife synthetic is good stuff. After I use the Pennzoil Platinum 5W-20 I have for my Odyssey I'm planning to run MaxLife Full Synthetic 0W-20.
Welcome to BITOG!
2001 Toyota Camry LE 4cyl.
Valvoline MaxLife 5W-30 blend and FRAM PH4967
2010 Honda Odyssey LX
Valvoline MaxLife 5W-20 blend and FRAM TG7317
Ford Service Advisor
#4513416 - 09/11/17 03:47 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
SubieRubyRoo Offline
Loc: Winchester, Indiana
I like Valvoline oils, but I am a Pennzoil (ab)user. That being said, I would use PP 5W-20 in both, or PPHM 5w-20 in place of the ML. But, there's absolutely nothing wrong with ML... it's a great engine oil, and the transmission fluid is really great too. Welcome to BITOG!
#4513417 - 09/11/17 03:47 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
JohnnyJohnson Online   content
Loc: Wet side WA
Anyone would serve you well but it looks like Valvoline Maxlife full synthetic 5w-20 has served you well in your other edge I see no reason no just to stick with what's gotten you over 180,000 miles. Don't over think what's working!
Edited by JohnnyJohnson (09/11/17 03:48 PM)
2004 Toyota Corolla 121808
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4513421 - 09/11/17 03:53 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
Onug Offline
Loc: Washington, USA
I had that motor in my previous car and it did great with Mobil 1. But any quality full synthetic will be fine. Even Motorcradr oil is great. If you're driving mostly freeway, then the OLM will take you all the way to 10,000 miles. I personally would take it to 20% life remaining and do an analysis. If the oil life and wear tracks well against the monitor, thrn you know you're GTG.
2016 F-150 3.5L Ecoboost
Current Oil: Mobil 1 5W-30 and Fram Ultra filter
#4513422 - 09/11/17 03:54 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
CT8 Offline
Loc: Idaho
Any oil that meets the recommended oil specs listed in the owners manual will allow life beyond your ownership of the vehicle will work. That being said if you have a favorite brand of oil that makes you feel good run it. Today's oils are that good. ValvolineFull syn with Maxlife technology is a super oil..
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4513439 - 09/11/17 04:18 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
wallyuwl Offline
Loc: Wisconsin
Use whatever full synthetic you can get cheapest, with a quality filter (don't go nuts - you don't need a M1 filter for 7500 OCI). Maxlife HM and a Motorcraft filter will suit you just fine. You only have to worry at all if you have the Eco Boost, which thankfully you don't (those are DI and turbo - really hard on oil).
We have the same engine in a 2014 and I've gone around 7500 miles per OCI with Pennzoil Platinum, M1, and Quaker State Ultimate Durability. The engine looks like you could eat off of it in the fill hole. It has a little over 30k on it. I'm waiting until Menards has QSUD for $1.99/qt again after rebate to stock up.
#4513474 - 09/11/17 05:07 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
Merkava_4 Offline
Loc: Clovis, CA
5W-20 is old news. Ford is switching their new cars over to Motorcraft 5W-30.
#4513540 - 09/11/17 06:10 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
SR5 Offline
Loc: Down Under
Yes use Valvoline MaxLife full synthetic in both. It's a great oil that works well in any mileage car.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4513581 - 09/11/17 06:59 PM Re: 2015 Ford Edge Recommendation [Re: Merkava_4]
Onug Offline
Even the NA motors?
#4513591 - 09/11/17 07:11 PM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
-SyN- Offline
Loc: Tornado Alley
I have used PP 10W-30 in both our 2012 edges since the first OCI.
17 Ram 2500 6.7L CTD- >Rotella T6 5W-40
14 GMC Sierra 5.3L-->PP (HM) 10W-30
12 Ford Edge-X2 Limited & SE->PP (HM) 10W-30
#4513595 - 09/11/17 07:15 PM Re: 2015 Ford Edge Recommendation [Re: Merkava_4]
tig1 Offline
Loc: Illinois
Edited by tig1 (09/11/17 07:17 PM)
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4513597 - 09/11/17 07:19 PM Re: 2015 Ford Edge Recommendation [Re: Onug]
tig1 Offline
Loc: Illinois
Even the NA motors?
My 2017 Fusion calls for 5-20. The Ecoboost engines call for 5-30, but that's about the turbo.
Edited by tig1 (09/11/17 07:20 PM)
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4513855 - 09/12/17 03:39 AM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
Joeescape63 Offline
Loc: New York/USA
I use in my Ford Escape 2.0L Ecoboost Castrol Edge or Magnatec 5W30.I'm sure you can get either of these oils in 5W20 weight.
Edited by Joeescape63 (09/12/17 03:40 AM)
2018 Subaru Forester Touring
2.5L engine/CVT
Subaru FIlters
#4513930 - 09/12/17 06:51 AM Re: 2015 Ford Edge Recommendation [Re: Kyle2636]
SilverFusion2010 Online   content
Loc: Crawfordville FL
Yes the full syn MAXLife will run fine for 10k in that application
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Page 1 of 2 1 2 >
