Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
go green or Dexcool?
by umungus1122
06/20/18 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
06/20/18 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
06/20/18 04:37 PM
bcj, Ilia, nmac9, Theraven, battleman13
65279 Registered Users
105 registered (addyguy, 4WD, 01rangerxl, 87sammy, 97f150, 17 invisible), 1422 Guests and 56 Spiders online.
65279 Members
67 Forums
285679 Topics
#4508122 - 09/05/17 01:34 PM Super Tech HM a blend?
Bhoppy1216 Offline
Loc: Houston, TX
I currently use SuperTech HM in my truck and my car and have had great results in my car; its too new in my truck to tell. I was thinking of switching to MaxLife just because it is a blend that provides the same benefits of ST, and for not much more. I just dont see anything on the bottle that says it is a blend, but figured you guys would definitely know if it was or not.
#4508135 - 09/05/17 01:48 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Nickdfresh Offline
Loc: Buffalo, NY
No way to know for sure but I suspect that at least the thinner weights are a blend, and that most conventional motor oil is a "blend" with a percentage of Group III...
Valvoline has a $10 rebate for the full syn, making it almost as cheap as the blend...
Edited by Nickdfresh (09/05/17 01:49 PM)
#4508139 - 09/05/17 01:53 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Bhoppy1216 Offline
Loc: Houston, TX
Group III? Is there a website or sticky to decipher that?
#4508140 - 09/05/17 01:57 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Nickdfresh Offline
Loc: Buffalo, NY
#4508176 - 09/05/17 03:07 PM Re: Super Tech HM a blend? [Re: Nickdfresh]
Bhoppy1216 Offline
Loc: Houston, TX
Man that cleared so many things up lol. How can you tell what is what though? Does it specify on the bottle, or on something like the MSDS?
#4508179 - 09/05/17 03:10 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Bhoppy1216 Offline
Loc: Houston, TX
Also where is this rebate that you speak of? I cant find it anywhere on the Val website. I kind of like that Mobil 1's HM is also full Syn, and my local Wally world carries it for 21 dollars. I just am a Valvoline fan, but I guess oil is oil now a days.
#4508310 - 09/05/17 06:16 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Linctex Offline
Loc: Waco, TX
Maybe in this sub-forum?
https://bobistheoilguy.com/forums/ubbthr...ons#Post4500481
#4508464 - 09/05/17 08:51 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Miller88 Offline
Loc: Onondaga County
Is supertech HM any good?
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4508470 - 09/05/17 08:59 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
SilverFusion2010 Offline
Loc: Crawfordville FL
It's adequate. I wouldn't use it for oci longer than 5k. And not in anything that requires dexos1
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4510199 - 09/07/17 05:03 PM Re: Super Tech HM a blend? [Re: Bhoppy1216]
Nickdfresh Offline
Loc: Buffalo, NY
There are a few sources for this, but just the very stringent GF-5 and API SM/SN certs required far more robust oils. There was also a retired Pennzoil engineer that has long since stopped posting here that revealed that Pennzoil YB was either Group II+ or a blend of Groups II & III. I think most here accept that at least the thinner weights of "conventional" are probably some sort of blend with some companies openly advertising their least expensive oils as blends such as Motorcraft/Conoco-Phillips....
