Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
50 registered members (69Torino, advocate, alarmguy, Astro_Guy, 97K15004WD, 2015_PSD, 5 invisible), 805 guests, and 48 spiders.
Topics286,222
Posts4,904,548
Members67,579
Most Online2,967
Mar 10th, 2019
How long until new engine turns oil black? #4509023
09/06/17 12:31 PM
09/06/17 12:31 PM
Texas
AnarchyX Offline OP
AnarchyX  Offline OP
Texas
As you guys know I recently bought a new Ford Edge (2.0 eco-boost)and I finally have almost 1500 miles on it but the oil looks the same as it did when I bought it with a little over 400 miles.There's also none of the shiny metal shavings that I can see in the oil.
So I'm wondering if this is normal because it's a new car, or does it have more to do with the type of engine it is and that it's semi-synthetic oil?
I drive about 10 miles to work and then 10 back of course, plus around 5 or so for lunch Monday through Friday.
Now the tailpipe does have the black soot stains on it, but I read that's pretty normal for direct injection/turbo engines.
Okay, well any info would be appreciated.
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509025
09/06/17 12:37 PM
09/06/17 12:37 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
I was unable to see anything shiny on the dipstick of my new engine... but I could see it shine after it drained into the catch pan.
15 Toyota Prius - M1 EP 0w20 SN+
06 Acura MDX - Valv MaxLife Syn 5w20 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Syn 5w30
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509029
09/06/17 12:40 PM
09/06/17 12:40 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Type of engine will probably play into it more than anything else. For example, a diesel engine will turn oil black within just a couple hundred miles. On a typical gasoline engine it should take a lot longer.
It may also be oil dependent. Some add packs, once activated, can cause the oil color to turn darker, but that in itself is not a cause for condemnation.
FYI, I change oil in my 530i once a year. I probably have around 6-8K miles on it at that point, and the oil is still not black by then.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509055
09/06/17 01:02 PM
09/06/17 01:02 PM
MD
AirgunSavant Offline
MD
What Quattro said and a new engine isn't loaded with sludge so going black fast isn't the norm.
I ran out one of my new Fords to 6200 miles on the FF and it was still golden color
The cut open filter looked good for another 5 grand too
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509058
09/06/17 01:04 PM
09/06/17 01:04 PM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
The Edge we bought with the new 2.0 Ecoboost had clean looking oil when I changed it. The dealer was adamant to change the factory fill when the message says to. I gave in at 5000 miles. Let it drain for and hour and filled with Home Depot Shell and a Motorcraft filter.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509080
09/06/17 01:23 PM
09/06/17 01:23 PM
Canada
i_hate_autofraud Offline
Canada
If you have a spin-on oil filter, Id start using FilterMags that match the filter
Diameter. See the results in the PDF below. If you know the filter has 3/4 clearance
all the way around the filter, then Id use a pair of FilterMags.
Ive been doing it for last 3 years along with more bar mags on open space on the filter,
it keeps my oil clean for 8-9 months! My UOA shows 40-50% less iron and a drop in all other wear metals.
FILTERMAG vs HOMEBREW
https://app.box.com/s/uxvu8dmscf5wcgftutdm0ejqwgn86tw7
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509082
09/06/17 01:26 PM
09/06/17 01:26 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Metal shavings?
I hope not. This ain't no Far eastern made 80 buck OPE on a murray.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509136
09/06/17 02:29 PM
09/06/17 02:29 PM
Balearic Islands , Spain
FordCapriDriver Offline
Your Ecoboost should in theory turn the oil dark faster than a regular port injection gas engine.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: How long until new engine turns oil black? [Re: FordCapriDriver] #4509139
09/06/17 02:33 PM
09/06/17 02:33 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
For sure.
I would change oil and filter at 1,000 miles.
Dipstick oil color doesn't tell the whole story.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509142
09/06/17 02:35 PM
09/06/17 02:35 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
I noticed the same thing on my (then) new Honda Accord. It took a long time for the oil to darken at all. Happened again after the first change.
I think the engine is just really clean.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509145
09/06/17 02:38 PM
09/06/17 02:38 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
More than 15,000 miles..... I've run it that far, and it STILL ISN'T black, just dark brown.
No sludge in the valve cover through the oil fill hole. 155,000 miles
Re: How long until new engine turns oil black? [Re: AnarchyX] #4509155
09/06/17 02:51 PM
09/06/17 02:51 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
It's seconds for my pickup.
2015 Ford F250 w/Powerstroke
Re: How long until new engine turns oil black? [Re: MolaKule] #4509163
09/06/17 03:08 PM
09/06/17 03:08 PM
NY
demarpaint Offline
demarpaint  Offline
NY
For sure.
approved
God Bless Our Troops
Re: How long until new engine turns oil black? [Re: Quattro Pete] #4509254
09/06/17 04:50 PM
09/06/17 04:50 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
With one of my old 240Ds, you could count on total darkness in fresh oil by the time I drove to work and back once, about fifty miles.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: How long until new engine turns oil black? [Re: MolaKule] #4509348
09/06/17 06:20 PM
09/06/17 06:20 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
For sure.
Change the filter if you think it needs it. But IMO I'd let the break in oil run it's full course. It's full of a lot of juicy additives that help with safe break in of parts. Usually they're pretty high in moly and zinc
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
