Originally Posted By: dave123
Originally Posted By: ARB1977
UOA. Might be the first to have a uoa done on a cat pump.
+1 and be only way to know I'd just drain and refill if worried and keep on the dot not top of the dot to be honest looks fine to me
As much as I admire your suggestion, no. If he can get a new unit, as he should per the pump's manufacturer, he should do so. If he bought the unit used or has owned it for several years, sure.. I agree with you 100%. Unless he can get the pressure washer company to compensate him for the cost, (doubtful.) I wouldn't do a thing aside from an oil change as previously mentioned.
Dumping $25+ into something that is potentially faulty is a bad idea IMO.
