Bought a Giulia
by RamFan. 09/22/18 08:38 AM
Toyota Genuine oil 10W30
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
85 registered members (ABomb369, alarmguy, Armkb, Aero540T, 02z, 6 invisible), 1,498 guests, and 41 spiders.
Topics290,814
Posts4,850,860
Members66,040
Most Online3,590
Jan 24th, 2017
Flaking aluminum oil pan #4508172
09/05/17 02:56 PM
09/05/17 02:56 PM
Canada
Boosted240 Offline OP
Canada
About a week ago I drained my oil and pulled the lower oil pan, saw that the residual oil in the pan seemed to have a fine glitter to it in the sunlight. I cut open the filter and found about a dozen <1mm diameter flakes in the pleats that were non magnetic. I luckily sampled the oil drain so I sent it off to Blackstone last week. The report came back with nothing too concerning. Been scratching my head for days. Today i was cleaning up the gasket surface of the upper aluminum oil pan to reinstall the lower portion I removed last week. After removing some varnish with a towel soaked in brake clean I came across what I believe to be the source of the flakes. It appears to be a rough casting defects from the factory, I also was wonder if high detergent synthetic oil also accelerated the flaking? I scratched a little off with a pick and it produced identical flakes to the ones I found in the filter. What kind of aluminum casting anomaly is this?
Re: Flaking aluminum oil pan [Re: Boosted240] #4508188
09/05/17 03:28 PM
09/05/17 03:28 PM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
If Iím looking at the right area it almost looks like the tool which tightened the upper pan got into the casting...
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: Flaking aluminum oil pan [Re: Boosted240] #4508224
09/05/17 04:19 PM
09/05/17 04:19 PM
Canada
Canada
Hmm quite possible. The area left behind from the flaked aluminum is rough, like it was sand casted.
Re: Flaking aluminum oil pan [Re: Boosted240] #4508300
09/05/17 06:01 PM
09/05/17 06:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
What engine/vehicle?
Re: Flaking aluminum oil pan [Re: Boosted240] #4508311
09/05/17 06:16 PM
09/05/17 06:16 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
From that affected area, go down just past that ridge. Looks like pits where something hit the pan. Same tool?
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Flaking aluminum oil pan [Re: Linctex] #4508634
09/06/17 01:02 AM
09/06/17 01:02 AM
Canada
Canada
Nissan SR20DET
Re: Flaking aluminum oil pan [Re: Boosted240] #4508642
09/06/17 01:27 AM
09/06/17 01:27 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The flakes might not even be metal; they might be vinyl or some other non-metallic coating.
Re: Flaking aluminum oil pan [Re: Merkava_4] #4508655
09/06/17 02:10 AM
09/06/17 02:10 AM
PimTac Offline
PimTac  Offline
What Merk just said prompts me to wonder if any additives were used in this Nissan? Cerakote etc?
Re: Flaking aluminum oil pan [Re: Boosted240] #4508760
09/06/17 07:37 AM
09/06/17 07:37 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
It is probably going to be tough to get it clean enough, but if it is in fact a casting porosity you might be able to seal it with Glyptal. If you can find 1201B it is thicker. Iíve never tried to use it on Aluminum or on a non hot tanked used part though.
Robert
  • 1972 Ford F100
