Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
85 registered members (53' Stude, bdcardinal, BAJA_05, BlakeB, Boomer, alphadog, 9 invisible), 1,833 guests, and 53 spiders.
Topics290,892
Posts4,852,014
Members66,047
Most Online3,590
Jan 24th, 2017
Do pressure washer hoses have standard fittings? #4508533
09/05/17 10:05 PM
09/05/17 10:05 PM
Houston, Texas
motor_oil_madman Online content OP
motor_oil_madman  Online Content OP
Houston, Texas
I bought a replacement hose and I found the part you thread on bottoms out against the handle. The other hose tightened before it bottomed out. Looking at it it looks like all that mAtters is that oring seals inside the bore.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Do pressure washer hoses have standard fittings? [Re: motor_oil_madman] #4508534
09/05/17 10:06 PM
09/05/17 10:06 PM
Houston, Texas
Houston, Texas
I haven't had a chance to drag it over to a hose.
Re: Do pressure washer hoses have standard fittings? [Re: motor_oil_madman] #4508537
09/05/17 10:07 PM
09/05/17 10:07 PM
Houston, Texas
Houston, Texas
By standard I mean universal.
Re: Do pressure washer hoses have standard fittings? [Re: motor_oil_madman] #4508566
09/05/17 10:30 PM
09/05/17 10:30 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
The smaller units use a M22 hose, and the larger units use a 3/8 hose typically without fittings.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Do pressure washer hoses have standard fittings? [Re: motor_oil_madman] #4508579
09/05/17 10:48 PM
09/05/17 10:48 PM
Houston, Texas
Houston, Texas
Yeah thats what both hoses appear to be. It's just that the old hose had this round part on the end and the new hose doesn't. So basically you tighten it until that round part comes into contact with the threaded part. I think think this new hose will still work, it's just going to pull the oring a little further inside the threaded portion. It seems that little oring is what holds back the pressure. This is just a cheap home owner grade with 1/4" hose and non quick connect fittings.
Here is what I bought and it's the same as the generac hose except for that round part behind the oring.
http://www.northerntool.com/shop/tools/product_200632637_200632637
Re: Do pressure washer hoses have standard fittings? [Re: motor_oil_madman] #4508583
09/05/17 10:51 PM
09/05/17 10:51 PM
Houston, Texas
Houston, Texas
I'm just trying to avoid water blowing out of the hose and cutting me. I got lucky the first time when the old hose blew. I had to hang onto it good with all that water coming out. lol
