Removing Broken Bathtub Drain
by Warstud
1 minute 19 seconds ago
Buffer Pads
by TheLawnRanger
6 minutes 9 seconds ago
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
37 minutes 36 seconds ago
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
37 minutes 38 seconds ago
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
38 minutes 22 seconds ago
DeWalt dcf887b 3spd impact driver
by JC1
42 minutes 28 seconds ago
Grit guard wash board
by JC1
54 minutes 8 seconds ago
Truck Lug Nut Spikes
by ET16
Today at 12:12 PM
Tier III fuel is on the way
by ZZman
Today at 11:53 AM
ACDelco Dexos 0W20 UOA
by DanMiller
Today at 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
Today at 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
Today at 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
Today at 10:18 AM
What to do when your Glock jams
by bigj_16
Today at 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
Today at 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
Today at 09:03 AM
Brisket flat on charcoal
by 04SE
Today at 08:45 AM
Weird Oil level question
by audia6
Today at 08:27 AM
DNA test and opening a can of worms
by WhyMe
Today at 08:11 AM
How to test a wheel speed sensor on the cheap?
by Nayov
Today at 06:23 AM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
98 registered (andyd, BAJA_05, aquariuscsm, Astro_Guy, AndyB, 9 invisible), 1658 Guests and 32 Spiders online.
65312 Members
67 Forums
285910 Topics
#4511663 - 09/09/17 04:13 PM Oil Dry Fill vs Service Fill
Pelican Offline
Loc: Ajax,Ontario, Canada
Can anyone tell me what's the difference between a dry oil fil and a Service oil fill !
Thanks
#4511666 - 09/09/17 04:24 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
danez_yoda Offline
Loc: texas
Dry oil fill is a new/rebuilt engine that never had oil in it. Service fill is when you empty the oil by the plug. Service will always leave some oil in the engne so the service capacity will be lower.
#4511667 - 09/09/17 04:24 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
OneEyeJack Offline
Loc: S California
Dry fill can be for a newly rebuilt engine. Once the engine has been filled there will always be some oil left behind no matter how long you leave the drain plug out.
Wet fill is the oil needed on the next oil change.
Sometimes both amounts are listed. Mostly not. The problem is that dipsticks are not really that accurate. Next oil change that I did (or watched someone do it) I'd use the amount called for and check the dipstick.
My 84 Civic calls for 3.7 quarts. I pour in 4 quarts. Also, I've had to replace the dipstick with a new one that is really for a later Civic so I just changed the oil and marked the new dipstick with one notch and the correct location.
#4511677 - 09/09/17 04:37 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
TheOilWizard Offline
Loc: US
Agreed
Edited by TheOilWizard (09/09/17 04:48 PM)
#4511732 - 09/09/17 05:54 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
oldhp Online   content
Loc: USA
Next oil change put in 1 qt less. Mark the dip stick, now you know where 1qt low exactly is.....add a qt, now you know exactly where full is. cheers
#4511763 - 09/09/17 07:07 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
LoneRanger Online   content
Loc: Midwest USA
Thanks
A service fill allows for residual oil trapped in the engine, which depending on engine size can vary, but for instance my Subaru it's about half liter of oil coating the inside of the engine and pooled here and there that doesn't drain out at an oil change.
'09 Subaru Forester ...................(QSED DEXOS1 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
#4511931 - 09/09/17 10:31 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
Charlie2015 Offline
Loc: Georgia
My car took about an extra quart when I put a new engine in it. Normal oil change fill is 4.5 qts. It took 5.5 qts for the initial "dry" fill.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
#4512122 - 09/10/17 09:21 AM Re: Oil Dry Fill vs Service Fill [Re: Charlie2015]
BHopkins Offline
Loc: Utah
This is why I'm always entertained by those that go to extreme measures at oil changes to drain every last drop of oil out of the engine. Short of a full tear down, they are never getting all the oil out at oil change.
The Service Manual for the 2.5 in my Outback shows a 0.9 qt between total capacity and oil change capacity. Perhaps that is similar for larger engines? Or can it be much more?
2013 Subaru Outback 2.5i - Royal Purple 0W-20 & NAPA Gold filter
2003 Oldsmobile Alero 3.4 - M1 5W-30 & NAPA Gold filter
#4512135 - 09/10/17 09:30 AM Re: Oil Dry Fill vs Service Fill [Re: oldhp]
demarpaint Offline
Loc: NY
You would have to start the engine and run it, then let the oil drain back to the pan to know the exact 1 quart low level. I'd suggest doing it on level ground and letting it sit overnight after you start it, then mark it. Add a quart, drive the car as you normally would, let it sit overnight and mark the full level. When establishing the 1 quart low level I'd run the car for about a minute, then let it sit overnight. Overkill, paranoid about driving around low one quart, that depends on the sump side. I like to play it safe. wink YMMV.
God Bless Our Troops
#4512217 - 09/10/17 10:52 AM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
klt1986 Offline
Loc: Southern VA
In my 2011 Toyota Tundra with the 5.7L the manual says an oil change is 8 quarts with a filter change. I have read the total oil capacity of the 5.7 is 9.8 quarts.
I'm convinced the total capacity on my truck is even more due to the factory oil cooler. Here is why I say that. When I do an oil and filter change, 8 quarts only reads half way between the add and full mark. It takes another 1/2 quart to get the oil up to the full mark.
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 0W-20
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
#4512286 - 09/10/17 12:23 PM Re: Oil Dry Fill vs Service Fill [Re: demarpaint]
Loc: USA
Yes, This goes without saying.
#4512287 - 09/10/17 12:25 PM Re: Oil Dry Fill vs Service Fill [Re: demarpaint]
Loc: USA
Yes, Starting, letting sit, checking.........adding 1qt goes without saying.
#4512305 - 09/10/17 12:51 PM Re: Oil Dry Fill vs Service Fill [Re: Pelican]
Pelican Offline
Thank You All for the replies!
