Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
35 registered (bdcardinal, Bryanccfshr, bbhero, askani79705, BlueBear, 2015_PSD, 6 invisible), 993 Guests and 34 Spiders online.
65258 Members
67 Forums
285502 Topics
#4508919 - 09/06/17 10:37 AM Power Steering Fluid for 2003 Hyundai?
mrdctaylor Offline
Loc: McGregor TX
Guys,
I have a 2003 Hyundai Santa Fe. I'm getting the power steering pump replaced for a third time in 3 months. The first two were A1 Cardone pumps and both were noisy and had issues. I finally broke down and ordered an OEM pump that my mechanic is going to install next week. But I'm curious: what fluid should he be using? I don't actually know what he used the first two times. Hyundai calls for something called "PSF-3" which no one ever has and most dealerships don't stock or use. I've read where ATF is fine in these systems. When I did a simple suck out/fill of the system over the years I used both store brand power steering fluid and then Maxlife PS fluid. So...I'm guessing that it isn't too picky. I just want to see what others are using with success in early 2000s Hyundais.
Thanks!
02 Tacoma 3.4L, 215K, Magnatec 10W30
02 Trailblazer 4.2L, 174K, Magnatec 5W30
12 Highlander 3.5L, 88K, M1 EP 0W20
17 Escape 2.0L, 31K, Hav ProDS 5W30
#4508934 - 09/06/17 10:47 AM Re: Power Steering Fluid for 2003 Hyundai? [Re: mrdctaylor]
mclasser Offline
Loc: The Northeast
Hyundai's and PSF are kind of a confusing topic. My old Elantra also speç'd PSF-3 but nobody seemed to stock it. I read around and apparently older owner's manuals said PSF-3 or Dexron ATF could be used. I called Royal Purple and they said their PSF would work fine in my application. That's what I ended up using.
2018 Hyundai Elantra VE -- 3K
2013 Honda Pilot EX-L 4WD -- 55K
2002 Honda Accord EX-L -- 210K
#4508936 - 09/06/17 10:50 AM Re: Power Steering Fluid for 2003 Hyundai? [Re: mrdctaylor]
Jimzz Offline
Loc: NoVA
I use ATF fluid in many Hyundai's and Kias just fine. Usually Maxlife or what ever fluid I have on hand.
yup
#4508952 - 09/06/17 11:20 AM Re: Power Steering Fluid for 2003 Hyundai? [Re: mrdctaylor]
SHOZ Offline
Loc: Illinois
I use Preston. It's $5 a qt at Walmart. PSF-4 is the new Hyundai fluid, Kia has it cheaper but it still is ridiculously expensive.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4509043 - 09/06/17 12:48 PM Re: Power Steering Fluid for 2003 Hyundai? [Re: mrdctaylor]
knerml Offline
Loc: NE Ohio
RAVENOL PSF Power Steering Fluid J1B1031 = Hyundai/Kia PSF-3
Available on Ebay and Amazon
FYI - RAVENOL SSF Power Steering Fluid J1B1001 = Hyundai/Kai PSF-4
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T GDI Castrol Edge 5W40 & OEM/Mann W811/80 Filter
#4509342 - 09/06/17 06:14 PM Re: Power Steering Fluid for 2003 Hyundai? [Re: mrdctaylor]
Thax Offline
Loc: VA
At work we have and use PS-3&4 . I havent seen the msds or pdf , however it is red in color. It has a distinct odor kinda like a mix between trans and psf, thicker than trans fluid but not as thick as psf. Id see if you could find some for a good price on amazon or ebay, if not I think a good trans fluid would do fine.
97 Grand Prix GTP
11 Jetta 2.5 SE
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
