Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
113 registered members (ad244, 1978elcamino, Aichiguy, addyguy, 69Torino, 2012AccentSE, 10 invisible), 1,938 guests, and 59 spiders.
Topics286,185
Posts4,903,775
Members67,574
Most Online2,967
Mar 10th, 2019
Harley Xl1200 Primary/Trans UOA Red Line 75w-110 #4509685
09/07/17 06:59 AM
09/07/17 06:59 AM
Indiana (IN)
shanneba Offline OP
shanneba  Offline OP
Indiana (IN)
Here is the latest Primary/Transmision UOA from my Sportster.
This was 10,000 miles on Red Line 75w-110 GL5 diff lube.
I am now running Red Line 75w-90 GL5 diff lube.
Maybe next time I'll run Formula +
You can see the difference in the additives between the Manual Trans fluid and the Diff lube.
Sql Query:
|              | Miles on oil   | 10000     | 10000     |
|              | Total miles    | 15000     | 25000     |
|              | Date           | 03/26/16  | 08/16/17  |
|              | Make up oil    | 0         | 0         |
|              | Oil Brand      | Red Line  | Red Line  |
|              | Weight         | MT-90     | 75w-110   |
|Universal avg |                |           |           |
| ~ 5700 miles |                |           |           |
| 9            | ALUMINUM       | 82        | 81        |
| 0            | CHROMIUM       | 0         | 0         |
| 47           | IRON           | 58        | 74        |
| 6            | COPPER         | 21        | 56        |
| 1            | LEAD           | 2         | 1         |
| 1            | TIN            | 0         | 0         |
| 141          | MOLYBDENUM     | 16        | 6         |
| 0            | NICKEL         | 1         | 1         |
| 1            | MANGANESE      | 1         | 1         |
| 0            | SILVER         | 0         | 0         |
| 0            | TITANIUM       | 0         | 0         |
| 5            | POTASSIUM      | 2         | 3         |
| 165          | BORON          | 137       | 131       |
| 14           | SILICON        | 49        | 77        |
| 6            | SODIUM         | 5         | 8         |
| 1859         | CALCIUM        | 2933      | 408       |
| 180          | MAGNESIUM      | 109       | 23        |
| 960          | PHOSPHORUS     | 1957      | 2930      |
| 535          | ZINC           | 2199      | 392       |
| 0            | BARIUM         | 0         | 1         |
|              | SUS @ 210F     | 77.2      | 92.7      |
|              | cSt @ 100C     | 14.83     | 18.63     |
|              | Flashpoint F   | 440       | 435       |
|              | Insolubles %   | TR        | 0.4       |
|              | TBN            |           |           |
|              | TAN            |           |           |
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4509808
09/07/17 09:38 AM
09/07/17 09:38 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have a couple neodymium magnets epoxied to the inside of my primary cover. Do that and your iron numbers will go way down.
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4509836
09/07/17 10:18 AM
09/07/17 10:18 AM
Indiana (IN)
shanneba Offline OP
shanneba  Offline OP
Indiana (IN)
No need to open anything up, I'm fine with the iron numbers.
The drain plug already has a magnet in it.
Iron is within the "averages" when you compare the mileage difference.
AL is higher. I do have a HD Screamn' Eagle extra plate Kevlar clutch installed with a 10% heavier spring.
My plan is just to continue chain and clutch adjustment and run UOAs for now.
Not enough of these UOAs to compare too.
2003 BMW 330Ci
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4509847
09/07/17 10:35 AM
09/07/17 10:35 AM
NJ, USA
MotoTribologist Offline
NJ, USA
I'm surprised you aren't getting clutch slip with those products. I know that have the limited slip additives, but even so that system usually needs something with less friction reduction.
Also, GL-5's usually aren't suggested where yellow metals are present unless they are sufficiently buffered. Based on your copper numbers, I would assume that GL-5 is not buffered. If you are going to keep using it, I'd suggest keeping a close eye on any yellow metal components.
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4510021
09/07/17 02:00 PM
09/07/17 02:00 PM
Indiana (IN)
shanneba Offline OP
shanneba  Offline OP
Indiana (IN)
The Red Line MT-90 is a GL4 rated oil and has the friction characteristics for brass syncros in transmissions.
The Harley has a constant mesh transmission without synchronizers.
ALL of the Red Line GL5 oils test as 1A in the ASTM D-130 test.
ratings fall on a scale going from 1A (least corrosive) to 4C (most corrosive)
I have a heavier clutch spring and kevlar friction plates, the only slip I notice is tire slip.
