Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
80 registered (2004tdigls, 2009Edge, 10WSmuckers, advocate, Aero540T, 9 invisible), 1531 Guests and 46 Spiders online.
65303 Members
67 Forums
285870 Topics
#4508242 - 09/05/17 04:45 PM Need home brew Fuel Injector cleaner
bopiddy Offline
Loc: Pennsylvania
444 Cummins will idle but won't rev, anyone have a very good homebrew fuel injector cleaner? Any help would be greatly appreciated!
#4508260 - 09/05/17 05:05 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
SirTanon Online   content
Loc: Phoenix, Arizona - USA
Why not just buy a bottle of proven OTC product, like Chevron Techron or Redline SI-1? They have a proven track record.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 257,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 55,000mi
#4508271 - 09/05/17 05:21 PM Re: Need home brew Fuel Injector cleaner [Re: SirTanon]
simple_gifts Offline
Loc: Middlesex County CT
Those are gas additives.
2004 Prius; 92K ML Syn 5W-30
2007 Yaris 68K 0w-40 Castrol
2006 B2300;130K;ALM
Was driving an ox cart; Now on the USS Enterprise
#4508273 - 09/05/17 05:22 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
dogememe Offline
Loc: SF BAY AREA, CA
Chevron Techron Diesel?
Edited by dogememe (09/05/17 05:23 PM)
2007 Ford Crown Vic P71 4.6 ~124K Miles, SynPower 5W-30, Royal Purple Filter. *Daily Driver*
2010 Ford Escape 2.5 ~70K Miles, SynPower 5W-30, Wix Filter. *Turo Rental*
#4508279 - 09/05/17 05:30 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4507986/Techron_Diesel_$9.99_at_AZ
2006 B2300;130K;ALM
#4508302 - 09/05/17 06:04 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
bioburner Offline
Loc: Minnesota
If the engine is running at idle but won't rev up I would think that the issue is somewhere before the injectors. Fuel pump or fuel filter? I know when my numerous fuel powered tractors and vehicles had power issues it usually was the filters.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4508307 - 09/05/17 06:09 PM Re: Need home brew Fuel Injector cleaner [Re: bioburner]
Linctex Offline
Loc: Waco, TX
Yes, or a lift pump
#4508308 - 09/05/17 06:11 PM Re: Need home brew Fuel Injector cleaner [Re: bioburner]
Oro_O Offline
Loc: Seattle-ish, WA
My first thought, too. Also electrical/ignition issues can cause this. Injectors would be much, much lower down the diagnostic list.
#4508332 - 09/05/17 06:42 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
Chris142 Offline
Loc: Deplorable in apple valley, ca
IIRC The 444 was just a mechanical cummins with a pt pump and automatically adjusting timing. If it wont rev its not all 6 injectors failed at the same time. Pump is bad or the filter is plugged.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4508342 - 09/05/17 07:00 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
Linctex Offline
Loc: Waco, TX
Check fuel pressure at the injection pump inlet fitting, and work back from there.
#4508363 - 09/05/17 07:17 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
dustyroads Offline
Loc: upstate NY
As has been mentioned, try a fuel filter first. As a kid I drove some of those mechanical pump Cummins powered trucks, and man a slightly plugged fuel filter was awful. I don't recall one that was so bad that it wouldn't rev, but I changed filters plenty on those engines. If you can get it running enough to go down the road, get some Power Service, Howes or whatever diesel injector cleaner you can buy into the tanks.
Those older engines didn't have a whole lot of injection pressure or the tiny holes (in the injectors) that we have today, so not sure how much an injector cleaner will help.
2013 F150 XLT 5.0 4X4 96k+
Edge 5W-30 / Fram 10575
#4508393 - 09/05/17 07:52 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
JohnnyJohnson Online   content
Loc: Wet side WA
If anything is going to help a good shot of this should.
2004 Toyota Corolla 121790
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4508541 - 09/05/17 10:09 PM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
bopiddy Offline
Loc: Pennsylvania
Thanks everyone! I'll keep you posted!
#4508770 - 09/06/17 07:53 AM Re: Need home brew Fuel Injector cleaner [Re: bopiddy]
UG_Passat Offline
Loc: NJ
If you look at the MSDS for various diesel additives, naphtha comes up a lot and in higher concentrations.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
#4514141 - 09/12/17 10:41 AM Re: Need home brew Fuel Injector cleaner [Re: JohnnyJohnson]
Bgallagher Offline
Loc: Boston, MA
+1 This is a proven cleaner for diesel engines. I wouldn't bother with a homebrew versus something that is commonly known as a solution.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
