Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
116 registered members (AdditiveOCD, 97prizm, Astro14, Alfred_B, aircooled, 8 invisible), 2,237 guests, and 57 spiders.
Topics286,072
Posts4,902,033
Members67,556
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Battery Chargers - Garage Fun and Results #4510508
09/07/17 11:44 PM
09/07/17 11:44 PM
Great White North.. eh
webfors Offline OP
webfors  Offline OP
I've gone a little OCD the past two months on chargers, since I had to replace my old motomaster charger that finally died. I dove into manuals, forums, and ultimately purchased several to observe their behaviors for myself.
Battery Chargers observed:
Noco Genius 3500
CTEK MUS 4.3
Erayak c9002
Schumacher SC3
Schumacher SC1
Battery Tender Junior
Out of all these chargers I've only returned one, the Noco. If you buy one I would highly recommend attaching a voltage meter to it for the first dozen cycles and watching carefully. I was surprised how inconsistent it was. The caution was raised when it was solid green on a wet cell, indicating the charging cycle was completed, and it was still pumping 14.88 volts. I left it for an hour hoping it would drop back to the previously observed 13.8 volts, it did not. The manual states when the solid green light is on the charger goes into maintenance mode, which should only monitor and charge when voltage drops below a certain threshold. My observations are that, in previous cycles in maintenance mode it was keeping a consistent 13.8 volts, indicating it was behaving similar to the CTEKs which hold a consistent 13.6 in stage 7 for up to 10 days before going into maintenance mode. The 'repair' mode also pushes a steady current of 15.8 volts for hours at a time. I could hear the boiling on the wet cells. Regardless of the 14.88v event, and the repair mode current, the observed behavior does not match the algorithm phases and status LEDs as explained in the manual.
That being said, the noco is a nice looking charger, with the parts/connectors and charger itself appearing to be very high quality. Maybe I got a bad one, or maybe the Noco was so wicked smart that it out smarted me and there is some explanation that reconciles the behavior of this charger.
I have spent hours watching and tracking the voltage patterns mapped against the documented algorithms for each charger. The most consistent, after dozens of charge cycles on multiple battery types, is the CTEK. The CTEK behaves exactly as the algorithm is explained in the manual. No deviation, ever.
The best value? The Schumacher chargers. $10 for a battery maintainer (SC1) and $20 for an 8 amp smart charger that both behave exactly as expected and get the job down well and safely. Both smart chargers, with simple 3/4 phase algorithms. The downside is they have fixed cables. So there is no option for interchangeable connectors. If you need ring terminals you will either need to splice in an SAE connector, or use another charger.
Of mention: the Battery Tender Junior algorithm was not what I was expecting. I was expecting it to behave just like the Schumacher SC1, which turns off all current immediately once it reaches 14.2 volts and only provides current again when voltage drops to 12.7 volts. You can clearly see the quick voltage drop from 14.2 when the SC1 turns off. The Tender Junior pumps a relatively steady current with the voltage bouncing between 14.2 and 14.6 initially and narrowing down to 14.5-14.6 volts for several minutes before it goes into maintenance mode. The voltage drop off was also noticeably slower indicating that it is potentially providing a small current to avoid back drain.
Anyway, it has been a fun learning experience for the reasonable price of approximately $200 (once the Noco was returned). I also now have a fleet of chargers, some of which I'll be lending to family/friends (hint: it won't be the CTEK), and hopefully this post will be helpful to others.
Happy Charging :P
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510517
09/08/17 12:22 AM
09/08/17 12:22 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Interesting information.
I am debating a tender for my bike.
I plan on riding regularly (never gets too cold for too long here), but may go a week or two without riding, so want to make sure it is topped up all the time.
Battery already had leads on the battery from previous owner, but no charger. I have an AGM battery so leaning toward the Battery Tender Plus (have read the Jr model is not quite up to par for AGM batteries).
I have had good luck with my Schumacher SE-1275A with many different batteries, and have hooked it up to the bike to make sure it is fully charged.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510518
09/08/17 12:25 AM
09/08/17 12:25 AM
CA
CharlieBauer Offline
CA
Thanks for doing that.
How would you compare the CTEK and the Schumacher? $20 is very good value for an 8 amp charger compared to the CTEK which is 4.3 amps.
I have the CTEK and am happy with it but ideally would have gotten a 20 amp charger since I have AGM batteries which I understand like the high amps.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510530
09/08/17 02:16 AM
09/08/17 02:16 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Interesting write up, but current is measured in amps and voltage is in volts. Did you ever measure the current or just the voltage? If you just did the voltage, there's no way to be certain about the current and the amps it was pushing unless you also measured watts at the outlet, but then there'd be losses between the outlet and the other end of the charger.
