White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
23 registered members (BretK, ChrisD46, billt460, c502cid, Char Baby, 4 invisible), 802 guests, and 33 spiders.
Topics296,866
Posts4,960,388
Members66,982
Most Online2,688
Jan 19th, 2019
Ford 5.4 Oil Sending Unit leak #4507870
09/05/17 07:44 AM
09/05/17 07:44 AM
Illinois
carguy996 Offline OP
Illinois
I have a 2000 Expedition with the 5.4 Triton V8. The oil sending unit was not functioning properly and would occasionally not give a reading causing the gauge to drop and light to come on when the vehicle has proper oil pressure. After putting thread tape around the new sensor and installing it until snug without over tightening, when starting the car it leaks like crazy, just pours oil out. After taking a look, it looks like the old one might have had RTV around it....perhaps the previous owner has replaced this part before. Is there any harm in throwing a bunch of RTV around the sensor, or does the entire oil filter housing need to be replaced?
2018 Nissan Rogue Platinum AWD w/ ProPilot
2014 Honda Odyssey Touring Elite 3.5
2013 Chrysler 200 Convertible 3.6
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4507884
09/05/17 08:00 AM
09/05/17 08:00 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
It may be a defective new part, that would be nothing unusual today. If the replacement leaks you might be dealing with a cracked housing if the previous owner was ham fisted. Don't RTV the thing fix it properly, when these things let go they can spew a lot of oil fast and thats not too cool driving down the road, RTV wont prevent it.
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4507890
09/05/17 08:04 AM
09/05/17 08:04 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
FIRST - - - what brand (and country of origin) is the sending unit from?
SECOND - there "should" have been a coating of very stiff (not easily pliable) thread coating on the threads already.
Sounds to me like you installed an inferior sending unit.
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4507900
09/05/17 08:12 AM
09/05/17 08:12 AM
Illinois
Illinois
The replacement sending unit was a Borg Warner that leaked when installed. Thinking it was a defective part, I went to install the original one and after doing that, had the same leak. Leads me to believe there is an issue with the housing. Looks like a beast to replace the housing on this thing.....There is another issue with this vehicle where it goes through PCM relays about every 6-12 months. Is it even worth putting money into at this point? It has 161,000 miles, in overall good shape, but it is 17 years old and only lightly used as a vehicle to pull a popup camper.
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4507906
09/05/17 08:14 AM
09/05/17 08:14 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Sending units need to pick up ground from the engine block unless they are very special two wire units. Coating the threads with an insulating material might give you trouble. The units are cheap enough, just change it. The Japanese senders seem to be more reliable than those in many European cars.
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4507919
09/05/17 08:29 AM
09/05/17 08:29 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Do you have a photo ?
Does it look like this ;
http://www.rockauto.com/en/moreinfo.php?pk=386772&cc=1362439&jsn=689
Wyr
God bless
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4507938
09/05/17 08:51 AM
09/05/17 08:51 AM
Southeast
meep Offline
meep  Offline
Southeast
hairline crack in the port it screws into?
-m
2018 F150
2015 crv (wifey!)
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4508029
09/05/17 10:30 AM
09/05/17 10:30 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
They leak when the plastic part gets dried brittle and cracked. The brass threaded part is usually fine.
Re: Ford 5.4 Oil Sending Unit leak [Re: carguy996] #4508321
09/05/17 05:30 PM
09/05/17 05:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Only you can make that decision. I'm sure there's a relatively easy fix.
Relays & fuses are free at the local "pick-n-pull" wrecking yard, as long as you buy something else.
I always fill my pockets full.
It's certainly possible. I have fixed cracks in aluminum threads with good epoxy like JB Weld (or 3M - much better) butt it takes a lot of carb cleaner to get the crack and threads super clean.
