Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
78 registered members (Astro_Guy, aquariuscsm, alarmguy, bcossa2001, avi1777, Back40, 9 invisible), 1,005 guests, and 50 spiders.
Topics286,107
Posts4,902,709
Members67,563
Most Online2,967
Mar 10th, 2019
Identifying Gm 14 bolt differential limited slip?? #4509355
09/06/17 06:30 PM
09/06/17 06:30 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
My 1983 p30 has a dually 14 bolt rear end.
Is there any way to tell if its limited slip besides removing the cover.?
Supertech Junky
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509358
09/06/17 06:38 PM
09/06/17 06:38 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
Put it up on jack stands and spin the tires.
Is this a van or RV?
Limited slip
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509365
09/06/17 06:44 PM
09/06/17 06:44 PM
South Louisiana
Soggydog Offline
Soggydog  Offline
South Louisiana
If you can find the build tag, look for G80. I think the 14 bolt full float axles were usually open or had lockers.
Currently running...
2011 Ford F250 4x4 6.7L, 2011 Toyota Camry SE 2.5L, 2002 Dodge Caravan 3.3L,
2012 Honda Rincon,2012 Honda Rancher AT,09 Honda Trx90
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509367
09/06/17 06:47 PM
09/06/17 06:47 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Sorry guys.
Just realized there's a sub fourm for differentials....
Supertech Junky
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509378
09/06/17 06:56 PM
09/06/17 06:56 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
If it does it will have a gov-loc. The usual ways to test it wont work as it works differently. Put 1 wheel in the dirt and the other on the street and hammer down. If the one on the street locks in it has a Gov-loc. If it does a 1 wheel peel in the dirt it don't.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509417
09/06/17 07:54 PM
09/06/17 07:54 PM
NY
joegreen Offline
joegreen  Offline
NY
If you cant find the g80 code im not sure without popping off the diff cover.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509424
09/06/17 07:58 PM
09/06/17 07:58 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
I have a feeling the axle has never been serviced. So i think I'll just pop the cover off.
I just want to know if the rest end floats or if it has the govt locker.
Mainly cause we want to take it to the local shore lines with the 5k boat.
It would be nice to know if we got into a pinch, we would be saved by the rear end.
Supertech Junky
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509445
09/06/17 08:21 PM
09/06/17 08:21 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
I highly doubt a P series chassis would have a Eaton Governor Locker or any other traction devise. The 10.5" 14 Bolt IS one of the easiest differentials to install a posi/locker carrier in...FYI.
2001 Chevy Camaro L92/4L80E
Re: Identifying Gm 14 bolt differential limited slip?? [Re: clinebarger] #4509461
09/06/17 08:29 PM
09/06/17 08:29 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I completely agree that it's unlikely that your P30 has a Gov-Lock but if you post a picture I can easily tell you if it does or not. I'll do some digging and see if I can find a reference picture for you.
Luke
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509515
09/06/17 09:22 PM
09/06/17 09:22 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Way to ruin my fun guys....
I'm just a poor kid who wants a posi traction rv for the family!
Joking.... I just wanna know.
Supertech Junky
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4509645
09/07/17 01:46 AM
09/07/17 01:46 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have NEVER personally seen, or heard of, a P30 chassis with limited slip.
Re: Identifying Gm 14 bolt differential limited slip?? [Re: ls1mike] #4510542
09/08/17 04:37 AM
09/08/17 04:37 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Limited slip
Jack it up with both wheels off the ground. Spin a wheel. If it is somewhat difficult to spin and the opposite wheel spins in the same direction, you have a lim slip diff. If it spins easily and the opposite wheel spins in the other direction, it is standard issue. No need to take off rear cover.
The "thinking" man's friend.
Re: Identifying Gm 14 bolt differential limited slip?? [Re: Lubener] #4510576
09/08/17 06:17 AM
09/08/17 06:17 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Limited slip
The nature of how the Gov-Lock works pretty much prevents you from checking it this way. A good majority of the ones I've worked on (that functioned just fine in use) felt like an open differential up on jack stands. The Gov-Lock requires enough differential wheel speed to engage the clutches to send power to the other side.
Luke
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4511244
09/08/17 11:58 PM
09/08/17 11:58 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Removed the cover.
I have the peg leg.
My dreams were s
Supertech Junky
Re: Identifying Gm 14 bolt differential limited slip?? [Re: leroyd92] #4511627
09/09/17 03:19 PM
09/09/17 03:19 PM
NY
joegreen Offline
joegreen  Offline
NY
Originally Posted By: leroyd92
Removed the cover.
I have the peg leg.
My dreams were s
Its not all bad. If i can recall if you have an open carrier 14 bolt a detroit locker drops right in and is stronger than the gov loc.
1978 Chevrolet k20
