Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Age of first drive
by madRiver. 09/25/18 08:02 AM
Please, maintain your tires properly
by 53' Stude. 09/25/18 06:58 AM
Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
95 registered members (4WD, Asterix, 2013ecof150, Astro14, 2009Edge, 9 invisible), 1,429 guests, and 43 spiders.
Topics290,975
Posts4,853,619
Members66,063
Most Online3,590
Jan 24th, 2017
Ford Ranger Trans Fluid #4511165
09/08/17 08:43 PM
09/08/17 08:43 PM
Perrysburg, OH
Buckeyeman Offline OP
Perrysburg, OH
I have a 2010 Ford Ranger 5-speed manual that calls for Mercon V fluid in trans. Just wanted to know if anyone has put Pennzoil Synchromesh in insted, and how did it perform?
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511174
09/08/17 08:59 PM
09/08/17 08:59 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
That's a GM & Chrysler fluid. Why not just get some Supertech Mercon V at Walmart? It's only $4.27 a quart. That's half the price of the Pennzoil.
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511187
09/08/17 09:13 PM
09/08/17 09:13 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Mercon V is not ideal for this trans.
I use Synchromesh or equivalent fluids. My truck has some Synchromesh and Valvoline MTF in it now.
You won't notice much/any difference on a nice shifting trans, but if there is an issue, Synchromesh usually helps in M5ODs.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 216K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 199K miles
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511225
09/08/17 10:55 PM
09/08/17 10:55 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I've used it in 2 rangers, one had no real change in shifting, the other was somewhat improved. I'll use it again the next time I change the trans fluid in that truck. I'm sure it's an upgrade over merconV.
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511355
09/09/17 07:27 AM
09/09/17 07:27 AM
New York
pbm Online content
pbm  Online Content
New York
IMO Mercon V is a compromise fluid in this application.
I would visit the Ranger forums and see what others are using.
If Redline makes a suitable fluid, that's what I'd use.
'Journalism is Dead'
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511359
09/09/17 07:40 AM
09/09/17 07:40 AM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
I've used Redline D4 and RP Synchromax in my Ranger clone.
Same transmission once specified Mercon too at one time, I would rather have a dual purpose (d4) or MTF fluid as a starting point
2004 Prius; 97K ML Syn 5W-30
2007 Yaris 71K 0w-40 Castrol
2006 B2300;130K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Ford Ranger Trans Fluid [Re: pbm] #4511392
09/09/17 08:37 AM
09/09/17 08:37 AM
Perrysburg, OH
Perrysburg, OH
I did visit the Ranger forum, and got 10 different opinions. I've heard so many good things about the GM/Pennzoil fluid that I thought I'd try it, but I don't want to damage anything either. I once drained out the OEM fluid and put in Amsoil ATF and the dealer had to rebuild the transmission under warranty.
Re: Ford Ranger Trans Fluid [Re: simple_gifts] #4511440
09/09/17 10:15 AM
09/09/17 10:15 AM
Pittsburgh, PA
JohnnyO Offline
JohnnyO  Offline
Pittsburgh, PA
When I had my stick Ranger I used both Mobil 1 ATF and Redline D4. Still use M1 ATF in the transfer case of my Explorer. Have D4 in the stick tranny of my son's Mustang and it shifts real nice.
Steeler Nation does not have to travel. We're already there.
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511646
09/09/17 03:48 PM
09/09/17 03:48 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Any of the MTF's below should work:
6.9 to 7.9 cST (ATF-like Viscosity); 70W75 :
Royal Purple's Synchromax
Ravenol MTF-2
Honda MTF
VW part number G052512A2
GM Manual Transmission and Transfer Case Fluid
BMW (Pentosin MTF 2) MTF-LT-1, 2 ,3
Tutelo (Petronus, Italy, Product Code 1402)
Pentosin Pro Gear 70W75 (Australia)
Pentosin FFL-4
Redline Power Steering Fluid
8.0 to 9.8 cSt Viscosity; 75W80:
The next higher viscosity MTL would be Castrol Syntrans V FE 75W-80 8.0cSt
Redline DCTF Dual Clutch Transmission Fluid (8.1 cSt)
The next higher viscosity MTL would be BG Synchroshift II (8.2 cSt)
The next higher viscosity is Mopar Type MS-9417 MTL 9.0cSt
Valvoline MTF Part Number 811095 9.2 cSt
The next higher viscosity MTL would be Pennzoil Synchromesh 9.3 cSt
Reading is fundamental; understanding is not a given ability.