2003 BMW 330Ci
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4510033
09/07/17 02:10 PM
09/07/17 02:10 PM
NJ, USA
NJ, USA
Right, the GL-4 should be totally fine.
I didn't see that Cu corrosion data on the GL-5. Is that for a 3 hour period or 24 hour period? Despite that, your copper levels are elevated with the GL-5 compared to the GL-4. I just thought I'd point it out and offer up a theory as to why.
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: MotoTribologist] #4510157
09/07/17 04:28 PM
09/07/17 04:28 PM
Indiana (IN)
shanneba Offline OP
shanneba  Offline OP
Indiana (IN)
Thanks for the heads up on copper.
There is an Amsoil oil comparison on the web that shows the Red Line 75w-90 tested as 1B by Amsoil.
It shows being done at the MT-1 temp of 250 F for 3 hours.
http://www.oilteksolutions.com/GearLubeWhitePaper.pdf
I contacted Red Line and they replied it is 1A for their GL5 lubes.
From Dave at Red Line-
"Our GL-5 gear oils pass the D-130 1A, they contain a copper deactivator so are not corrosive to brass, bronze or copper."
The copper would be coming from the stator in the primary for the electrical system.
2003 BMW 330Ci
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4511072
09/08/17 06:03 PM
09/08/17 06:03 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I could never get the back tire to spin on my Sportster.
She was a wheelie-in' bee-otch.
Going into 3rd gear at 65 would bring the front tire up for a third time!
Best run: 12.39 in the 1/4 at Houston Raceway
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4512143
09/10/17 09:37 AM
09/10/17 09:37 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Would REALLY look forward to seeing a Formula+ UOA on your trans/primary. Something many people do not do and now with your gear lube UOAs there is a reference point.
Personally for me, I will not use a gear lube in a transmission designed to run engine oil anymore then I would use engine oil in a transmission designed to run gear oil.
There are a mix of both types of fluids used in Car, Truck, Bike Transmissions, heck anything with gears and I trust the engineers who make the decisions on the fluid.
I dont think it will harm anything but if there is a potential for harm it will be from the fluid that is not recommended.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4513913
09/12/17 06:31 AM
09/12/17 06:31 AM
Indiana (IN)
shanneba Offline OP
shanneba  Offline OP
Indiana (IN)
I would like to see several UOAs of 10,000 mile runs of Formula+.
To keep things simple just use Formula+ in the primary/transmission smile
I only ran it for the first 1000 miles, then SYN3 was run until the clutch was replaced at just over 3000 miles.
I have only seen one Formula+ VOA and it didn't show much in the way of additives.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3087905&Searchpage=1&Main=72166&Words=Formula+%2B&Search=true#Post3087905
It tested as a GL1 gear lube about the same viscosity as a 50 weight motor oil.
Harley even states not to use it in the engine.
Formula+ is the only primary/trans lube mentioned in my owners manual (it doesn't list SYN3 )
https://www.harley-davidson.com/store/quart---formula--transmission-and-primary-chaincase-lubricant
" Formula+ is blended to provide lubricity for the anti-wear requirements of transmission gears. Not for use in the crankcase as a motor oil"
They do also suggest their SYN3 20w-50 can be used in the Sportster Primary/Transmission.
They do not have the same recommendation for the HD360 20w-50 mineral oil.
2003 BMW 330Ci
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: shanneba] #4513924
09/12/17 06:43 AM
09/12/17 06:43 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Correct Formula+ is primary/transmission fluid/oil, never an engine oil as any transmission fluid is not either.
Correct very little additives because its not being used in a combustion engine, just oiling gears, doesnt need detergents more much zinc as the gears do not run dry like an engine. Maybe better said GL1 performance type oil is all that is recommended for some reason.
Im sure the clutch was covered under warranty, did they find the cause? Slipping?
07 Suzuki C50
Re: Harley Xl1200 Primary/Trans UOA Red Line 75w-110 [Re: alarmguy] #4514533
09/12/17 07:42 PM
09/12/17 07:42 PM
Indiana (IN)
shanneba Offline OP
shanneba  Offline OP
Indiana (IN)
There are very little anti wear additives in Formula+, very little detergents also.
It doesn't need anything to combat blow by, moisture or the carbon from combustion.
The clutch was not covered under warranty, it was deliberate damage to the clutch while my now ex wife had possession of the bike.
2003 BMW 330Ci
