Composite socket for fork suspension nuts
As I was using my 22mm hex 3/8 drive socket to adjust preload on the forks today I thought to myself, "Self, wouldn't it be nice if someone made a socket this size in composite poly or something so you wouldn't tink up your brand new virgin looking pre-load nuts ... "
Alas. But no. Not that I can find.
I just put some masking tape between the nut and the socket to protect from marring. But good point nonetheless!
Alternatively if you have access to a 3d printer you can make your own sized to your needs. Or there are places where you can send them a model and they'll print it for you
If you have an old t-shirt, bed sheet, or whatever that's thin fabric, you can put that over the adjuster, and still fit a socket on. Except now the you won't damage the adjuster, or other nuts/bolts you don't want to mar.
If you were doing this all the time, I'd invest in socket inserts, etc.
Originally Posted By: Kira
Glock sockets...seen 'em on Amazon.
Amazon search on this turns up nothing.
A paper towel works too.
