Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
100 registered members (380SLbenz, 1WildPig, 2012AccentSE, aircooled, ABerns, 2K2AcuraTL, 8 invisible), 2,165 guests, and 142 spiders.
Topics286,197
Posts4,904,018
Members67,576
Most Online2,967
Mar 10th, 2019
Ecoboost F150 on the wrong oil?? #4508390
09/05/17 07:50 PM
09/05/17 07:50 PM
S California
OneEyeJack Offline OP
S California
A guy with a 2013 Ecoboost F150 stopped by to pick up a horse and we talked vehicles.
He's got just over 200K miles and all of them with conventional Castrol 20w-50 at 5K intervals with Motorcraft filters. All his driving has been in the desert, high desert or mountains and mostly towing. He's had nothing done except routine maintenance. What he called 5w-20 oil can't be repeated here so I take it he prefers a bit thicker oil. He's had trips where he's towing maximum weight for 8-10 hours in the desert with temps in the triple digits and he won't risk his rig to thinner oils.
He also changes his air filter based on a delta gage and he's added a really big gas filter/water separator with a warning light and a coolant filter with a sacrificial anode along with an extra really big tranny cooler and a spin on filter with synthetic tranny fluid with a drain and refill every 30K miles. The diff also gets a heavier synthetic oil changed every 30K miles.
As hard as he works his truck I'd say he's doing okay with his changes.
I just thought BITOG members might like to hear what someone is doing with their Ecoboost in a real working truck.
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508404
09/05/17 08:02 PM
09/05/17 08:02 PM
Utah
CKN Online content
CKN  Online Content
Utah
If your getting accurate information it just goes to prove that the concern a dealer, Jiffy Lube, Walmart, Pep Boys, or your average neighborhood mechanic putting in the wrong oil and the motor blowing up is a little unfounded.
And one reason why this excuse (putting in the wrong oil) should be scratched off the list of reasons why one should change their own oil.
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508410
09/05/17 08:05 PM
09/05/17 08:05 PM
Illinois
tig1 Online content
tig1  Online Content
Illinois
A friend has a 2012 F 150 ecobost and it's his work truck as well. He is a contractor and pulls a tandem wheel trailer that serves hauling all his equipment. Often he travels long distance to jobs. He also pulls a 32 ft camper for extended stays. He uses MC 5-30 at factory spec OCIs.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Ecoboost F150 on the wrong oil?? [Re: CKN] #4508415
09/05/17 08:09 PM
09/05/17 08:09 PM
Illinois
tig1 Online content
tig1  Online Content
Illinois
A person I know, his sons engine did blow up after an oil change at Jiffy Lube. Reason was the drain plug was cross threaded and leaked the oil out in two days. JL replaced the 40K engine with another used 40K engine.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508460
09/05/17 08:44 PM
09/05/17 08:44 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
It is one data point. I would not draw conclusions or offer advice based on it.
2019 Toyota Tacoma 3.5L (MileSyn 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508472
09/05/17 09:01 PM
09/05/17 09:01 PM
S California
S California
I was very specific in collecting the information I listed. I'm not making any recommendations but if I were working my Ecoboost engine I'd use a "thicker" oil, too. And I'd do some or all of the other things he did.
This truck gets worked really hard, harder than most pickups except for those other individuals that actually use their trucks for work. From all the desert driving his body work looks like he's been on a campaign with Rommel across the African desert. In his case, if it goes or stops it gets taken care of. Besides the a/c and the lights everything else only gets fixed when it breaks.
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508494
09/05/17 09:35 PM
09/05/17 09:35 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I think this oil weight theory is way over rated.
I have never used the specified oil weight in my Dodge I bought new and is still under warranty.
I know it would not be a issue because it got changed regularly and that would be evident in a clean motor.
I know a guy that has 326,000+ Miles on a Ford F150 with a 4.6 that all he ran was Havoline 20w50. Never had a engine issue.
Oil weight in the manuals, I take as a suggestion not a rule. 10w30 will work in anything.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508500
09/05/17 09:40 PM
09/05/17 09:40 PM
WI.
dblshock Offline
dblshock  Offline
WI.
'10w30 will work in anything' but not up here in January, and 40 or 50 might do better under duress.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508513
09/05/17 09:49 PM
09/05/17 09:49 PM
Panzerman Offline
Panzerman  Offline
That's another rumor thats over hyped. Cold weather starts. I am originally from Pennsylvania where in the winter it would go well below 0. What do you think equipment does out in the middle of nowhere where starting on 15w40 or even straight 40 wt in the detroits start? Middle of the woods in strip cuts, no electricity to plug them in.
Cars and trucks have been around alot longer than 0w20 motor oils and never was oil a issue in cold weather. Fuel and air were, not oil.
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508560
09/05/17 10:25 PM
09/05/17 10:25 PM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
I more entertain the idea of using the correct oil the manual specifies, Mine has always got 0-20 but its been proven around here from multiple people its really a myth people use whatever they get their hands on....mix it or not mix it. UOA still shows decent results.
16 Silverado 2500 LML 20k Miles
Rotella 5w-40 T6
ST 75w-90 GL5 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant, K&N Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508574
09/05/17 10:41 PM
09/05/17 10:41 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Why another thick vs thin argument? So if i find someone who used 5w20 and not the other precautions and hits 200k miles, what would that prove? I guess I dont understand the argument of 1 person doing something and getting a result that doesnt prove anything. We all know that engines outlive most cars. Proof of ones success does not make fact.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508575
09/05/17 10:43 PM
09/05/17 10:43 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Funny how cars are lasting longer today and oils are getting thinner LOL
PP 0w20 & ST 4967
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508597
09/05/17 11:11 PM
09/05/17 11:11 PM
Panzerman Offline
Panzerman  Offline
I am not really arguing thick is better than thin.
My argument is it doesn't really make any difference.
The thin is to get better gas mileage not necessarily long life but oil changes are more important than oil weights.
Longer living engines are due to on board computers monitoring all systems. No fuel dumps and constant corrections to optimize operations leads to longer living motors.
Re: Ecoboost F150 on the wrong oil?? [Re: OneEyeJack] #4508601
09/05/17 11:20 PM
09/05/17 11:20 PM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
Whenever I hear stuff like this I get suspicious of how true it is. Guy is an expert but doesn't know that Ford did not spec 5w20 for the 3.5 EcoBoost?
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 5w30 Euro L
LR Series III 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 PP
10 Charger Pursuit 5.7L
95 Accord - 386k. Mobil 2 RIP
Re: Ecoboost F150 on the wrong oil?? [Re: Gasbuggy] #4508614
09/06/17 12:00 AM
09/06/17 12:00 AM
Phoenix, AZ
panthermike Offline
panthermike  Offline
Phoenix, AZ
In all fairness, alot of dealers probably assume 5w20 as well, it happened a couple of times with my ex's Ecoboost. 20w50 is Overkill but likely not harmful either. The mechanic I used to go to (retired) used 20w50 in literally everything because he believed it was the best. He serviced many cars with 200k+ and some town cars with 300k+. Not to say the 50w got them there as the specd oils would have to, but it didn't hurt anything.
Some people are too stubborn to stray from old ways but no worries, their vehicles will still last a long time! I use specd oil mostly but some circumstances I use thicker. My brother's 07 F150 5.4s cam phasers are quieter with thicker oil for example.
'15 Lexus RX350; ST 0w20/LG, 44K
'10 F150 5.4; M1 0w40/LG, 99K
'70 F100; Valvoline 15w40/LG
MMO in Fuel
