Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (AndyB, Astro_Guy, avi1777, alarmguy, 69Torino, 2015_PSD, 6 invisible), 800 guests, and 52 spiders.
Topics286,106
Posts4,902,673
Members67,563
Most Online2,967
Mar 10th, 2019
50% STP? #4510068
09/07/17 02:49 PM
09/07/17 02:49 PM
Tug Hill, NY
Corelokt Offline OP
Corelokt  Offline OP
Tug Hill, NY
What's the heaviest percentage of STP I can run with 15-40 oil in a 6.5 diesel with very low oil pressure?
86 CUCV. 6.5L. Level-3 4L80. NP205. 9-16 14 ply tires, HX35/40 turbo. WMI. 5" exh. ARP studs heads & crank. Cooling upgrades. Rattle can camo.
Re: 50% STP? [Re: Corelokt] #4510084
09/07/17 03:01 PM
09/07/17 03:01 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Fix it so it has proper oil pressure? Then 0% STP
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: 50% STP? [Re: Corelokt] #4510093
09/07/17 03:11 PM
09/07/17 03:11 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Do you know why it doesn't have good oil pressure?
STP might be a stop gap measure if you have a bearing that's shot. but if it's caused by something like a pickup tube issue or a stuck bypass valve on the oil pump, thick oil will make the issue far worse. You won't have hardly any flow.
What's your oil pressure anyway? How did you diagnose the issue?
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: 50% STP? [Re: Corelokt] #4510098
09/07/17 03:19 PM
09/07/17 03:19 PM
Tug Hill, NY
Corelokt Offline OP
Corelokt  Offline OP
Tug Hill, NY
Yes, cam bearings. In a 6.5 the valley is closed and entails pulling the motor, turning it upside down and maybe crank removal. Water pump, timing cover, both alt brackets, steering pump bracket... Not happening anytime soon.
Re: 50% STP? [Re: Corelokt] #4510099
09/07/17 03:20 PM
09/07/17 03:20 PM
Tug Hill, NY
Corelokt Offline OP
Corelokt  Offline OP
Tug Hill, NY
So, back to my question, how high of a percentage can it be run at?
Re: 50% STP? [Re: Corelokt] #4510108
09/07/17 03:28 PM
09/07/17 03:28 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
I have used STP in a lot of worn engines, but I don't think I would go much above 20% in 15/40 oil. Also depends on the ambient temp.
come winter, not so much.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: 50% STP? [Re: Corelokt] #4510153
09/07/17 04:24 PM
09/07/17 04:24 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
If the below pic accurately represents the oiling system, then I'd be loathe to do it...looks like the mains are the last to get oil, around the backs (hopefully) of the cam bearings...then the mains feed the big ends.
Go 20W50, see if it helps, then thicken a little from there if you think it's helping...in incrememnts. if you like.
But I think going thicker than that will hasten the demise of other componentry.
Re: 50% STP? [Re: Corelokt] #4510197
09/07/17 05:00 PM
09/07/17 05:00 PM
USA
NHGUY Offline
NHGUY  Offline
USA
And heaven forbid it gets cold out...
Re: 50% STP? [Re: Corelokt] #4510283
09/07/17 06:41 PM
09/07/17 06:41 PM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
What is the total oil capacity. I would not hesitate to run (and have) at least 1 full quart (2 bottles) but would be a bit careful after that.
STP is old school VII...I have experienced easier starts with my cranky Jeep with STP in the sump. When I was a kid every oil change got a can of STP, and we were using 10w40 year round in South Dakota! Brrrr......
2018 VW Passat GT VR6 - 6k - Valvoline MST 5w40 - VW OEM filter
2012 KIA Sedona 96k - PP HM 10w30
2009 Ford Focus 135k - Supertech FS HM 5w30
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: 50% STP? [Re: Corelokt] #4510298
09/07/17 06:56 PM
09/07/17 06:56 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I have to ask-have you put a mechanical pressure gauge on it? The factory setup isn't very accurate, the senders aren't the greatest-I'm on my 3rd AC Delco one on my '93 6.2. I've put lots of non-diesel rated oils in both my 6.2 & 7.3 (although they were usually at least CF)-might be time for some Delo 400 straight 50-if you can find it.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 50% STP? [Re: Corelokt] #4510363
09/07/17 08:01 PM
09/07/17 08:01 PM
Florida
chainblu Offline
chainblu  Offline
Florida
I think Lucas (which is a similar product) says you can go up to 25%. So.... I'd say 25%.
Re: 50% STP? [Re: Corelokt] #4510430
09/07/17 09:16 PM
09/07/17 09:16 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
How did you manage to take out a cam bearing? And how do you know it's a cam bearing? Are you sure it isn't cracked from a main into a galley?
The 6.5/6.2 was never a robust motor even in the later versions. I think I read even the last 6.5s in the humvees had issues dispite the block improvements.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: 50% STP? [Re: Corelokt] #4510731
09/08/17 10:19 AM
09/08/17 10:19 AM
Tug Hill, NY
Corelokt Offline OP
Corelokt  Offline OP
Tug Hill, NY
I have an optimizer block, pulled it and did crank bearings. They actually weren't bad, so reassembled. I've tried 3 manual gauges. I lost the oil going down the road. It's running the high volume pump. I put a new one in. What's left is cam bearings.
Re: 50% STP? [Re: jhellwig] #4510765
09/08/17 10:56 AM
09/08/17 10:56 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
The Optimizer isn't a bad engine, especially if it has the forged crankshaft (original GM was nodular iron-crack prone)-I've had two 599 block 6.2s, a '92 & the '93 in my sig-the '92 actually made it to 300K, the '93 is now at 160K, they had the beefed up 6.5 block with the smaller 6.2 bore. If those darned forged cranks weren't $1000+...
Re: 50% STP? [Re: Corelokt] #4510767
09/08/17 10:57 AM
09/08/17 10:57 AM
Tug Hill, NY
Corelokt Offline OP
Corelokt  Offline OP
Tug Hill, NY
Mine is a military take out, all the best except the driver...
