Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
92 registered members (BamaE92, ARCOgraphite, billt460, Bailes1992, andyd, 14 invisible), 1,750 guests, and 67 spiders.
Topics286,446
Posts4,908,449
Members67,626
Most Online2,967
Mar 10th, 2019
ATF for 2013 Mazda 3 #4512977
09/11/17 08:16 AM
09/11/17 08:16 AM
Monterrey, Mexico
knoas Offline OP
knoas  Offline OP
Monterrey, Mexico
Hey guys,
Just looking for some advice,
I just bought a new to me 2013 2.5 Mazda 3 Hatchback with Automatic Transmission (I believe it is a 5-speed).
It currently has 96,000 KM.
I am sure the ATF has never been changed and would like to do it if is best for the vehicle.
What ATF works best on this transmission, based on your experience?.
I have used Valvoline Maxlife on a Jetta with Aisin transmission previously with good results.
Thank you all for any support you can provide.
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513050
09/11/17 09:44 AM
09/11/17 09:44 AM
Florida
Artem Offline
Artem  Offline
Florida
What's wrong with the original PROPERLY Spec'd oil from Mazda? Swing by the dealership and get some oil. Why put in aftermarket fluid?
How do you plan on changing it? Simple drain n fill? Multiple drain n fills like Mazda recommends? Or a proper fluid exchange via radiator hose?
I recently serviced a 2004 Mazda RX-8 with 4 speed auto and the transmission pan had no drain bolt. Mazda requires dropping the pan. About 3 quarts came out, along with two (2) VERY DIRTY oil pan magnets.
Upon re-installation, I proceeded to flush the rest of the old transmission fluid out via return radiator line, pumping 1 quart at a time and pouring in a new one. An additional 7 quarts of new fluid went in before I started seeing fresh fluid come out of the hose... just saying.
Transmissions shifts MUCH smoother. Sometimes can't even feel it. Money and effort paid off. 125k miles on the clock.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513054
09/11/17 09:49 AM
09/11/17 09:49 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
What's the spec?
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513055
09/11/17 09:52 AM
09/11/17 09:52 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
I believe the only fluid approved for that vehicle is Mazda OE fluid. A local Mazda3 owner here recently had a trans flush done at a quick lube, the trans then started making some noise, Mazda denied the warranty claim because non OE fluid was used.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: ATF for 2013 Mazda 3 [Re: Artem] #4513058
09/11/17 09:54 AM
09/11/17 09:54 AM
Monterrey, Mexico
knoas Offline OP
knoas  Offline OP
Monterrey, Mexico
Not saying there is anything wrong with the OEM fluid.
In Mexico OEM fluid is usually very overpriced as are synthetics oils in general, sometimes more than 2X the cost in the US from the posts i have seen here.
If no aftermarket fluid has record of working well in this trans then i will go with the OEM fluid, just looking for advice in order to not pay more than i should if an aftermarket one works well.
I plan on doing a drain n fill, if i do that i will need about 3 quarts as you mentioned below?.
Thank you for you reply.
Re: ATF for 2013 Mazda 3 [Re: mightymousetech] #4513079
09/11/17 10:24 AM
09/11/17 10:24 AM
PA
Chester11 Offline
Chester11  Offline
PA
Very much this....I had a flush done at a quickie lube and they used the generic stuff. Needed a rebuild at about 70k.
I would only use the Mazda stuff and just do a drain and fill (no flush). Do it a couple times if you are paranoid.
Re: ATF for 2013 Mazda 3 [Re: Chester11] #4513089
09/11/17 10:38 AM
09/11/17 10:38 AM
Florida
Artem Offline
Artem  Offline
Florida
It has nothing to do with being paranoid. It's a matter of doing the maintenance work Properly, vs halfassed. Major difference between the two.
Say you had the option of two identical cars @ 150k miles. One went to get ALL FLUIDS changed at the dealership with OE spec fluid. The second went to a quick lube place to get all fluids changed with no name juice from a barrel.
Which would you say has more value just based on the quality of the fluids used?
