Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
106 registered members (4WD, 2002 Maxima SE, 28oz, Alfred_B, 53' Stude, 7 invisible), 2,240 guests, and 34 spiders.
Topics296,643
Posts4,956,523
Members66,950
Most Online2,577
Jan 14th, 2019
CAT pressure washer pump cloudy sight glass #4508609
09/05/17 10:47 PM
09/05/17 10:47 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
i just bought a new pressure washer with a CAT pump. Looking at the sight glass the oil looked kind of cloudy. Maybe it's just me I don't know. According to the manual its supposed to be in the middle of the glass and it was 3/4 of the way up the glass. I drained a little bit out so it's at the middle now. Draining the oil out it looked like the usual golden color. I only drained out maybe an ounce or two to get it to the middle of the sight glass, so if I knew that's all it would take I probably would have left it alone. lol Now the small amount that went into the drain pan looked a little grey in color, but then again it might just be the black drain pan making it look like that.
What do you guys think? Should I be worried or not? It's a brand new pressure washer, so I don't see how water could be in it. The box didn't have water damage, so I don't think it was from flood water Is it maybe just from break in? I'm sure it's run at the factory. I haven't even started it yet.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4508678
09/06/17 03:01 AM
09/06/17 03:01 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Use it for a few hours and see if the level in the sight glass rises, if it does the seals in the pump are bad. Having said that the seals in my Cat pump are bad, and the level doesn't rise even after about 10 hours of use, but when I drain the oil from the pump there's water in it. If I run it 30 or so hours the level will rise a bit. If I were you, I would do an early break in oil change on the engine, and a 10 hour oil change on the pump and check for water if you're concerned. Yours could be fine, or like mine and a small amount of water is getting into the pump oil. No water should be getting into the pump oil. Replacing the seals on my pump is on my to do list.
God Bless Our Troops
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4508745
09/06/17 06:11 AM
09/06/17 06:11 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Mine looks cloudy in the sight glass too, always has. Doesn't rise any and usually looks ok when drained annually.
Does yours not even appear in the sight glass when its running? I just happened to look the other day while my wife was using it and noticed the oil level drops out of the glass when running... returns to half way when off though.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4508793
09/06/17 07:37 AM
09/06/17 07:37 AM
Houston, Texas
Houston, Texas
So the water got in it when they ran it at the factory?
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4508795
09/06/17 07:38 AM
09/06/17 07:38 AM
Houston, Texas
Houston, Texas
I don't get how it's cloudy straight out of the box
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4508819
09/06/17 08:03 AM
09/06/17 08:03 AM
Houston, Texas
Houston, Texas
what if I just change it out before I start it? That way I can drain it into a clear glass drain cup and look at it then.
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509032
09/06/17 11:42 AM
09/06/17 11:42 AM
Easton, PA
lexus114 Offline
lexus114  Offline
Easton, PA
i just got a new simpson pressure washer with the cat pump. and like yours the oil level in the pump is 3/4 of the way up the sight glass too? whats with this?
2017 Mercedes-Benz C300 4matic coupe 2.0 turbo
2016 Lexus RX 350 Autumn Shimmer AWD
Re: CAT pressure washer pump cloudy sight glass [Re: lexus114] #4509606
09/06/17 10:23 PM
09/06/17 10:23 PM
Houston, Texas
Houston, Texas
[quote=lexus114]i just got a new simpson pressure washer with the cat pump. and like yours the oil level in the pump is 3/4 of the way up the sight glass too? whats with this? [/quote
I only drained out an ounce two at most to get it at the top of the red dot.is it possible its assembly lube giving it a cloudy look?
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509782
09/07/17 08:08 AM
09/07/17 08:08 AM
Easton, PA
lexus114 Offline
lexus114  Offline
Easton, PA
mine isn't cloudy, just over full like yours was. so to answer your question...i still wonder if yours had some sort of water damage. then they slapped it in a new box? and prayers to you and your family...
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509802
09/07/17 08:33 AM
09/07/17 08:33 AM
Houston, Texas
Houston, Texas
I had them get it out of the back, because the one on the floor was opened. I didn't see any signs of water and they said they didn't get any. How can I check for water?
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509828
09/07/17 09:07 AM
09/07/17 09:07 AM
Houston, Texas
Houston, Texas
I spoke with CAT pumps and they said to bring it back to the place I bought it and get it swapped out.
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509829
09/07/17 09:08 AM
09/07/17 09:08 AM
Houston, Texas
Houston, Texas
I'll take a pic and show you guys tonight
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509866
09/07/17 10:04 AM
09/07/17 10:04 AM
Easton, PA
lexus114 Offline
lexus114  Offline
Easton, PA
it was just a thought i had. its probably fine.
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509967
09/07/17 12:13 PM
09/07/17 12:13 PM
Houston, Texas
Houston, Texas
Kind of a bummer I got to bring it back, but oh well. It's like a 50 mile round trip.
Re: CAT pressure washer pump cloudy sight glass [Re: motor_oil_madman] #4509973
09/07/17 12:17 PM
09/07/17 12:17 PM
Houston, Texas
Houston, Texas
If it was just overfilled I would have assumed someone just didn't pay attention, but the fact that it's also cloudy has me concerned.
