While changing the oil in my 1996 Ford F150 I noticed coolant dripping off the frame. This is a 302 V8 with 133,000 miles. I bought the truck used and I believe the water pump was changed in 2014 at 110,000 miles. (According to the Carfax I received)
The leak is NOT coming from the weep hole. It appears to be from the gasket itself. Researching this particular job indicates a problem with the bolts seizing into the timing chain cover and breaking when removal is attempted. The leak may be coming from the timing chain cover.
I just took another look, and I am 90% sure the timing chain cover is the source of the leak. This appears to be a Big Job.
Does anyone have any pointers?