Safe to say the car with original fluids designed and tested on your particular model is far better then using generic one size fits all fluid.
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513092
09/11/17 10:46 AM
09/11/17 10:46 AM
Florida
Artem Offline
Artem  Offline
Florida
What's the total transmission fluid capacity? I'm willing to bet that you'll be mixing 3 quarts of new fluid with 6 quarts of old fluid, effectively diluting the transmission fluid to ONLY roughly 30% of the oil replaced. I mean, sure that's better then no oil replaced but it still falls far behind being considered a proper transmission oil change, to where you can expect another 60k worth of trouble free use before the color starts going dark on the dipstick.
My 98 Camry can go 100k on the Mobil 1 Synthetic transmission fluid it has been flushed with for 250k miles now since new. Transmission shifts smooth, doesn't leak oil, and fluid stays bright red for YEARS. The car always got a full fluid exchange via radiator return line. 10 quarts oil change. I buy it when it's on sale ahead of time.
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513108
09/11/17 11:05 AM
09/11/17 11:05 AM
Monterrey, Mexico
knoas Offline OP
knoas  Offline OP
Monterrey, Mexico
Thank you all for your replies..
Based on the general consensus then i will go and quote the price for the OE fluid and prepare to get it done ASAP.
I will get the drain and fill done at an independent place but i will make sure to use the OE fluid.
Have a great day!
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513139
09/11/17 11:30 AM
09/11/17 11:30 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
I exchanged the ATF in my 06 Mazda 3 at about 20k miles with Castrol Import Multivehicle ATF, which meets Mazda MV fluid specification (not to be confused with Mecron V). At about 60k miles I exchanged Castrol ATF with Petro Canada Synthetic multi vehicle ATF, again it met the MV specification. The car has a bit over 150k miles now with absolutely no issues.
If a multi vehicle ATF, that meets Mazda MV spec, is used, there should be no problems.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: ATF for 2013 Mazda 3 [Re: KrisZ] #4513171
09/11/17 12:01 PM
09/11/17 12:01 PM
Florida
Artem Offline
Artem  Offline
Florida
Have a great day!
Good choice on the OEM spec fluid. You just can't go wrong with it.
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513173
09/11/17 12:03 PM
09/11/17 12:03 PM
The Orca
quint Offline
quint  Offline
The Orca
You can get Idemitsu Mazda Type M off Ebay pretty cheap. Been using it for years.
You can also go to a Ford dealer and get the Ford FNR5 fluid, which is the exact same thing as the Mazda M-V fluid.
Re: ATF for 2013 Mazda 3 [Re: KrisZ] #4513175
09/11/17 12:04 PM
09/11/17 12:04 PM
Florida
Artem Offline
Artem  Offline
Florida
I've been running Mobil 1 synthetic transmission fluid in my 98 Camry since first oil change when New. 280k miles and shifts like a dream. 60-80k oil changes.
I'm not saying there's anything wrong with aftermarket Lube. It just makes more sense to use OE oil for peace of mind knowing the specs are designed to work with YOUR transmission.
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513260
09/11/17 01:38 PM
09/11/17 01:38 PM
Michigan
khittner Offline
khittner  Offline
Michigan
Valvoline MaxLife ATF is suitable for Mazda transmissions that use Mazda M-V fluid, according to Valoline's data sheet MaxLife ATF Data Sheet . My anecdote: I use MaxLife in my Toyota Camry's automatic transmission, and have for the last 150K miles (the car has 264K miles on it), and it works fine.
I'd do a pan drop, change the transmission filter, clean the magnet(s), refill with MaxLife, and drive on. Or you can spend more money, to little probable positive effect, by only buying the proprietary OEM fluid, as Artem suggests.
Re: ATF for 2013 Mazda 3 [Re: knoas] #4513262
09/11/17 01:41 PM
09/11/17 01:41 PM
Monterrey, Mexico
knoas Offline OP
knoas  Offline OP
Monterrey, Mexico
Once again thank you guys..
Reading BITOG has certainly changed my maintenance routines and knowledge.
I read the forum everyday grin
