Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
26 registered (d00df00d, Buzzinhalfdozen, BoiseBound, Brad_C, discobob, Deltona_Dave, 3 invisible), 740 Guests and 30 Spiders online.
65258 Members
67 Forums
285504 Topics
Page 1 of 2 1 2 >
#4511618 - 09/09/17 03:02 PM Ceratec, MoS2, and other particle suspension.
SnowDrifter Offline
Loc: WA
I have a question that's been on my mind for a while now. You have these additives that rely on suspended particles to reduce wear numbers. But what I don't understand, is how do these fine particles, particularly in ceratec (since ceramic is pretty hard), not act as a microabrasive against soft parts like bearings?
#4511689 - 09/09/17 04:51 PM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
SubieRubyRoo Offline
Loc: Winchester, Indiana
I'm not extremely versed on liquid/solid interactions at the nanometer level, but when you're talking about something that measures in billionths of a meter, flowing through gaps that are thousandths of a meter, it sounds like driving a go-kart through an open jumbo jet hangar door.
#4511992 - 09/10/17 01:25 AM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
SnowDrifter Offline
Loc: WA
While I see your, logic, I'm still not super clear on how it works.
I'll use ceratec to talk about. Particle size there is .4 microns, or .016 thousands of an inch. And the outline below indicates that lubricating film can thin down to .2 microns, thinner than the particle size of this stuff. How does it not grind into and abrade the bearings and other surfaces?
http://www.sciencedirect.com/science/article/pii/S0924424708004834
#4512002 - 09/10/17 02:28 AM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
DdDd Offline
Loc: NY
Indian phd student... Suddenly they are mechanical engineer extraordinaire? How many engines has he designed?
At .2 microns your oil film is essentially gone. Bearing clearances typically offer more cushion.
Moly works. This ceratec business is probably something like graphite. Which technically could be called a ceramic by the marketing dorks.
Looking at liquidity site and MSDS offers nothing. So marketing babble it is then...
#4512189 - 09/10/17 10:24 AM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
Linctex Offline
Loc: Waco, TX
.4 microns does NOT equal .016"... prob closer to .00016"?
#4512204 - 09/10/17 10:43 AM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
SHOZ Offline
Loc: Illinois
Graphite, MoS2 and Boron Nitrate all have a similar molecular structure.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4512327 - 09/10/17 01:12 PM Re: Ceratec, MoS2, and other particle suspension. [Re: Linctex]
SnowDrifter Offline
Loc: WA
Thousandths sir grin
#4512865 - 09/11/17 04:52 AM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
Trav Offline
Loc: MA, Mittelfranken.de
Hexagonal boron nitride aka white graphite.
https://en.wikipedia.org/wiki/Boron_nitride
#4513044 - 09/11/17 09:39 AM Re: Ceratec, MoS2, and other particle suspension. [Re: Linctex]
UG_Passat Offline
Loc: NJ
1.574803149606299e-5 inches. you're off by an order of magnitude
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
#4513117 - 09/11/17 11:11 AM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
SHOZ Offline
Loc: Illinois
Here's a nice conversion program for about anything.
https://joshmadison.com/convert-for-windows/
#4513200 - 09/11/17 12:27 PM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
Virtus_Probi Offline
Loc: New England
Just remember 25.4 microns per mil.
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4513434 - 09/11/17 04:10 PM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
CT8 Offline
Loc: Idaho
Help if any would be in the metal to metal contact otherwise it is of no advantage.
"Don't let your preconceived notions get in the way of facts."Geoff Metcalf"
#4513451 - 09/11/17 04:36 PM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
SHOZ Offline
Loc: Illinois
The nano particles fill the nano ridges and crevices on the surface and bond to the metal I believe.
#4514336 - 09/12/17 03:35 PM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
Kamele0N Online   sick
Loc: Slovenia
I dont think that Moly bonds to anything.....its just...if its there when you need protection it will protect....
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4514339 - 09/12/17 03:42 PM Re: Ceratec, MoS2, and other particle suspension. [Re: SnowDrifter]
SHOZ Offline
Loc: Illinois
http://www.imoa.info/molybdenum-uses/molybdenum-chemistry-uses/lubricants.php
Molybdenum disulfide is used as a dry lubricant in, e.g. greases, dispersions, friction materials and bonded coatings.
Molybdenum-sulfur complexes may be used in suspension but more commonly dissolved in lubricating oils at concentrations of a few percent.
Molybdenum disulfide, MoS2, the most common natural form of molybdenum, is extracted from the ore and then purified for direct use in lubrication. Since molybdenum disulfide is of geothermal origin, it has the durability to withstand heat and pressure. This is particularly so if small amounts of sulfur are available to react with iron and provide a sulfide layer which is compatible with MoS2 in maintaining the lubricating film.
A number of unique properties distinguish molybdenum disulfide from other solid lubricants:
A low coefficient of friction (0.03-0.06) which, unlike graphite, is inherent and not a result of absorbed films or gases;
A strong affinity for metallic surfaces;
Film forming structure;
A yield strength as high as 3450 MPa (500 x 103 psi);
Stability in the presence of most solvents;
Effective lubricating properties from cryogenic temperatures to about 350oC in air (1200oC in inert or vacuum conditions).
Molybdenum disulfide will perform as a lubricant in vacuo where graphite fails.
A combination of molybdate and water soluble sulfides can provide both lubrication and corrosion inhibition in cutting fluids and metal forming materials. Oil soluble molybdenum-sulfur compounds, such as thiophosphates and thiocarbamates, provide engine protection against wear, oxidation and corrosion. Several commercial manufactures supply these additives to the lubrication industry.
Some molybdenum disulfide formulations are given in Table 1.
Page 1 of 2 1 2 >
