Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
113 registered members (andyd, 2009Edge, 55hambone, 2002 Maxima SE, 77GrandPrix, AdRock, 13 invisible), 1,835 guests, and 31 spiders.
Topics290,958
Posts4,853,320
Members66,062
Most Online3,590
Jan 24th, 2017
Replaced Inner Tie Rod - Made Mistakes. #4508206
09/05/17 03:55 PM
09/05/17 03:55 PM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
I replaced the inner tierod on my truck with a Moog EV370. I usually read the instructions which come in the package but there were no instructions, so I plunged in. The good news is that I had a little bit of play on the driver side front wheel and now there is no more play.
I read the FSM after the job was done and realised that I made three mistakes. The manual wants the rack and the tie rod joint greased which I did not do. I can slide the boot back and easily rectify that. The joint already had grease in it, they want more added?
There was a plastic sleeve over the original joint, which the manual calls a shock dampener. The manual wants it to be transferred over to the new joint. I can do that without too much difficulty by disconnecting the outer tie rod.
The manual wants a pipe wrench on the end of the rack so that the torque involved in loosening and tightening the tie rod is not transferred to the internals of the rack and pinion unit. I did not use a pipe wrench and must have applied about 140 ft lbs of torque to break the old loctited joint loose. Might I have damaged anything? So far no symptoms.
I set the toe by using string and jackstands and am pretty confident that I have the toe set correectly.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508215
09/05/17 04:11 PM
09/05/17 04:11 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I highly recommend you get the alignment checked anyway. Last time I changed tie rods I thought I got the toe bang on but ended up being WAY off.
2018 Hyundai Elantra VE -- 4K
2013 Honda Pilot EX-L 4WD -- 56K
2002 Honda Accord EX-L -- 211K
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508216
09/05/17 04:12 PM
09/05/17 04:12 PM
WI
HoosierJeeper Offline
WI
If it has grease in it, I wouldn't worry. I'd go by what the Moog part said, and if it didn't say to grease it, you're good. The FSM is probably written that way because maybe some come ungreased and they want you to check it.
The shock dampener thing, never seen one so I don't know.
If it's not clunking or doing anything odd, don't worry. I've never heard of the pipe wrench thing. When I replaced my tie rods on my Liberty, I just used a big adjustable wrench, didn't hold the rack or anything.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: mclasser] #4508232
09/05/17 04:29 PM
09/05/17 04:29 PM
Toronto, Canada
Toronto, Canada
You will be surprised by how accurately the toe can be set if you are diligent enough. I set the toe many years ago on the truck and the front tires are wearing very very evenly. I am assuming incorrect toe will manifest itself in tire wear, I don't know how accurate the assumption is.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508248
09/05/17 04:49 PM
09/05/17 04:49 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
You really should get a real alignment.
With it on jack stands, you have weight on the wheels right? Wheels aren't floating? Because you can't do an alignment if the weight isn't on the wheels, the toe will be quite a bit off.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: Nick1994] #4508253
09/05/17 04:54 PM
09/05/17 04:54 PM
Toronto, Canada
Toronto, Canada
No, the truck is on the ground. The jackstands are only to tie the string on to.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508265
09/05/17 05:10 PM
09/05/17 05:10 PM
NC
BigD1 Offline
BigD1  Offline
NC
Did you get the steering wheel centered?
It can a PITA some times to get it centered. I gave up getting it centered this past Spring when I used the string method after I replaced a lot of parts on the front end. Took my truck to get a two wheel alignment done, and the tech did say I did a dang good job of setting the toe.
1992 Toyota Pickup--Formula Shell 10W-30--Fram PH3614
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: BigD1] #4508289
09/05/17 05:46 PM
09/05/17 05:46 PM
Toronto, Canada
Toronto, Canada
Yes, the steering wheel is centered now and also was before tierod replacement.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508351
09/05/17 07:07 PM
09/05/17 07:07 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
HoosierJeeper is right, if it's greased, it's greased. Not all parts come greased.
The "shock damper" is just an accordion sleeve, right? It's only purpose is to keep grit from getting into the grease. You should get it in there ASAP, but it won't explode if you don't.
If the rack isn't leaking, and you can move it from lock to lock without any funny noises, you probably dodged that bullet. Time will tell.
Various musings: http://hangfire.net
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: HangFire] #4508357
09/05/17 07:12 PM
09/05/17 07:12 PM
Toronto, Canada
Toronto, Canada
The shock damper is different from the boot. The shock damper is about 1 1/4 in long, smooth, pinkish white in colour and fits tightly over the ball and socket joint of the tierod.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508358
09/05/17 07:12 PM
09/05/17 07:12 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
I managed to align my last 528e by taking painstaking measurements of the original set up. I kept it a 1/2 turn short to account for the wear. Drove great and tires didn't wear on the edges. Wheel was still centered.
Thick oil is better grin2
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508400
09/05/17 08:00 PM
09/05/17 08:00 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I think you should do what the FSM wants you to do. It sounds like some important stuff.
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: Merkava_4] #4508454
09/05/17 08:41 PM
09/05/17 08:41 PM
Toronto, Canada
Toronto, Canada
Well, I can still do the way FSM wants on two of the three items. It is too late for the pipe wrench backup, what has been done is done, no way to correct it.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508488
09/05/17 09:18 PM
09/05/17 09:18 PM
PA
Lasthope05 Online content
Lasthope05  Online Content
PA
I just want to add that a lot of people do not know how to properly align toe with the string method. A majority of people incorrectly assume the front and rear wheel widths are the same, when most are not, and proceed to align the two hub centers parallel with the string.
Since most vehicles have smaller rear track widths, by adjusting the front to what you think is neutral (zero toe) is actuality negative toe(toe out). To properly do a string alignment you have to add the difference in track width, from the front and rear, to the hub center spacing for a proper parallel alignment.
Re: Replaced Inner Tie Rod - Made Mistakes. [Re: George7941] #4508638
09/06/17 01:15 AM
09/06/17 01:15 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Is the pipe wrench for holding the inner tie rod still while you loosen the outer tie rod ?
