My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned - I let someone else change my oil
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
97 registered members (Anduril, Astro14, 97K15004WD, 93cruiser, 15 invisible), 1,903 guests, and 44 spiders.
Topics295,131
Posts4,928,254
Members66,691
Most Online2,553
Oct 27th, 2018
Mixing some 0w20 and 0w30 #4511554
09/09/17 12:12 PM
09/09/17 12:12 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
How safe would it be to mix amsoil 0w20 (a little less then a quart) and another 3qts of Mobil 1 0w30 in TGDI Civic? Have some amsoil left and going up on the grade so was wondering if the mix will be fine. Appreciate y'alls opinions
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511556
09/09/17 12:17 PM
09/09/17 12:17 PM
New York
pbm Offline
pbm  Offline
New York
Shouldn't be a problem.
'Journalism is Dead'
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511560
09/09/17 12:22 PM
09/09/17 12:22 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Wonder what vis will it be (at 100). Guess in lower 10s?
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511566
09/09/17 12:35 PM
09/09/17 12:35 PM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
Mixing at a ratio of less than 1 qt of 0w20 to 3 qts of 0w30 likely won't make much difference at all. As far as 0w20 versus 0w30, it will be basically the same weight cold, at startup. Still best to use the oil type weight recommended by the OM. I have never ever seen an owners manual that recommendeds mixing different weights of oil. Best to go with what the oil weight the owner manual says IMO.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511578
09/09/17 12:56 PM
09/09/17 12:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Every time you change your oil, mixing occurs.
No problems at all from mixing.
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511591
09/09/17 01:08 PM
09/09/17 01:08 PM
Texas,USA
ATex7239 Offline
ATex7239  Offline
Texas,USA
I'm as frugal as the next guy, but it a quart of oil going to rock your bank account...
Why risk your engine's health over 6 bucks? My 2 cents.
'12 Buick Enclave 150,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 54,xxx
Oil � Don't know
Filter � Don't care
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511644
09/09/17 02:45 PM
09/09/17 02:45 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
API oils must be mixable with other oils, so you'll be fine. Some blenders actually encourage it so you can get a custom viscosity.
2017 Chevrolet Corvette Grand Sport
Re: Mixing some 0w20 and 0w30 [Re: pbm] #4511659
09/09/17 03:05 PM
09/09/17 03:05 PM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
+1. I wouldn't worry about it.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511673
09/09/17 03:33 PM
09/09/17 03:33 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
It's safe. But not optimal. Not because of the viscosity difference. But, that the add packs for those 2 oils are quite different. If I;m mixing different brands oils, I much prefer to use those that have similar add packs.
Amsoil VOA
Mobil 1 PQIA
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Mixing some 0w20 and 0w30 [Re: dparm] #4511680
09/09/17 03:41 PM
09/09/17 03:41 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
What blenders suggest this as good practice?? I am saying you are wrong about this. But I will say it is the first I have heard of this.
One aspect of note here as others have stated about this mixing.... Yes it can surely be done. However, all it really means is that API approved oils will not coagulate or form jello in your vehicle. It does not guruantee performance standards will be met or satisfied. This is true for the winter term rating part especially. Two different 0w's may well not equate real world 0w performance. For this reason it might not be advisable mixing two totally different oils if vehicle was going to experience the coldest limits of the winter rating.
Having stated this, I have a mix in my lady's Camry right now. It has 2 qts of 30 grade Warren and 1 qt of 30 grade Coastal, rislone and I just had to add 20ozs of Cam2 Superpromax the other day. It was put in July and it's coming out in just a bit. I don't mind mixing this up in the summer time. Coming up for the next run it will get Valvoline Maxlife Full Synthetic 5w30 only and a new oil filter. No bigtime mixing for winter time.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511775
09/09/17 06:28 PM
09/09/17 06:28 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Use the oil up it will be fine.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511781
09/09/17 06:41 PM
09/09/17 06:41 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Many of us took refraining from mixing as an article of faith for many years.
Along came Sonofjoe who in another thread basically debunked our concerns.
You'll end up with a thickish twenty with the mix you propose and the 0W qualification should still be met, as though that would actually matter in Texas.
Just as a matter of interest, is the Amsoil SSO or is it one of their API licensed products?
The API products are not too much different from M1.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Mixing some 0w20 and 0w30 [Re: ATex7239] #4511787
09/09/17 06:44 PM
09/09/17 06:44 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
How does ur engine suffer from less than a quart of non similar oil?.. wont make any difference. I dont think the car is able to figure out the difference.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511817
09/09/17 07:06 PM
09/09/17 07:06 PM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Mix away. You bought the oil. With good money. Use all of it up.
Re: Mixing some 0w20 and 0w30 [Re: parshisa] #4511826
09/09/17 07:20 PM
09/09/17 07:20 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
After its been pumped around in that engine for an hour and has gotten real warm it'll be mixed!
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
