MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their electric OPE?
by dlundblad. 09/25/18 04:21 PM
Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
Peppz, Jfa02, ibsfusion, Fearcat707, Perseo
66069 Registered Users
100 registered members (Audios, 28oz, 53' Stude, Ablebody, ad244, 2004tdigls, 8 invisible), 1,548 guests, and 33 spiders.
Topics291,000
Posts4,854,146
Members66,069
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
Proper method to apply dielectric grease... #4512599
09/10/17 07:04 PM
09/10/17 07:04 PM
West Virginia
prs Offline OP
prs  Offline OP
West Virginia
... to electrical connections. I know my technique, but I may be a self taught idiot. So, does one slather the grease onto the conductors and plastic, rubber connector surfaces? Or does one only apply the grease to the conductors? Or just to the surface of the male connecter?
My way is to only apply to the male connector's surface that goes into the female, thus sealing the joint. I do not get any on the conductor pins. But which is correct?
prs
Even a fish can stay out of trouble if he keeps his mouth shut.
Re: Proper method to apply dielectric grease... [Re: prs] #4512601
09/10/17 07:06 PM
09/10/17 07:06 PM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
This should be a good one. Dielectric grease stops the flow of electricity. Therefore, do not put it directly on the conductors.
Re: Proper method to apply dielectric grease... [Re: leje0306] #4512645
09/10/17 07:59 PM
09/10/17 07:59 PM
New England
gathermewool Offline
New England
Huh? Most male and female connections make contact via friction. The connection will displace (scrape) away the grease; the grease will have zero effect on the connection. The benefit of dielectric grease, is that it will keep out moisture and prevent oxidation, allowing the contact to remain corrosion-free.
To the OP, it doesn't matter. I apply a small amount of dielectric grease to the female connector, so that the male will enter, the grease displaced, and a good seal formed.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter
Re: Proper method to apply dielectric grease... [Re: prs] #4512659
09/10/17 08:21 PM
09/10/17 08:21 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Re: Proper method to apply dielectric grease... [Re: prs] #4512660
09/10/17 08:22 PM
09/10/17 08:22 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Squirt some in either side of the connector and push 'em together
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Proper method to apply dielectric grease... [Re: leje0306] #4512661
09/10/17 08:23 PM
09/10/17 08:23 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
no
2005 Tahoe - 135k
Re: Proper method to apply dielectric grease... [Re: prs] #4512700
09/10/17 09:19 PM
09/10/17 09:19 PM
Georgia
AVB Offline
AVB  Offline
Georgia
lol My old boss put dielectric grease on the battery cables of his Semi, then it wouldn't start. He is a smart guy, but didn't realize just what dielectric meant. I had to clean the cables and explain to him what he did.
Re: Proper method to apply dielectric grease... [Re: leje0306] #4512701
09/10/17 09:22 PM
09/10/17 09:22 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Yay! At last a rationale for copper-based anti seize.
Re: Proper method to apply dielectric grease... [Re: gathermewool] #4512709
09/10/17 09:37 PM
09/10/17 09:37 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
This ^ Friction and clamping force will remove the grease from contact points leaving it to seal around them.
Re: Proper method to apply dielectric grease... [Re: prs] #4512756
09/10/17 10:33 PM
09/10/17 10:33 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Agree regarding friction and clamping force. This stuff has some number of volts/mil standoff of electricity. A connection has intimate contact, so effectively 0mil. So the conductivity is "infinite" (divide by zero), or in practice, no increase in resistance over surface asperities.
I watched the crc video. I suspect they just did what they do for effect... they put a LOT of grease in those connections, which would either glob out or cause the connector to pop back off.
Re: Proper method to apply dielectric grease... [Re: leje0306] #4512757
09/10/17 10:39 PM
09/10/17 10:39 PM
New England
Virtus_Probi Offline
New England
Air is also a good insulator, but connectors still work in it because the mating surfaces push it out.
Same with the grease.
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Proper method to apply dielectric grease... [Re: prs] #4512777
09/10/17 11:27 PM
09/10/17 11:27 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Since this thread is turning into false info about you shouldn't apply dielectric grease to electrical connectors, I'm going to nip this in the bud now.
Dielectric grease is designed specifically for electrical connections. It's purpose, to keep moisture and dirt out, It's a mechanical barrier. The reason it's used is if you were to use a conductive grease for electrical components, you would incur leakage current between electrical contacts, leading to electrolysis and corrosion. It keeps moisture out for the same reason. The stuff is designed specifically FOR electrical connections. Don't get hung up on the naming convention.
2005 Tahoe - 135k
Re: Proper method to apply dielectric grease... [Re: SnowDrifter] #4512833
09/11/17 01:48 AM
09/11/17 01:48 AM
CA
user52165 Offline
user52165  Offline
CA
Finally some sanity.
Re: Proper method to apply dielectric grease... [Re: prs] #4512842
09/11/17 03:10 AM
09/11/17 03:10 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Re: Proper method to apply dielectric grease... [Re: AVB] #4512896
09/11/17 06:34 AM
09/11/17 06:34 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
I've used dielectric grease on battery terminals for years and never had an issue.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Page 1 of 4 1 2 3 4
