Corrosion in the garage - salt or humidity?
by Kurtatron
14 minutes 34 seconds ago
Darn dogs
by AZjeff
Today at 10:21 PM
New GC?
by Bullwinkle007
Today at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Today at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Today at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Today at 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Today at 08:45 PM
what happened to merk
by ernied
Today at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Today at 07:41 PM
Decent MP3 player
by Ed_T
Today at 07:08 PM
Letgo
by Donald
Today at 06:52 PM
Tire buying advice
by supton
Today at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Today at 06:21 PM
No older cars in New York State?
by Oldtom
Today at 06:19 PM
2009 Taurus strut mount noise
by terry274
Today at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Today at 03:36 PM
2003 Honda power steering problem
by hogpops
Today at 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
Today at 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
Today at 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
Today at 03:02 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
70 registered (154cm, 77GrandPrix, 1JZ_E46, 2015_PSD, 4WD, Aero540T, 8 invisible), 1153 Guests and 56 Spiders online.
65317 Members
67 Forums
285949 Topics
Page 1 of 3 1 2 3 >
#4508564 - 09/05/17 10:26 PM Interesting mod motor spark plug failure
Colt45ws Offline
Loc: Central Washington
So I blew out another spark plug, but it didnt fully eject. The combustion pressure blew through the threads on a small section then proceeded to Oxy-gasoline torch the spark plug and cylinder head.
Its cut the head so bad it might actually be non-repairable. I dont know how long it was leaking for since I had my radio cranked. Finally I went WOT around a truck and o boy was it loud.
Im glad I already got the ball rolling on getting another engine in it rather than do the timing chains on this engine, since it might need a cylinder head now.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4508587 - 09/05/17 10:58 PM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
Gasbuggy Offline
Loc: PA
On the crown vic? Never saw anything like that before on a N/A Ford Mod.
CTS-V+Recaros 5w30 Magnatec
Volvo P1800 5w30 Euro L
Land Rover Series 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 MaxLife
95 Accord - 386k. Mobil 2 RIP
#4508595 - 09/05/17 11:07 PM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
Panzerman Offline
Loc: Port Orange, Florida
JB Weld to the rescue!!
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4508598 - 09/05/17 11:11 PM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
dishdude Online   content
Loc: Phoenix
I'm surprised the compression gases - even blowing the spark up would be hot enough to melt the plug.
2018 Challenger SRT
#4508604 - 09/05/17 11:28 PM Re: Interesting mod motor spark plug failure [Re: Gasbuggy]
Colt45ws Offline
Yap
-Colton
#4508661 - 09/06/17 02:33 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
Dave9 Offline
Loc: Cincinnati, USA
This is abnormal, I suspect a combination of not torquing them enough then cleaning your engine perpetually with water and letting the threads rust out.
#4508679 - 09/06/17 04:04 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
barryh Offline
Loc: Cheshire, England
Combustion gases not hot enough to do that damage ?
I don't fully understand the mechanism at work but it's more erosion than melting. if you have a gasket failure on a steam pipe and leave it to leak long enough without repair it will cut a groove in a sold steel pipe flange that looks a lot like that spark plug damage.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
#4508700 - 09/06/17 05:54 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
OVERKILL Online   content
Loc: Ontario, Canada
That's impressive if anything. Do you have a borescope to take a peek at the underside? I agree with you that it may be "unrepairable" as in the head would need to be removed and welded, then worked, then an insert put in.
2016 Durango Limited
2016 Grand Cherokee SRT
#4508722 - 09/06/17 06:43 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
andyd Online   content
Loc: Marshfield , MA
That is a deep reach plug. How does it "blow out" ? There is nearly an inch of thread on the plug. Could somebody s'plain the mode of failure to me? Once again FOMOCO metallurgy fails to impress. Colt45ws isn't at fault here. TIA
Thick oil is better grin2
#4508742 - 09/06/17 07:09 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
Kruse Offline
Loc: Kansas
I'd bet it was giving indications of a problem for quite awhile, but like you said, if your stereo was cranked, I guess you didn't hear it.
Which cylinder was this one? Like you probably guess, I bet this one will require a new cylinder head.
#4508788 - 09/06/17 08:28 AM Re: Interesting mod motor spark plug failure [Re: Kruse]
Canadastang Offline
Loc: Ontario Canada
Is this the generation of 2V's that only had something crazy like 4 threads?
I know in later years they added more threads to prevent this from happening.
Fordtechmakuloco advocates overtorquing the plugs to about 20 ft. lbs, instead of the called for 10ish ft lbs. I did that on my Town Car 6 months ago and no issues.
Did you use a torque wrench on the last plug change?
#4508803 - 09/06/17 08:49 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Al heads, peanut plugs with no gasket. Nice design.
I do like this engine though for many REAL advancements in mfg that would make Grumpy ole Henry happy.
I Specifically find the assembled camshaft(s) with sintered lobes to be real out of box thinking.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4508805 - 09/06/17 08:50 AM Re: Interesting mod motor spark plug failure [Re: Colt45ws]
WyrTwister Offline
Loc: Texas
You plan to replace the entire engine , not just the head ? What , salvage yard engine ?
Best luck to you , :-)
Wyr
God bless
#4508808 - 09/06/17 08:56 AM Re: Interesting mod motor spark plug failure [Re: WyrTwister]
Canadastang Offline
Loc: Ontario Canada
Swap in a 5.4 2V from a truck or van and if funds allow, throw on some trick flow heads, port the exhaust manifolds and make some real power!
#4508842 - 09/06/17 09:18 AM Re: Interesting mod motor spark plug failure [Re: OVERKILL]
Linctex Offline
Loc: Waco, TX
I have never seen anything like this in my life.
I mean, I have seen spark plug failures (center blows out of steel shell) and spark plug holes fail in numerous ways, but this is COMPLETELY new.
Yes, time for that engine swap we were talking about!
Page 1 of 3 1 2 3 >
