oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
102 registered members (97f150, aba4430, ammolab, 4WD, aquariuscsm, anndel, 13 invisible), 1,783 guests, and 40 spiders.
Topics295,018
Posts4,926,083
Members66,666
Most Online2,553
Oct 27th, 2018
2003 Malibu coolant tank system #4510734
09/08/17 09:23 AM
09/08/17 09:23 AM
Peace valley, Missouri
Fitter30 Offline OP
Fitter30  Offline OP
Looking for a explanation on how the systems works, mainly the coolant tank with all hoses. I know how how the older systems work with a radiator cap.
Re: 2003 Malibu coolant tank system [Re: Fitter30] #4510784
09/08/17 10:21 AM
09/08/17 10:21 AM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Coolant tank is pressurized as part of the coolant system with a pressure cap as normal.
While running, a portion of the coolant(and air along with it) circulates through the reservoir and is more effective at self-bleeding. I tend to prefer those systems, they're easier to bleed and generally require no special bleeding tools or funnels.
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: 2003 Malibu coolant tank system [Re: Fitter30] #4510816
09/08/17 11:02 AM
09/08/17 11:02 AM
PA
Chester11 Offline
Chester11  Offline
PA
Just curious - was this a design driven in part by Dexcool or something else?
I've had a bunch of GM cars that use Dexcool - and noticed the later models seemed to have pressurized tanks, and less sludge.
Re: 2003 Malibu coolant tank system [Re: Fitter30] #4510820
09/08/17 11:07 AM
09/08/17 11:07 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Dexcool does not like to be exposed to air. The old style system where the over flow bottle is vented to atmosphere would expose the coolant to atmosphere on a regular basis. The new pressurized over flow tank eliminates this problem.
Re: 2003 Malibu coolant tank system [Re: Fitter30] #4510879
09/08/17 12:30 PM
09/08/17 12:30 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Ford has been doing this too for a long time, my 99 Crown Vic had that kind of system - but with regular green coolant, they hadn't switched to extended life yet. Anyway, I think it's six of one, half a dozen of the other in terms of which one is "better"
2010 Ford Escape 2.5~91K Miles: AMSOIL SS 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL
Re: 2003 Malibu coolant tank system [Re: Fitter30] #4510910
09/08/17 01:10 PM
09/08/17 01:10 PM
Fitter30 Offline OP
Fitter30  Offline OP
system uses dexcool, just replaced the radiator found the one small tube off the top of the tank was plugged solid at the radiator and the tank had a crack at top mounting tab. so with the line block and the crack just trying to rigged this out. water temp seemed to run ok 110*
Re: 2003 Malibu coolant tank system [Re: Chester11] #4510949
09/08/17 02:06 PM
09/08/17 02:06 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
I think it also has to do with the highest point in the cooling system no longer being on the radiator cap. This kind of system was also in the 90s Taurus despite them not using Dexcool.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: 2003 Malibu coolant tank system [Re: Fitter30] #4510984
09/08/17 02:39 PM
09/08/17 02:39 PM
Fitter30 Offline OP
Fitter30  Offline OP
runs at 210* not 110*
