more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
74 registered members (AurionX2, Bjornviken, billt460, Astro14, Brian123, bozo66, 4 invisible), 1,346 guests, and 52 spiders.
Topics286,271
Posts4,905,690
Members67,589
Most Online2,967
Mar 10th, 2019
Mazda Thermostat #4513026
09/11/17 09:19 AM
09/11/17 09:19 AM
PA
Chester11 Offline OP
PA
Folks:
Yesterday I tried to replace the thermostat on an 07 Mzada 6.
I'm not seeing any activity on the Mazda boards - so hoping someone here can help.
I cannot figure out how to reach the lower bolt on the thermostat body. (I have now lost the bolt in the engine bay - which is another issue).
It can be reached from underneath, but I can't get a wrench on it. From the front you can barely touch it with an extension, but you can't see the hole to line it up. I've tried lining it up from below and then back up front to turn the extension. Each time I drop the bolt, or knock it out of the hole.
Is there a way to "stick" a bolt in a socket so I can line it up and get it started? I tried using grease which almost worked. I figure there is a mechanic trick out there....
Re: Mazda Thermostat [Re: Chester11] #4513046
09/11/17 09:42 AM
09/11/17 09:42 AM
VA
Thax Offline
Thax  Offline
VA
Easiest way is to get a socket with a magnetic insert, never fails. Another way is to put a piece of shop paper towel in the socket ,and jam the fastener in the socket.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: Mazda Thermostat [Re: Chester11] #4513047
09/11/17 09:42 AM
09/11/17 09:42 AM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
I put a small piece of masking tape around the bolt head so that it fits snug...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Mazda Thermostat [Re: Chester11] #4513066
09/11/17 09:57 AM
09/11/17 09:57 AM
PA
PA
man...why didn't I think of that....
I am going to get some wobble extensions just because...
Re: Mazda Thermostat [Re: Chester11] #4513178
09/11/17 12:07 PM
09/11/17 12:07 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Is this on the 4 cylinder or v6?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Mazda Thermostat [Re: Miller88] #4513268
09/11/17 01:50 PM
09/11/17 01:50 PM
PA
PA
sorry man, that would have been helpful right?
I'm good to go. I found the bolt and was able to reach it with an extension using the tips provided.
So far no leaks and the serpentine belt has not fallen off! Hopefully I can get the splash guards back on.
Thanks all!!
Re: Mazda Thermostat [Re: Chester11] #4513304
09/11/17 02:12 PM
09/11/17 02:12 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The major tool guys sell all kinds of tools for this problem. I have 1/4 swivels,magnetic sockets etc
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Mazda Thermostat [Re: Chester11] #4513326
09/11/17 02:27 PM
09/11/17 02:27 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
There are different ways to get the bolt in there to get it started. One way is by using super long nose pliers. Another way is to drop it in there with a telescopic magnet. Once the bolt is dropped in the hole and a couple of threads started, you can finish it up with a super long 1/4 drive extension and a swivel socket on the end. The long extension and swivel socket lets you go in at an angle to clear obstructions.
Re: Mazda Thermostat [Re: Chester11] #4513652
09/11/17 08:28 PM
09/11/17 08:28 PM
PA
PA
Thanks guys. This made me realize I need a better assortment of extensions.
This is the second or third time now I have busted myself up trying to reach something. Should I invest in some wobble extensions? I have a couple swivel tools, but it always seems that they swivel the wrong way.
Just in case anyone is interested - I also dislodged the bottom radiator hose just enough to contact the fan. Nice noise there when the fan kicked on. After sorting that, there must a been a large air bubble because the temp shot way up on my drive around the block. (Like s-my pants / shut down hot). Heat stopped working also. After cooling down, it finally pulled a little fluid from the expansion tank. My second lap was a little better but still too hot. I think it is ok now, but for a while the heat was off and on.
About two quarts of fluid came out - I must have misjudged how much spilled out of the pan, because even with over 2 quarts replaced, I nearly cooked my engine.
Live and learn.
Re: Mazda Thermostat [Re: Chester11] #4514282
09/12/17 02:01 PM
09/12/17 02:01 PM
Chris142 Offline
Chris142  Offline
Get the impact swivels. Matco makes the best. Not the ujoint ones.
Re: Mazda Thermostat [Re: Chris142] #4514624
09/12/17 09:07 PM
09/12/17 09:07 PM
VA
Thax Offline
Thax  Offline
VA
Matco's pinless impact swivel sockets are the bomb!! Also pretty good and not too expensive is the adv line of magnetic impact sockets. I love the set I have in 1/4 , life savers on many jobs.