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510563
09/08/17 05:48 AM
09/08/17 05:48 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
I've had my Schumacher for over 15 years now it has worked well for me.
2004 Corolla 129892
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Battery Chargers - Garage Fun and Results [Re: Wolf359] #4510565
09/08/17 05:52 AM
09/08/17 05:52 AM
North Carolina
Egg_Head Offline
Egg_Head  Offline
North Carolina
+1
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
Re: Battery Chargers - Garage Fun and Results [Re: CharlieBauer] #4510604
09/08/17 07:13 AM
09/08/17 07:13 AM
webfors Offline OP
webfors  Offline OP
Two different chargers that I will use for different use cases. I'll use the Schumacher for my deep cycle RV batteries when I want a quick turn around. I will bring it with me on our adventures for when I have the pleasure of finding a 120v socket. I typically have two batteries with me when we're off grid. Also, since it has fixed cables I won't be using it as a long term maintainer, even though it is perfectly capable doing so.
Re: Battery Chargers - Garage Fun and Results [Re: Wolf359] #4510610
09/08/17 07:22 AM
09/08/17 07:22 AM
webfors Offline OP
webfors  Offline OP
Agreed, I should have used'for 15.8v'. The current is fixed on the Noco's repair mode at 1.5 amps.
I have an inline meter on the way and will be performing more observations when it comes in which will include all three variables. However, voltage tells 9/10ths of the story with "smart" chargers, since they are constantly changing current to hit and keep specific voltages. It will definitely be interesting to document the current is as exactly as spec'd. I'm looking forward to seeing the CTEK phase 4 current be modified. It keeps such a consistent voltage while decreasing current.
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510733
09/08/17 10:21 AM
09/08/17 10:21 AM
Great Lakes
Quattro Pete Offline
Great Lakes
That does sound odd.
I have the G7200, and the few times that I monitored voltage, it was sitting around 13.6V towards the end of the charging cycle (100% LED still blinking), and then dropped to 13.0V once the 100% LED turned solid.
This was when using the "Norm" setting, not the "AGM/Cold". Ambient temp was around 70F.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Battery Chargers - Garage Fun and Results [Re: Quattro Pete] #4510749
09/08/17 10:39 AM
09/08/17 10:39 AM
webfors Offline OP
webfors  Offline OP
Agree it was strange. The algorithm, as I understood in the manual, was that a solid green LED indicates a fully charged battery and current is stopped until the voltage drops to a specific threshold. This was never observed in any cycle. It either pushed 13.8 consistently, or 14.88 as mentioned above (which threw the caution).
The NOCO manual is well written, with two obvious gaps. First the charging steps -> LED behavior mapping. I have no idea what charging step the charger is in when looking at the LEDs. Unlike the CTEK which identifies the steps directly via the LEDs on the top of the charger. This allows a direct one to one mapping of LED -> Step mapping and allows me to accurately confirm the algorithm behaves as documented. Second, while the max voltage for each mode is identified, it does not identify the thresholds that trigger a maintenance cycle. Since I did not observe the charger ever cutoff (as per the manual) I was not able to document what the bottom threshold is. Most likely between 12.6 and 12.8 volts like every other smart charger.
Looking at the modes/voltages explained in the manual, it's as if the charger was stuck in a 12v COLD/AGM (14.8 volts) active charging mode even though the LED stated it was completed and should have been in maintenance mode.
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510751
09/08/17 10:41 AM
09/08/17 10:41 AM
webfors Offline OP
webfors  Offline OP
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510781
09/08/17 11:18 AM
09/08/17 11:18 AM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Thanks for all of this helpful information. Is CTEK, from HF(https://www.harborfreight.com/automatic-battery-float-charger-69955.html)?
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Battery Chargers - Garage Fun and Results [Re: maverickfhs] #4510794
09/08/17 11:38 AM
09/08/17 11:38 AM
Great Lakes
Great Lakes
Your link shows Centech.
This is the CTEK the OP was talking about:
http://a.co/dlAphkr
Re: Battery Chargers - Garage Fun and Results [Re: webfors] #4510798
09/08/17 11:41 AM
09/08/17 11:41 AM
Great Lakes
Great Lakes
Yeah, mine doesn't exactly do that either. When I check with my clamp meter, it looks like it's sending 1.5A pulses every 2 seconds or so. My clamp meter may not be quick enough to read it accurately, but there are definitely some current pulses going on.
Voltage is sitting at around 13.0-13.1V.
I agree, by looking at the lights, you don't know what it's doing... maintenance, or optimization, or something else.
Re: Battery Chargers - Garage Fun and Results [Re: Quattro Pete] #4510799
09/08/17 11:42 AM
09/08/17 11:42 AM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
http://a.co/dlAphkr
Makes sense, thanks for the clarification smile
Page 1 of 5 1 2 5
