Acclaim radiator ?
by urrlord
1 minute 1 second ago
Understanding Idle Control Circuit
by artbuc
49 minutes 2 seconds ago
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Yesterday at 07:08 PM
Wheel says 50 mph max
by pda1122
Yesterday at 06:54 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
81 registered (ARCOgraphite, andyd, A310, 2004tdigls, ArrestMeRedZ, 04sierrashortbed, 7 invisible), 1321 Guests and 44 Spiders online.
65284 Members
67 Forums
285689 Topics
Page 1 of 2 1 2 >
#4511625 - 09/09/17 03:14 PM 2002 Yukon AC slugging
another Todd Offline
Loc: Lakeside CA
New to me 2002 Yukon 5.3L with rear air. Horrible noise upon acceleration with AC on. Tensioner is jumping up and down, and according to GM TSB #03-01-38-019A, it is caused by the compressor slugging. The compressor is very low on the engine and apparently liquid refrigerant and oil can pool in the compressor causing it to slug (hydraulic binding). I already replaced the belt and tensioner.
Is there any way to get it out of this condition without replacing the compressor like TSB says? What if I idle it for a long time, as it doesn't seem to do it at idle. Would that eventually pump the accumulated fluids out? Heat up the compressor?
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
#4511642 - 09/09/17 03:42 PM Re: 2002 Yukon AC slugging [Re: another Todd]
Chris142 Offline
Loc: Deplorable in apple valley, ca
No. The compressor is damaged internally and must be replaced. It will blow up and contaminate the whole system soon if you keep driving it. This is so common that I keep these parts in stock.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4511656 - 09/09/17 04:00 PM Re: 2002 Yukon AC slugging [Re: another Todd]
Loc: Lakeside CA
So how do I prevent this in the future?
2002 GMC Yukon
2015 Hyundai Accent
#4511671 - 09/09/17 04:28 PM Re: 2002 Yukon AC slugging [Re: another Todd]
NHGUY Offline
Loc: USA
Four Seasons/Comfort Temp sells a DeSlugger kit for Chrysler minivans and a few other vehicles.It pulses the coil for a few minutes when the AC is turned on,to prevent compressor explosions/case splitting.
#4511674 - 09/09/17 04:34 PM Re: 2002 Yukon AC slugging [Re: another Todd]
Kibitoshin Offline
Loc: Kaiōshinkai
Four Seasons makes a deslugging module that plugs into the A/C clutch magnet that pulses the engagement to slowly push oil out of the compressor before it fully engages.
http://www.4s.com/en/marketing/psp-solutions/the-deslugger/
I have one installed in my 02 Silverado since the truck barely gets used and as a preventative action to prevent slugging if it ever happens. A/C components are all original w/ 150,000mi on it so I gonna make it last.
Edited by Kibitoshin (09/09/17 04:36 PM)
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L - 170k mi
02 Chevy Silverado C1500 V8 5.3L 154k mi
#4511824 - 09/09/17 08:17 PM Re: 2002 Yukon AC slugging [Re: another Todd]
WyrTwister Offline
Loc: Texas
The GM cars I have worked on in the last few years , were older cars .
They had an accumulator thwr received the refrigerant / oil from the evaporator coil . Best I remember , the outlet was up high enough that the compressor pulled vapor off the " top " .
Surplus oil / refrigerant was held in the accumulator in " reserve " .
Wyr
God bless
#4511965 - 09/09/17 11:43 PM Re: 2002 Yukon AC slugging [Re: another Todd]
Chris142 Offline
move the compressor to the top smile...the oil and refrigerant settles in the compressor when its not running. When you turn the ac on it tries to compress the liquid and bang.
#4512072 - 09/10/17 08:15 AM Re: 2002 Yukon AC slugging [Re: another Todd]
WyrTwister Offline
Loc: Texas
Where is the accumulator located ? Higher or lower than the compressor ?
Best of luck , :-)
Wyr
God bless
#4512569 - 09/10/17 06:35 PM Re: 2002 Yukon AC slugging [Re: WyrTwister]
Chris142 Offline
Best of luck , :-)
higher...much higher
#4512574 - 09/10/17 06:40 PM Re: 2002 Yukon AC slugging [Re: another Todd]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
This is the first I have heard of this "slugging". My 2004 Silverado a/c never gave any problems. Any specific models this problem occurs in?
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
#4512593 - 09/10/17 06:56 PM Re: 2002 Yukon AC slugging [Re: xxch4osxx]
Kibitoshin Offline
Loc: Kaiōshinkai
Mostly in Tahoes and Suburbans with rear A/C.
#4512596 - 09/10/17 07:00 PM Re: 2002 Yukon AC slugging [Re: Kibitoshin]
xxch4osxx Offline
Ah ok, that explains it then, thanks!
#4512606 - 09/10/17 07:10 PM Re: 2002 Yukon AC slugging [Re: Chris142]
WyrTwister Offline
Loc: Texas
Best of luck , :-)
OK , best I remember the last Chevy Lumina sedan we had was a 3.1l V-6 , 1996 model . The A/C compressor was mounted down low on the engine .
Accumulator up high . Never had this problem , that I know of .
I am wondering if the truck in question is over charged with oil , or refrigerant of both ? Fan not blowing enough air and too much liquid refrigerant returning ? Something wrong with the expansion device & the evaporator coil being flooded ?
Wyr
God bless
#4512612 - 09/10/17 07:16 PM Re: 2002 Yukon AC slugging [Re: another Todd]
WyrTwister Offline
Loc: Texas
Tahoes and Suburbans with rear A/C ?
Suspect a lot of piping and " devices " mounted really low . Wonder if one area is especially pow & acting as a " P-Trap " .
Wyr
God bless
#4512690 - 09/10/17 09:13 PM Re: 2002 Yukon AC slugging [Re: xxch4osxx]
Chris142 Offline
all 4.8,5.3 and 6.0 gm trucks with the bottom mounted compressor. The ones with rear ac are very prone to it.
Page 1 of 2 1 2 >
