stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
107 registered members (AZjeff, 2015_PSD, anndel, ArrestMeRedZ, AndyB, 17 invisible), 1,912 guests, and 65 spiders.
Topics286,431
Posts4,908,112
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open #4512715
09/10/17 09:43 PM
09/10/17 09:43 PM
California
Dave424 Offline OP
Dave424  Offline OP
California
This is from a 2010 Mazda 6 2.5L (Non-Skyactive)
25k miles on the filter, 3 oil changes. The oil filter was drained and re-filled with clean oil during each OCI. Oil used - M1 HM 10w-30.
The recommended filter size is 3614. However, 3600 and XG8A fit just fine - same gasket OD and bypass specs.
I opened the filter with a sharp chisel and a hammer. The can is made out of thin metal so it only took a minute. No need to spend money on a filter cutter for these. Otherwise, I used a hacksaw and pliers to rip out the metal mesh/filter media.
After making the first two cuts, I drained the remaining oil out of the side hole and it seemed much thicker/blacker than what came out of the oil pan. I guess the filter was doing its job of keeping the dirt on the dirty side. shrug
Enjoy cheers
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512731
09/10/17 10:00 PM
09/10/17 10:00 PM
snow and sun
oliveoil Offline
oliveoil  Offline
snow and sun
What happened to the media?
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: oliveoil] #4512733
09/10/17 10:01 PM
09/10/17 10:01 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
+1
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512750
09/10/17 10:20 PM
09/10/17 10:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Why ?
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512753
09/10/17 10:22 PM
09/10/17 10:22 PM
California
Dave424 Offline OP
Dave424  Offline OP
California
Nothing wrong with it that I can see. I just ripped it open to show the metal mesh and 2 layers of synthetic media. The black/brown contrast of the media shows how much dirt it is holding.
On a side note, I have not used synthetic oil in this car in a while 50k miles or so. 125k on ODO at this time.
I was not expecting the filter to be this dirty. I think the M1 did lots of cleaning and may have loaded the media as a result... the engine looks clean through the fill hole.
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512761
09/10/17 10:51 PM
09/10/17 10:51 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Now somebody is going to look at that and think the filter fell apart.
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512762
09/10/17 10:51 PM
09/10/17 10:51 PM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
Did you take the filter off every time to drain it? You could have compromised the gasket unless you changed it every time you took the filter off.
2004 Toyota Solara SE 2.4 2AZFE
187,000 miles
Castrol Magnatec Semi-Syn 5W30 3 quarts and 1 quart of Valvoline Syn-Power 5W30 that I had left over
Fram Ultra XG3600 oversize 1st run
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Merkava_4] #4512784
09/10/17 11:33 PM
09/10/17 11:33 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Only if it was a Purolator instead. laugh
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512790
09/10/17 11:38 PM
09/10/17 11:38 PM
California
mbacfp Offline
mbacfp  Offline
California
Great share. I feel like a fool...I just changed my Ultra at 9 months and 4,700 miles with my oil change...contemplated leaving on for next OCI but didn't. Those are amazing filters for sure. Thanks again for the share.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512800
09/11/17 12:01 AM
09/11/17 12:01 AM
California
Dave424 Offline OP
Dave424  Offline OP
California
The gasket was fine, I inspected it every OCI.
At the bottom of the can there was gritty residue which makes me wonder if some of it made it back into the engine when the filter went into bypass mode. The residue at the bottom did not appear to be metallic. The car burned about 1 quart every OCI. With M1 HM the consumption was significantly less. I think M1 may have dissolved some of the carbon in the piston rings and got them unstuck? I don't know how else to explain these results... any ideas?
I think the filter can handle even more miles without tearing. However, once the media gets loaded with dirt and becomes more restrictive, more unfiltered oil will go through the bypass valve.
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512807
09/11/17 12:22 AM
09/11/17 12:22 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
^^^ For those reasons it would have been better to run the filter 2x OCIs, and not disturb the filter. No real need to remove it to try and "flush it out", which probably did't do much anyway.
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512862
09/11/17 04:40 AM
09/11/17 04:40 AM
NY
demarpaint Offline
demarpaint  Offline
NY
That filter did great for 25K miles. Fram Ultra filters are all I have in my stash now.
God Bless Our Troops
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Dave424] #4512874
09/11/17 05:27 AM
09/11/17 05:27 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I can't honestly understand why anyone would run a filter for 25k.
The "thinking" man's friend.
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Lubener] #4512883
09/11/17 05:44 AM
09/11/17 05:44 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Because they are apparently up to the task. Because conservation. Because money. Because some filter changes send a stream of carcinogen down past your armpit. Because some people are getting old and it saves their back a little bit. Come on.
Re: Fram Ultra XG8A - 3 OCI & 25,000 miiles - Cut Open [Re: Lubener] #4512889
09/11/17 06:08 AM
09/11/17 06:08 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Me either, but I enjoy reading about them. wink
Page 1 of 3 1 2 3
