Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
82 registered members (10WSmuckers, 2004tdigls, 2015_PSD, Ablebody, 53' Stude, 11 invisible), 1,641 guests, and 31 spiders.
Topics290,839
Posts4,851,233
Members66,040
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Smoke from Engine - Help me diagnose please! #4509732
09/07/17 08:06 AM
09/07/17 08:06 AM
Cincinnati Ohio
castle Offline OP
castle  Offline OP
Cincinnati Ohio
Hi all, I have an old Maserati Biturbo that I bought in a non-running condition. It had a bad engine so I sourced a replacement used engine.
I got everything back together and have been seeing a lot of smoke from the tailpipe.
I initially did a compression test:
cylinder 1 - 120
cylinder 2 - 115
cylinder 3 - 130
cylinder 4 - 123
cylinder 5 - 118
cylinder 6 - 118
not super high but all within 10% of each other.
No real smoke until it heated up a little bit and then really heavy at high revs - then when warm pretty much all the time.
At that point I thought maybe the turbo was blown or perhaps there were valve stem seals blown. After reading more about it, I figured it was the turbo on one side or another.
I pulled the exhaust Y pipe and:
Passenger's side:
Driver's side:
So clearly an issue on just that side. I figured the turbo on just that side blew so I pulled the engine to get at it and upon pulling the exhaust manifold off the head it was clear that the oil was coming into the system ahead of the turbo:
So then I figured that a valve stem seal had blown on that cylinder. I pulled both heads and cleaned up the valves from a LOT of oily soot and replaced all seals.
It was the top left cylinder in the below picture - cleaner than the rest due to burning oil right?
I did find a bad seal on this intake valve - note the soot:
Here's the cylinder in question:
a few scratches but nothing with any depth to it at all.
All the valves fit in the guides properly and the cylinder sleeve diameters all check out per specs
So I buttoned it all back up
All fixed right? - no
I got it back together and still smoking like crazy. Here's the view right out of the exhaust manifold.
[video:youtube]https://www.youtube.com/edit?o=U&video_id=WYnkPgDsHFI[/video]
I pulled the turbo on that side again and same source of oil.
So, is this a simple case of stuck or broken rings? Could anything else have caused this problem? The good compression in cylinder #4 (the fouled cylinder) has me confused
I also had a bit of gas in my oil early on but I have chalked that up to excessive cranking with the distributor cap 180 degrees off (whoops!)
Thanks for your comments
1986 Maserati Biturbo Spyder
1994 Audi Cabriolet
1995 Audi 90 Quattro
2011 Audi A4 Avant Quattro
2014 Mercedes GLK 250
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509741
09/07/17 08:19 AM
09/07/17 08:19 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
How long did you run it? Often an engine thats been sitting will smoke a while till it clears up. My old scout fumigated the neighborhood for 45 minutes.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509747
09/07/17 08:23 AM
09/07/17 08:23 AM
USA
mk378 Online content
mk378  Online Content
USA
This seems to be an awful lot of work to dance around the fact that the rings in the "new" engine are worn. Did you do a "wet" compression test?
What is the spec for compression? Turbo engines are often set up for lower compression in the first place. Those numbers on an NA engine combined with smoke from the tailpipe would make the obvious conclusion that the rings are shot.
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509754
09/07/17 08:29 AM
09/07/17 08:29 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Any way to run it without the turbos, just to be sure?
If you have a way to take the inlet air from the turbo out of the picture and run it N/A to eliminate the turbo as a source of the oil.
Did I understand that you replaced all seals on ONE cylinder, or replaced all valve seals?
network down, IP packets delivered via UPS -BOFH
Re: Smoke from Engine - Help me diagnose please! [Re: Chris142] #4509763
09/07/17 08:35 AM
09/07/17 08:35 AM
Cincinnati Ohio
castle Offline OP
castle  Offline OP
Cincinnati Ohio
I ran it for a while in the garage and driveway and then took it for a short drive. It wasn't letting up. I thought maybe oil in the exhaust was the problem which is why I pulled the exhaust completely and was able to see smoke from the exhaust manifold itself
1994 Audi Cabriolet
Re: Smoke from Engine - Help me diagnose please! [Re: mk378] #4509764
09/07/17 08:37 AM
09/07/17 08:37 AM
Cincinnati Ohio
castle Offline OP
castle  Offline OP
Cincinnati Ohio
I did not do a wet compression test and I can't find a compression spec in the manual. I would think so too. just trying to make sure before I dive in
1994 Audi Cabriolet
Re: Smoke from Engine - Help me diagnose please! [Re: javacontour] #4509766
09/07/17 08:38 AM
09/07/17 08:38 AM
Cincinnati Ohio
castle Offline OP
castle  Offline OP
Cincinnati Ohio
I thought about this too and I could probably do this but the oil is very clearly coming in from cylinder #4's exhaust port into the manifold and then hitting the turbo. I briefly considered the thought that the turbo could be spitting oil up but there just isn't any way.
I replaced all the valve stem seals on both heads and replaced head gaskets too.
1994 Audi Cabriolet
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509781
09/07/17 09:03 AM
09/07/17 09:03 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Could be a crack in the head allowing oil in.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509789
09/07/17 09:16 AM
09/07/17 09:16 AM
give it a couple squirts of oil. then check the compression. if it goes up a few psi they are ok. if it goes up say 25 psi or more they are bad.
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509791
09/07/17 09:17 AM
09/07/17 09:17 AM
wv
krismoriah72 Offline
wv
If the car blows blue smoke during acceleration, it's the rings, if you are coasting down hill in gear and the car starts smoking, then its the valve guides... The vacuum in the cylinders will pull the oil through the guides when you are coasting down hill with the throttle off and it's in gear if they are worn out...
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509812
09/07/17 09:42 AM
09/07/17 09:42 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
[/URL]
"the cylinder sleeve diameters all check out per specs"
I disagree COMPLETELY
Those "piston ring marks" are NOT normal.
Water got into that cylinder at one time to make those.
Re: Smoke from Engine - Help me diagnose please! [Re: Linctex] #4509818
09/07/17 09:48 AM
09/07/17 09:48 AM
Cincinnati Ohio
castle Offline OP
castle  Offline OP
Cincinnati Ohio
Will new rings solve this or are you saying I need a new sleeve there?
1994 Audi Cabriolet
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509890
09/07/17 11:39 AM
09/07/17 11:39 AM
BerksCounty/Pa.
thorromig Offline
thorromig  Offline
BerksCounty/Pa.
Not a motor head at the least but did the head gasket go & was it replaced? Had same issues with an old Nissan 200SX with turbo. Had new head gasket & new seals put in & the smoking completely went away. Please dont burn me for this question fellow BITOGers.
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
Re: Smoke from Engine - Help me diagnose please! [Re: thorromig] #4509895
09/07/17 11:43 AM
09/07/17 11:43 AM
Cincinnati Ohio
castle Offline OP
castle  Offline OP
Cincinnati Ohio
It didn't fail while I've had the car but I don't know the history of the motor.
I did just replace the seals and head gaskets but the smoke persists
1994 Audi Cabriolet
Re: Smoke from Engine - Help me diagnose please! [Re: castle] #4509961
09/07/17 01:09 PM
09/07/17 01:09 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What is the year of this Maserati Biturbo ?
Page 1 of 3 1 2 3
