New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (addyguy, 2004tdigls, arowbat, 2002 Maxima SE, Astro14, 11 invisible), 2,191 guests, and 65 spiders.
Topics286,350
Posts4,906,901
Members67,608
Most Online2,967
Mar 10th, 2019
Mid '70s John Deere C110 Top Up Oil #4511589
09/09/17 02:07 PM
09/09/17 02:07 PM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Howdy! I checked the oil and it needs topped up. The oil was changed last year not under my supervision so I have no idea what weight oil or what oil brand is in it. Oil is still nice light brown, definitely less than 50 hours on it.
I have a jug of remaining Rotella T4 15w40 CJ4, would that be ok to top up with? I dislike mixing as much as the next person but I don't want to waste oil by dumping it.
Thank you!
Engine is a Kholer if that helps at all.
(I have no owner's manual for it or else I would have looked there)
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4511608
09/09/17 02:48 PM
09/09/17 02:48 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I am not familiar with any C110 tractor.
but in general that would be fine all regular engine oils are compatible.. just not optimal to mix.
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4511744
09/09/17 06:20 PM
09/09/17 06:20 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
probably a 30wt in there.
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4511776
09/09/17 07:30 PM
09/09/17 07:30 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Top it up !!!
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4511949
09/09/17 11:12 PM
09/09/17 11:12 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
JD made the 110 for many years, but never heard of a c110. I owned a 1964 110 for about 5 years. The Rotella will be fine, it's what I use in all my OPE.
Re: Mid '70s John Deere C110 Top Up Oil [Re: gman2304] #4512046
09/10/17 07:15 AM
09/10/17 07:15 AM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Hmmmm, I thought there was a C beside the 110. Could be wrong!
Thanks everyone, will top away!
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4512123
09/10/17 09:22 AM
09/10/17 09:22 AM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
My family had a ~1970 JD 110 for many years. That baby cut a LOT of grass and threw a lot of snow. The 10hp Kohler-K series in it will spec SAE30. IMO, today's 15w40 is a better choice for it. I know our old JD in it's later days would burn 1qt every 3 tanks of fuel or so and the fuel tank wasn't very large IIRC. Back then, it would get topped up with what ever we had on hand, which was typically just automotive 10w30 or 5w30.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4512308
09/10/17 12:53 PM
09/10/17 12:53 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
110s used to have an L as a prefix and now has a D, as in D110.
Note that they keep shifting the numbers themselves around.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Mid '70s John Deere C110 Top Up Oil [Re: dwendt44] #4512785
09/10/17 11:33 PM
09/10/17 11:33 PM
West Michigan
HM12460 Offline
HM12460  Offline
West Michigan
You are talking about the big box store (Home Depot etc...) model's. O.P. is talking about the much better built vintage machine from the 60's/early 70's. 2 totally different machine's.
2018 Chevy Colorado
1995 Ford Thunderbird
Re: Mid '70s John Deere C110 Top Up Oil [Re: HM12460] #4513176
09/11/17 12:05 PM
09/11/17 12:05 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Point being is that John Deere has used the '110' label on
several lines of product, even a much larger commercial tractor.
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4513182
09/11/17 12:12 PM
09/11/17 12:12 PM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Looking it up online on google images of the tractor, I found the exact model. It indeed doesn't say C110, but just 110.
The tractor looks like this (not as good condition as the paint has faded to a slightly less bright green lol):
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4514159
09/12/17 10:55 AM
09/12/17 10:55 AM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
The only bad part about the vintage 110's is the variator drive system. They had an iron beast 4spd gear drive, then you had additional ground speed options by selecting a different notch with the variator lever on the right side IIRC. This re-positioned the moveable sheave on the variator, moved the drive belt and gave you a different ground speed. Problem is, like all variator sheaves on OPE, the things lock up over time and are useless. Good thing about JDs is, it's totally user serviceable and parts can be had. Long story short. Leave the variator lever at max and don't touch it.
Re: Mid '70s John Deere C110 Top Up Oil [Re: JTK] #4514169
09/12/17 11:07 AM
09/12/17 11:07 AM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Yes, I leave the lever at max.
The tractor is pretty flawless in its long life. It has recently in the past 3 years needed repairs. It needed a new starter, surprised it lasted this long. Something was weird with the wiring for the tractor to start so a bypass push button starter was added. And all the belts were just replaced.
The only thing I complain about this tractor is that there must be something wrong with the clutch. It's a ghost clutch. I'll be riding along on a straight-level surface and the clutch will move by itself halfway pressed in, making the tractor move slower and I cannot force the clutch back towards me. I understand that it's supposed to slow down the tractor during descent down hills, but I don't think it should be doing that going on a flat surface. The clutch seems to have a mind of its own, presses part way in and then randomly back out, all throughout I mow the grass. I just keep it in 2nd gear and it takes awhile to move the acre lawn, but I don't need to touch the clutch practically the whole time. But if I use 3rd gear I use the clutch all the time (so I'd rather not). Never have needed to use 4th gear (way too fast) or 1st gear (crawling).
Re: Mid '70s John Deere C110 Top Up Oil [Re: JeepWJ19] #4514315
09/12/17 02:52 PM
09/12/17 02:52 PM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
That's exactly what our 110 would do when it had variator sheave problems. You eventually loose clutch pedal travel 100% of the time and nearly all ground speed. I'd pull the belts off the variator, actuate the lever and see if you're getting proper movement and no binding of the sliding/moveable sheave.
Re: Mid '70s John Deere C110 Top Up Oil [Re: JTK] #4514658
09/12/17 09:48 PM
09/12/17 09:48 PM
West Michigan
HM12460 Offline
HM12460  Offline
West Michigan
Yes, variator issue's. The center sliding sheave is binding up. If it has any "wobble" at all, it is worn out. The 110/112 and 200 series are old enough that good used ones are getting hard to find. The last I checked, they were still available from John Deere for about $200 iirc. Back on topic though, the old K series Kohler's do well on 15W-40 HDEO. Been using it for many years now. I tend to favor Mobil Delvac.
2018 Chevy Colorado