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4511991
09/10/17 01:21 AM
09/10/17 01:21 AM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Synchromesh or a similar MTF definitely will not damage it. I heard stories years ago of M5ODs being damaged from being filled with gear oil. Early Rangers with Mitsubishi and Toyo Kogyo transmissions used gear oil, and those transmissions were used along with the M5OD from about '87-'91. Apparently some owners/shops would refill M5ODs with gear oil by mistake. All of that is anecdotal though.
The M5OD is not very picky and not very refined no matter what you put in it. Different fluids seem to work better or worse in different trucks used in different conditions. No harm in trying an MTF...if you don't like the way it shifts (doubtful), you can always change back to ATF. The M5OD came out in 1987, right around the same time Mercon was introduced, so Ford probably wanted to consolidate fluids on their assembly lines. Mercon could be used to fill a lot of things on a Ranger, Explorer, Bronco, Aerostar, E-Series van, or F-Series truck, including the M5OD. It was a good general purpose trans/PS/t-case fluid, but some M5ODs do better with something else. Mercon V was never really meant for the M5OD. It was introduced in 1996 or 1997 to correct issues with (I think) the 4R70W auto specifically, then was spec'd for other transmissions, including the ones used in Rangers.
Re: Ford Ranger Trans Fluid [Re: MolaKule] #4512056
09/10/17 07:39 AM
09/10/17 07:39 AM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Ravenol MTF-2
Honda MTF
Pentosin FFL-4
Is this good stuff? This is what I use...
https://www.walmart.com/ip/Super-Tech-Automatic-Transmission-Fluid/20573820
or is this better?
https://www.walmart.com/ip/Valvoline-Max...Gallon/15125768
Thanks...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Ford Ranger Trans Fluid [Re: 01rangerxl] #4512164
09/10/17 09:55 AM
09/10/17 09:55 AM
Perrysburg, OH
Perrysburg, OH
I've searched all over the net regarding this subject, and obviously several opinions. There seems to be a lot of people endorsing Redline D4 atf. There was a lot endorsing Royal Purple Synchromax and Max ATF too. The only complaint was people that live in the north experienced harder shifting with RP Synchromax in cold weather. I think I'm going to pass on the Pennzoil Synchromesh cause I don't want to have this problem in the winter. I'm kind of leaning toward the Redline D4. I want to thank everyone for their input. I just don't want to have to have the transmission rebuilt again for something I caused.
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4512246
09/10/17 11:31 AM
09/10/17 11:31 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
My two choices would be:
Redline Power Steering Fluid (6.9 cSt)
The above fluids contain an FM and AW additive package commensurate with MT internals.
Redline D4 is not designed for MTF's, regardless of their "suggested" coverage for MT's.
Re: Ford Ranger Trans Fluid [Re: MolaKule] #4512359
09/10/17 02:10 PM
09/10/17 02:10 PM
Perrysburg, OH
Perrysburg, OH
Forgive me for not knowing, but what is FM & AW? Redline's website says to use D4. It's got to be better than Motorcraft Mercon V.
Re: Ford Ranger Trans Fluid [Re: Buckeyeman] #4512989
09/11/17 08:36 AM
09/11/17 08:36 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
FM is the Friction Modification chemistry necessary for proper engagement of synchronizer assemblies and shifter forks. Its main duty is to provide the correct dynamic friction coefficient for engagement and release at the clutch surfaces.
AW is the Anti-Wear chemistry necessary to reduce wear in bearings, gear teeth, and shifter forks.
MTF's
Again, Redline D4 is not designed for MTF's, regardless of their "suggested" coverage for MT's.
