Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
Car Sales Scammers on Letgo
by ZZman
06/17/18 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
06/17/18 04:10 PM
Which coil for a 2002 Focus Zetec?
by slacktide_bitog
06/17/18 04:07 PM
Blink -Roadside assistance, any experience?
by MoneyJohn
06/17/18 03:22 PM
Some garage art!
by ls1mike
06/17/18 03:12 PM
California Law
by PiperOne
06/17/18 02:37 PM
honda vs tyc a/c condenser?
by researcher
06/17/18 02:31 PM
To all the Fathers out there.
by rollinpete
06/17/18 01:37 PM
'14 Mercedes E350 Coupe - Castrol Edge 0w40
by FlyPenFly
06/17/18 01:08 PM
2007 Chrysler 4.0L SOHC engine - why 10w-30 req'd?
by 92saturnsl2
06/17/18 12:54 PM
you can see my crack when I dismount a tire
by eljefino
06/17/18 12:44 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
82 registered (330indy, 08z06, 2015_PSD, 4WD, 2009Edge, 12 invisible), 1509 Guests and 38 Spiders online.
65258 Members
67 Forums
285491 Topics
#4511450 - 09/09/17 10:34 AM Ford Escape Rear Diff Fill Level
Oscar_Ruitt Offline
Loc: Spokane, WA
The owner's manual on my '08 Ford Escape AWD states to fill the rear diff "to 1/4 inch to 9/16 inch below bottom of fill hole." So, if I fill until it comes out the hole is it overfilled and I need to take some out?
2012 Mazda5 - 0w20 cheaptest synthetic, 6 MO OCI
2013 Grand Caravan - 5w20 cheapest synthetic, 10k/OLM OCI
#4511461 - 09/09/17 10:47 AM Re: Ford Escape Rear Diff Fill Level [Re: Oscar_Ruitt]
andyd Offline
Loc: Marshfield , MA
I would, Ive discovered that they leak less when a bit low.
Thick oil is better grin2
#4511470 - 09/09/17 11:08 AM Re: Ford Escape Rear Diff Fill Level [Re: Oscar_Ruitt]
old1 Offline
Loc: Columbus Nebraska
If it already leaks some, I would just leave it in there, and the leak will bring it to the proper level soon enough. Just take longer till you have to add again.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
#4511472 - 09/09/17 11:10 AM Re: Ford Escape Rear Diff Fill Level [Re: Oscar_Ruitt]
Oscar_Ruitt Offline
Loc: Spokane, WA
It doesn't leak I am just planning to do a fluid change.
#4511523 - 09/09/17 12:34 PM Re: Ford Escape Rear Diff Fill Level [Re: Oscar_Ruitt]
Kuato Offline
Loc: Colorado
Just fill until you can reach it with your pinky finger. If it's overfilled, put a drip pan under it, grab a beer, and wait for it to stop dripping
(or siphon some out)
Thick vs Thin test: 15k / 43k miles complete
#4511573 - 09/09/17 01:49 PM Re: Ford Escape Rear Diff Fill Level [Re: Kuato]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
^ This. Stick your finger in there, you will have to bend your finger to fit it in the hole, when you feel the tip of your finger is wetted by the lubricant level, stop filling.
Next time you think of it, go to a Veterinary Supply vendor, buy some honkin' syringes (you don't need the needles, although they can come in handy, especially if you need to glue something tricky) and some tubing to fit the end, and you can remove lubricants that are over-filled in pretty much any area of the vehicle, reasonably quickly.
You can get syringes designed for the purpose at automotive stores or woodworking supply shops as well, but they are a) more expensive and b) not as well made (tend to leak past the plunger).
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4511790 - 09/09/17 07:45 PM Re: Ford Escape Rear Diff Fill Level [Re: Oscar_Ruitt]
zeng Offline
Loc: Malaysia
I would've intentionally filled it to the brim ...... in particular in rear differentials.
It is overfilled indeed, but I don't see it as posing problem. OTOH, I see some 'slight' advantage in 'slight' oil quantity/volume increase within differential housing.
#4512871 - 09/11/17 05:19 AM Re: Ford Escape Rear Diff Fill Level [Re: zeng]
Lubener Offline
Loc: N.Ohio
Won't make any difference. The oil will get picked up, slung around and everything will be fine. As long as you can feel the level in there with your finger, you are fine.Don't make a science project out of it.
Edited by Lubener (09/11/17 05:20 AM)
The "thinking" man's friend.
#4512908 - 09/11/17 06:58 AM Re: Ford Escape Rear Diff Fill Level [Re: Oscar_Ruitt]
ATex7239 Offline
Loc: Texas,USA
It's sounds, based on your description, to be a bit full. Drain some out and use the pinky method stated above and you'll be fine.
Diff's aren't as particular about over filling like a transmission, brake, or power steering system.
'12 Buick Enclave 139,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 42,xxx
Oil – Don't know
Filter – Don't care
#4514048 - 09/12/17 08:53 AM Re: Ford Escape Rear Diff Fill Level [Re: old1]
Bgallagher Offline
Loc: Boston, MA
+1 Just make sure the vehicle is on level ground.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
