White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
20 registered members (Char Baby, BretK, ChrisD46, billt460, c502cid, 4 invisible), 817 guests, and 34 spiders.
Topics296,866
Posts4,960,390
Members66,982
Most Online2,688
Jan 19th, 2019
2-Stroke oil in diesel for winter preservation? #4512848
09/11/17 02:22 AM
09/11/17 02:22 AM
Norway
mmosberg Offline OP
mmosberg  Offline OP
Norway
I have a 2003 Windy Scirocco 32 with a twin Volvo Penta KAD300 installation. The fuel tank on the boat is of aluminium and 520 liters. I put the boat on shore from end of September to app. end of April and I leave it with a full tank to minimize condensation.
I was first thinking of adding a diesel improver additive with water emulgating properties when filling the tank before winter storage. But then I got uncertain if this is wise. Any water emulgated in the diesel would leave the tank, travel through the water separators without falling out and into the Bosch rotary HP pump and the diesel nozzles. Could any water emulgated in the diesel cause corrossion in the fuel system?
The diesel here in Norway has a biodiesel content of 2-5%. So I was thinking if it maybe would be smarter to add 2-Stroke oil to the diesel on the last fill up before winter storage? If yes, mineral based 2-Stroke oil or Synthetic? And at what concentration? I can also add that there is no DPF or catalysator on the exhaust side of the engines to worry about getting clogged.
Wife & kids: 2012 VW Sharan Highline 2.0 TDI 4M, Pantheon Grey, 17" Jarama
Man: 2014 Audi A6 Avant quattro 3.0 TDI S-Line, Daytona Grey, 20" Rotor
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4512880
09/11/17 04:41 AM
09/11/17 04:41 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
From a lubricity standpoint, two stroke oil, such as a typical TCW-III outboard oil, will improve lubricity on conventional diesel. However, you state that your diesel contains Biodiesel, itself a very good lubricity additive. You probably do not need more lubricity.
From a stability standpoint, diesel fuel, and in particular biodiesel has a limited life. I don't "know" that adding two stroke oil will increase the lifespan of the fuel, I can only say I "suspect" it might. I do have a tank with diesel and two stroke oil mix. It's lasted for years in a plastic tank.
Remember that additives designed to extend the life of diesel fuel exist. A good additive may include metal deactivators (copper and zinc can react with the fuel) and anti oxidant. The two stroke oil may, in some small measure be an anti oxidant.
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513071
09/11/17 09:08 AM
09/11/17 09:08 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
What does s stroke oil do? I would use a biocide.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513085
09/11/17 09:32 AM
09/11/17 09:32 AM
Norway
mmosberg Offline OP
mmosberg  Offline OP
Norway
Biocide is for killing bacterias. 2-stroke oil improves lubrication and preservation properties (I assume?).
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513118
09/11/17 10:12 AM
09/11/17 10:12 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Adding oils to the diesel will increase its life, as it makes it harder for "algae" diesel microbes to reproduce.
Biodiesel decomposes quicker, but not sure why - perhaps due to oxidation?
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513135
09/11/17 10:25 AM
09/11/17 10:25 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I might not fill the tank if all I could get was bio-diesel.
2015 Ford F250 w/Powerstroke
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513166
09/11/17 10:57 AM
09/11/17 10:57 AM
Norway
mmosberg Offline OP
mmosberg  Offline OP
Norway
There is no way around the biodiesel over here. By law the distributors have to blend in minimum 2% biodiesel. If over 5% the pump must be clearly marked. What I get is somewhere between 2 and 5%.
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513216
09/11/17 11:53 AM
09/11/17 11:53 AM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
The biodiesel is more susceptible to being "eaten" by bacteria, etc because of the ester linkage which gives enzymes an easier point of attack on the molecule. Look at Diesel Kleen products and follow their recommendations.
2013 VW Passat TDI SE, 61,200 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 18,370 miles Castrol Professional VW505 5W-40
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513234
09/11/17 12:09 PM
09/11/17 12:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Is this product available to you?
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513287
09/11/17 01:00 PM
09/11/17 01:00 PM
Norway
mmosberg Offline OP
mmosberg  Offline OP
Norway
I havent seen Clear Diesel here, but Hammerdown is quite popular. However, Hammerdown and most other additives which promises water to diappear does so by emulgating the into the diesel. But the water is still there and that is what I dont want into the fuel system. I then prefer the water to fall out in the water separators where I can drain it out. I have no reason to believe there are bacterias present. If I had I would use biocide poison to kill them and manually clean it out if severe.
Re: 2-Stroke oil in diesel for winter preservation? [Re: mmosberg] #4513358
09/11/17 01:55 PM
09/11/17 01:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: mmosberg
... most other additives which promises water to disappear does so by emulsifying the into the diesel.
But the water is still there and that is what I don't want into the fuel system.
I also believe products that force the water out of emulsification are best.
