Originally Posted By: AMC
Updated my post.
The length of time you store gasoline is very relevant. Like food, It only stays good for so long.
And yes fuel additves can be used to correct an engine not running properly, not snake oil. I have used heavy doses of seafoam to clean dirty carbs and make engines that were barely running run better with the carb still attached to the engine. There are plenty of other products out there that can do that and they do work well for what they are.
Mechanical repairs are not always necessary.
Perhaps you don't understand, I'll say it again.
The length of time in storage is irrelevant, you STILL need fresh fuel. I'm not saying it doesn't go off, I'm saying that it doesn't matter if the mower has been stored for 8 weeks or 10 years, it STILL needs fresh fuel.
The carbs you cleaned with seafoam wouldn't have gotten dirty with proper filtration. What can seafoam dissolve that petroleum cannot?
Updated my post.
